I am having a new problem with my insteon binding. It was working fine but now I can control the lights but the UI does not show the state of the light if the switch is flipped. It will show on the UI in the proper state if I use the UI to turn the light on or off. The logs do not show the light switch being flipped by the switch but does by the UI. My logs look like this when using the UI:
2019-03-04 19:16:03.046 [INFO ] [onplm.internal.device.CommandHandler] - LightOnOffCommandHandler: sent msg to switch 43.62.EB off
2019-03-04 19:16:03.046 [INFO ] [onplm.internal.device.CommandHandler] - Sending message to 43.62.EB
2019-03-04 19:16:03.416 [INFO ] [onplm.internal.device.MessageHandler] - DimmerRequestReplyHandler: set device 43.62.EB to level 0
2019-03-04 19:16:06.488 [INFO ] [onplm.internal.device.MessageHandler] - DimmerRequestReplyHandler: set device 43.62.EB to level 0
2019-03-04 19:23:31.118 [INFO ] [g.insteonplm.InsteonPLMActiveBinding] - devices: 48 configured, 0 polling, msgs received: 5
2019-03-04 19:33:31.118 [INFO ] [g.insteonplm.InsteonPLMActiveBinding] - devices: 48 configured, 0 polling, msgs received: 0
Any ideas?
-Keith
