@Bernd_Pfrommer
Still trying to solve this issue⊠I did a factory reset on my PLM and a factory reset on one of my 2477D dimmers.
Using the button on the PLM, set it to linking mode, then linked to the 2477D using the button on the 2477D.
Using the button on the 2477D, set it to linking mode and then linked to the PLM using the button on the PLM.
Deleted my .items file and created a new one with only
Dimmer porch {insteonplm=â33.81.AD:F00.00.01#dimmerâ}
Number porch_manchange {insteonplm=â33.81.AD:F00.00.01#manualchangeâ}
Shut down OpenHAB, deleted logs and restarted.
As far as I can see, my setup is now as clean and simple as it could be to test this issue.
I manually adjusted the dimmer using the sitemap and verified that an event was seen in the log and that the physical dimmer reacted.
2017-04-22 09:20:52.978 [ItemCommandEvent ] - Item âporchâ received command 54
2017-04-22 09:20:52.994 [ItemStateChangedEvent ] - porch changed from 0 to 54
I went to the dimmer switch and âmanualchangedâ down using the paddle.
As seen before, OpenHAB registered this change, both, the manualchange start and end.
As expected it also registered the change in the âdimmerâ state
2017-04-22 09:21:32.881 [ItemStateChangedEvent ] - porch_manchange changed from NULL to 0
2017-04-22 09:21:34.393 [ItemStateChangedEvent ] - porch_manchange changed from 0 to 1
2017-04-22 09:21:34.822 [ItemStateChangedEvent ] - porch changed from 54 to 19
I then âmanualchangedâ the dimmer up but nothing was registered in the event.log. I tried manualchanging down and nothing registered.
As before, only the the first manualchange then stop is ever registered as an event in the events.log.
My debug log is below, I really think it has something to do with the fact that my messages are 0xCF
, not 0xCB
and also the numbers after the ALL_LINK_MESSAGES
are 3:3
and not 3:2
Since the first event that worked, is in the format expected 0xCB=ALL_LINK_BROADCAST:3:2
format.
Please help as I have no more ideas and canât get the OpenHAB code to build so I canât even try to fix it myself.
Thanks!
2017-04-22 09:21:32 org.openhab.binding.insteonplm.InsteonPLMActiveBinding$PortListener.msg(InsteonPLMActiveBinding.java:591) - got msg: IN:Cmd:0x50|fromAddress:33.81.AD|toAddress:00.00.01|messageFlags:0xCF=ALL_LINK_BROADCAST:3:3|command1:0x17|command2:0x00|
2017-04-22 09:21:32 org.openhab.binding.insteonplm.internal.device.MessageDispatcher.handleAllLinkMessage(MessageDispatcher.java:75) - all link message: IN:Cmd:0x50|fromAddress:33.81.AD|toAddress:00.00.01|messageFlags:0xCF=ALL_LINK_BROADCAST:3:3|command1:0x17|command2:0x00|
2017-04-22 09:21:32 org.openhab.binding.insteonplm.internal.device.MessageDispatcher.handleAllLinkMessage(MessageDispatcher.java:77) - all link message is no duplicate: true/true
2017-04-22 09:21:32 org.openhab.binding.insteonplm.internal.device.MessageDispatcher.handleAllLinkMessage(MessageDispatcher.java:79) - 33.81.AD:FastOnOff->DefaultMsgHandler cmd1:0x17 group 1/-1:IN:Cmd:0x50|fromAddress:33.81.AD|toAddress:00.00.01|messageFlags:0xCF=ALL_LINK_BROADCAST:3:3|command1:0x17|command2:0x00|
2017-04-22 09:21:32 org.openhab.binding.insteonplm.internal.device.MessageHandler$DefaultMsgHandler.handleMessage(MessageHandler.java:338) - DefaultMsgHandler drop unimpl message 0x17: IN:Cmd:0x50|fromAddress:33.81.AD|toAddress:00.00.01|messageFlags:0xCF=ALL_LINK_BROADCAST:3:3|command1:0x17|command2:0x00|
2017-04-22 09:21:32 org.openhab.binding.insteonplm.internal.device.MessageDispatcher.handleAllLinkMessage(MessageDispatcher.java:79) - 33.81.AD:DimmerRamp->DefaultMsgHandler cmd1:0x17 group 1/-1:IN:Cmd:0x50|fromAddress:33.81.AD|toAddress:00.00.01|messageFlags:0xCF=ALL_LINK_BROADCAST:3:3|command1:0x17|command2:0x00|
2017-04-22 09:21:32 org.openhab.binding.insteonplm.internal.device.MessageDispatcher.handleAllLinkMessage(MessageDispatcher.java:79) - 33.81.AD:ManualChange->StartManualChangeHandler cmd1:0x17 group 1/-1:IN:Cmd:0x50|fromAddress:33.81.AD|toAddress:00.00.01|messageFlags:0xCF=ALL_LINK_BROADCAST:3:3|command1:0x17|command2:0x00|
2017-04-22 09:21:32 org.openhab.binding.insteonplm.internal.device.MessageHandler$StartManualChangeHandler.handleMessage(MessageHandler.java:621) - StartManualChangeHandler: dev 33.81.AD manual state change: DOWN
2017-04-22 09:21:32 org.openhab.binding.insteonplm.internal.device.DeviceFeature.publish(DeviceFeature.java:321) - 33.81.AD:ManualChange publishing: 0
2017-04-22 09:21:32 org.openhab.binding.insteonplm.internal.device.MessageDispatcher.handleAllLinkMessage(MessageDispatcher.java:79) - 33.81.AD:Dimmer->NoOpMsgHandler cmd1:0x17 group 1/1:IN:Cmd:0x50|fromAddress:33.81.AD|toAddress:00.00.01|messageFlags:0xCF=ALL_LINK_BROADCAST:3:3|command1:0x17|command2:0x00|
2017-04-22 09:21:32 org.openhab.binding.insteonplm.internal.device.DeviceFeature.publish(DeviceFeature.java:321) - 33.81.AD:GenericLastTime publishing: 2017-04-22T09:21:32
2017-04-22 09:21:34 org.openhab.binding.insteonplm.InsteonPLMActiveBinding$PortListener.msg(InsteonPLMActiveBinding.java:591) - got msg: IN:Cmd:0x50|fromAddress:33.81.AD|toAddress:00.00.01|messageFlags:0xCB=ALL_LINK_BROADCAST:3:2|command1:0x18|command2:0x00|
2017-04-22 09:21:34 org.openhab.binding.insteonplm.internal.device.MessageDispatcher.handleAllLinkMessage(MessageDispatcher.java:75) - all link message: IN:Cmd:0x50|fromAddress:33.81.AD|toAddress:00.00.01|messageFlags:0xCB=ALL_LINK_BROADCAST:3:2|command1:0x18|command2:0x00|
2017-04-22 09:21:34 org.openhab.binding.insteonplm.internal.device.MessageDispatcher.handleAllLinkMessage(MessageDispatcher.java:77) - all link message is no duplicate: true/true
2017-04-22 09:21:34 org.openhab.binding.insteonplm.internal.device.MessageDispatcher.handleAllLinkMessage(MessageDispatcher.java:79) - 33.81.AD:ManualChange->StopManualChangeHandler cmd1:0x18 group 1/-1:IN:Cmd:0x50|fromAddress:33.81.AD|toAddress:00.00.01|messageFlags:0xCB=ALL_LINK_BROADCAST:3:2|command1:0x18|command2:0x00|
2017-04-22 09:21:34 org.openhab.binding.insteonplm.internal.device.MessageHandler$StopManualChangeHandler.handleMessage(MessageHandler.java:637) - StopManualChangeHandler: dev 33.81.AD manual state change: 0
2017-04-22 09:21:34 org.openhab.binding.insteonplm.internal.device.DeviceFeature.publish(DeviceFeature.java:321) - 33.81.AD:ManualChange publishing: 1
2017-04-22 09:21:34 org.openhab.binding.insteonplm.internal.device.MessageDispatcher.handleAllLinkMessage(MessageDispatcher.java:79) - 33.81.AD:Dimmer->DimmerStopManualChangeHandler cmd1:0x18 group 1/1:IN:Cmd:0x50|fromAddress:33.81.AD|toAddress:00.00.01|messageFlags:0xCB=ALL_LINK_BROADCAST:3:2|command1:0x18|command2:0x00|
2017-04-22 09:21:34 org.openhab.binding.insteonplm.internal.device.DeviceFeature.publish(DeviceFeature.java:321) - 33.81.AD:GenericLastTime publishing: 2017-04-22T09:21:34
2017-04-22 09:21:34 org.openhab.binding.insteonplm.internal.device.InsteonDevice.processRequestQueue(InsteonDevice.java:459) - qe taken off direct: Dimmer(1:3:8) OUT:Cmd:0x62|toAddress:33.81.AD|messageFlags:0x0F=DIRECT:3:3|command1:0x19|command2:0x00|
2017-04-22 09:21:34 org.openhab.binding.insteonplm.internal.device.InsteonDevice.processRequestQueue(InsteonDevice.java:479) - next request queue processed in 2000 msec, quiettime = 2000
2017-04-22 09:21:34 org.openhab.binding.insteonplm.internal.driver.Port$IOStreamWriter.run(Port.java:415) - writing (500): OUT:Cmd:0x62|toAddress:33.81.AD|messageFlags:0x0F=DIRECT:3:3|command1:0x19|command2:0x00|
2017-04-22 09:21:34 org.openhab.binding.insteonplm.InsteonPLMActiveBinding$PortListener.msg(InsteonPLMActiveBinding.java:591) - got msg: IN:Cmd:0x50|fromAddress:33.81.AD|toAddress:2F.B9.A3|messageFlags:0x2B=ACK_OF_DIRECT:3:2|command1:0x02|command2:0x32|
2017-04-22 09:21:34 org.openhab.binding.insteonplm.internal.device.MessageDispatcher$DefaultDispatcher.dispatch(MessageDispatcher.java:149) - 33.81.AD:Dimmer DIRECT_ACK: q:QUERY_PENDING cmd: 80
2017-04-22 09:21:34 org.openhab.binding.insteonplm.internal.device.MessageDispatcher$DefaultDispatcher.dispatch(MessageDispatcher.java:154) - changing key to 0x19 for msg IN:Cmd:0x50|fromAddress:33.81.AD|toAddress:2F.B9.A3|messageFlags:0x2B=ACK_OF_DIRECT:3:2|command1:0x02|command2:0x32|
2017-04-22 09:21:34 org.openhab.binding.insteonplm.internal.device.MessageHandler$DimmerRequestReplyHandler.handleMessage(MessageHandler.java:588) - DimmerRequestReplyHandler: set device 33.81.AD to level 19
2017-04-22 09:21:34 org.openhab.binding.insteonplm.internal.device.DeviceFeature.publish(DeviceFeature.java:321) - 33.81.AD:Dimmer publishing: 19
2017-04-22 09:21:34 org.openhab.binding.insteonplm.internal.device.MessageDispatcher$DefaultDispatcher.dispatch(MessageDispatcher.java:176) - defdisp: 33.81.AD:Dimmer set status to: QUERY_ANSWERED
2017-04-22 09:21:36 org.openhab.binding.insteonplm.internal.device.RequestQueueManager$RequestQueueReader.run(RequestQueueManager.java:137) - device queue for 33.81.AD is empty!
2017-04-22 09:22:58 org.openhab.binding.insteonplm.InsteonPLMActiveBinding$PortListener.msg(InsteonPLMActiveBinding.java:591) - got msg: IN:Cmd:0x50|fromAddress:33.81.AD|toAddress:00.00.01|messageFlags:0xCF=ALL_LINK_BROADCAST:3:3|command1:0x17|command2:0x01|
2017-04-22 09:22:58 org.openhab.binding.insteonplm.internal.device.MessageDispatcher.handleAllLinkMessage(MessageDispatcher.java:75) - all link message: IN:Cmd:0x50|fromAddress:33.81.AD|toAddress:00.00.01|messageFlags:0xCF=ALL_LINK_BROADCAST:3:3|command1:0x17|command2:0x01|
2017-04-22 09:22:58 org.openhab.binding.insteonplm.internal.device.DeviceFeature.publish(DeviceFeature.java:321) - 33.81.AD:GenericLastTime publishing: 2017-04-22T09:22:58
2017-04-22 09:23:00 org.openhab.binding.insteonplm.InsteonPLMActiveBinding$PortListener.msg(InsteonPLMActiveBinding.java:591) - got msg: IN:Cmd:0x50|fromAddress:33.81.AD|toAddress:00.00.01|messageFlags:0xCF=ALL_LINK_BROADCAST:3:3|command1:0x18|command2:0x00|
2017-04-22 09:23:00 org.openhab.binding.insteonplm.internal.device.MessageDispatcher.handleAllLinkMessage(MessageDispatcher.java:75) - all link message: IN:Cmd:0x50|fromAddress:33.81.AD|toAddress:00.00.01|messageFlags:0xCF=ALL_LINK_BROADCAST:3:3|command1:0x18|command2:0x00|
2017-04-22 09:23:00 org.openhab.binding.insteonplm.internal.device.DeviceFeature.publish(DeviceFeature.java:321) - 33.81.AD:GenericLastTime publishing: 2017-04-22T09:23:00
2017-04-22 09:23:01 org.openhab.binding.insteonplm.InsteonPLMActiveBinding.logDeviceStatistics(InsteonPLMActiveBinding.java:684) - devices: 1 configured, 1 polling, msgs received: 11
2017-04-22 09:23:06 org.openhab.binding.insteonplm.internal.device.InsteonDevice.processRequestQueue(InsteonDevice.java:459) - qe taken off direct: Dimmer(1:3:8) OUT:Cmd:0x62|toAddress:33.81.AD|messageFlags:0x0F=DIRECT:3:3|command1:0x19|command2:0x00|
2017-04-22 09:23:06 org.openhab.binding.insteonplm.internal.device.InsteonDevice.processRequestQueue(InsteonDevice.java:479) - next request queue processed in 500 msec, quiettime = 500
2017-04-22 09:23:06 org.openhab.binding.insteonplm.internal.driver.Port$IOStreamWriter.run(Port.java:415) - writing (500): OUT:Cmd:0x62|toAddress:33.81.AD|messageFlags:0x0F=DIRECT:3:3|command1:0x19|command2:0x00|
2017-04-22 09:23:06 org.openhab.binding.insteonplm.InsteonPLMActiveBinding$PortListener.msg(InsteonPLMActiveBinding.java:591) - got msg: IN:Cmd:0x50|fromAddress:33.81.AD|toAddress:2F.B9.A3|messageFlags:0x2F=ACK_OF_DIRECT:3:3|command1:0x02|command2:0xC5|
2017-04-22 09:23:06 org.openhab.binding.insteonplm.internal.device.MessageDispatcher$DefaultDispatcher.dispatch(MessageDispatcher.java:149) - 33.81.AD:Dimmer DIRECT_ACK: q:QUERY_PENDING cmd: 80
2017-04-22 09:23:06 org.openhab.binding.insteonplm.internal.device.MessageDispatcher$DefaultDispatcher.dispatch(MessageDispatcher.java:154) - changing key to 0x19 for msg IN:Cmd:0x50|fromAddress:33.81.AD|toAddress:2F.B9.A3|messageFlags:0x2F=ACK_OF_DIRECT:3:3|command1:0x02|command2:0xC5|
2017-04-22 09:23:06 org.openhab.binding.insteonplm.internal.device.MessageHandler$DimmerRequestReplyHandler.handleMessage(MessageHandler.java:588) - DimmerRequestReplyHandler: set device 33.81.AD to level 77
2017-04-22 09:23:06 org.openhab.binding.insteonplm.internal.device.DeviceFeature.publish(DeviceFeature.java:321) - 33.81.AD:Dimmer publishing: 77
2017-04-22 09:23:06 org.openhab.binding.insteonplm.internal.device.MessageDispatcher$DefaultDispatcher.dispatch(MessageDispatcher.java:176) - defdisp: 33.81.AD:Dimmer set status to: QUERY_ANSWERED
2017-04-22 09:23:06 org.openhab.binding.insteonplm.internal.device.DeviceFeature.publish(DeviceFeature.java:321) - 33.81.AD:GenericLastTime publishing: 2017-04-22T09:23:06
2017-04-22 09:23:06 org.openhab.binding.insteonplm.internal.device.RequestQueueManager$RequestQueueReader.run(RequestQueueManager.java:137) - device queue for 33.81.AD is empty!
2017-04-22 09:24:07 org.openhab.binding.insteonplm.InsteonPLMActiveBinding$PortListener.msg(InsteonPLMActiveBinding.java:591) - got msg: IN:Cmd:0x50|fromAddress:33.81.AD|toAddress:00.00.01|messageFlags:0xC7=ALL_LINK_BROADCAST:3:1|command1:0x17|command2:0x00|
2017-04-22 09:24:07 org.openhab.binding.insteonplm.internal.device.MessageDispatcher.handleAllLinkMessage(MessageDispatcher.java:75) - all link message: IN:Cmd:0x50|fromAddress:33.81.AD|toAddress:00.00.01|messageFlags:0xC7=ALL_LINK_BROADCAST:3:1|command1:0x17|command2:0x00|
2017-04-22 09:24:07 org.openhab.binding.insteonplm.internal.device.DeviceFeature.publish(DeviceFeature.java:321) - 33.81.AD:GenericLastTime publishing: 2017-04-22T09:24:07
2017-04-22 09:24:09 org.openhab.binding.insteonplm.InsteonPLMActiveBinding$PortListener.msg(InsteonPLMActiveBinding.java:591) - got msg: IN:Cmd:0x50|fromAddress:33.81.AD|toAddress:00.00.01|messageFlags:0xC3=ALL_LINK_BROADCAST:3:0|command1:0x18|command2:0x00|
2017-04-22 09:24:09 org.openhab.binding.insteonplm.internal.device.MessageDispatcher.handleAllLinkMessage(MessageDispatcher.java:75) - all link message: IN:Cmd:0x50|fromAddress:33.81.AD|toAddress:00.00.01|messageFlags:0xC3=ALL_LINK_BROADCAST:3:0|command1:0x18|command2:0x00|
2017-04-22 09:24:09 org.openhab.binding.insteonplm.internal.device.DeviceFeature.publish(DeviceFeature.java:321) - 33.81.AD:GenericLastTime publishing: 2017-04-22T09:24:09
