I think this change may have broke the newer insteon hub (2245-222). It seems to have for me at least but maybe someone else can try? I’m using the latest build of 1.9.0 binding.
openhab.log:
2016-08-14 00:48:52.495 [INFO ] [.service.AbstractActiveService] - InsteonPLM has been started
Exception in thread "Thread-59" java.lang.NoSuchMethodError: org.apache.http.impl.client.DefaultHttpClient.execute(Lorg/apache/http/client/methods/HttpUriRequest;)Lorg/apache/http/client/methods/CloseableHttpResponse;
at org.openhab.binding.insteonplm.internal.driver.hub.HubIOStream.getURL(HubIOStream.java:213)
at org.openhab.binding.insteonplm.internal.driver.hub.HubIOStream.bufferStatus(HubIOStream.java:108)
at org.openhab.binding.insteonplm.internal.driver.hub.HubIOStream.poll(HubIOStream.java:156)
at org.openhab.binding.insteonplm.internal.driver.hub.HubIOStream.run(HubIOStream.java:226)
at java.lang.Thread.run(Thread.java:745)
Exception in thread "/hub2/REMOVED:REMOVED@10.0.0.15:25105,poll_time=1000 Writer" java.lang.NoSuchMethodError: org.apache.http.impl.client.DefaultHttpClient.execute(Lorg/apache/http/client/methods/HttpUriRequest;)Lorg/apache/http/client/methods/CloseableHttpResponse;
at org.openhab.binding.insteonplm.internal.driver.hub.HubIOStream.write(HubIOStream.java:139)
at org.openhab.binding.insteonplm.internal.driver.hub.HubIOStream$HubOutputStream.flushBuffer(HubIOStream.java:308)
at org.openhab.binding.insteonplm.internal.driver.hub.HubIOStream$HubOutputStream.write(HubIOStream.java:302)
at java.io.OutputStream.write(OutputStream.java:75)
at org.openhab.binding.insteonplm.internal.driver.IOStream.write(IOStream.java:67)
at org.openhab.binding.insteonplm.internal.driver.Port$IOStreamWriter.run(Port.java:421)
insteonplm.log:
2016-08-14 01:09:31 INFO o.o.b.i.InsteonPLMActivator[:37]- Insteon PLM binding has been started.
2016-08-14 01:09:31 DEBUG o.o.b.i.InsteonPLMActiveBinding[:154]- activating binding
2016-08-14 01:09:31 DEBUG o.o.b.i.InsteonPLMActiveBinding[:269]- global binding config has arrived.
2016-08-14 01:09:31 INFO o.o.b.i.InsteonPLMActiveBinding[:319]- dead device timeout set to 3000s
2016-08-14 01:09:31 DEBUG o.o.b.i.InsteonPLMActiveBinding[:273]- configuration update complete!
2016-08-14 01:09:31 DEBUG o.o.b.i.InsteonPLMActiveBinding[:358]- initializing...
2016-08-14 01:09:31 INFO o.o.b.i.InsteonPLMActiveBinding[:370]- config: port_0 -> /hub2/REMOVED:REMOVED@10.0.0.15:25105,poll_time=1000
2016-08-14 01:09:31 INFO o.o.b.i.InsteonPLMActiveBinding[:684]- devices: 0 configured, 0 polling, msgs received: 0
2016-08-14 01:09:31 DEBUG o.o.b.i.internal.driver.Poller[:188]- starting poll thread.
2016-08-14 01:09:31 DEBUG o.o.b.i.internal.driver.Driver[:83]- added new port: port_0 /hub2/REMOVED:REMOVED@10.0.0.15:25105,poll_time=1000
2016-08-14 01:09:31 INFO o.o.b.i.InsteonPLMActiveBinding[:370]- config: service.pid -> org.openhab.insteonplm
2016-08-14 01:09:31 DEBUG o.o.b.i.InsteonPLMActiveBinding[:376]- setting driver listener
2016-08-14 01:09:31 DEBUG o.o.b.i.InsteonPLMActiveBinding[:378]- starting 0 ports
2016-08-14 01:09:31 DEBUG o.o.b.i.internal.driver.Port[:149]- starting port /hub2/REMOVED:REMOVED@10.0.0.15:25105,poll_time=1000
2016-08-14 01:09:31 DEBUG o.o.b.i.internal.driver.Port[:268]- starting reader...
2016-08-14 01:09:31 DEBUG o.o.b.i.internal.driver.Port[:406]- starting writer...
2016-08-14 01:09:31 DEBUG o.o.b.i.i.d.ModemDBBuilder[:51]- querying port for first link record
2016-08-14 01:09:31 DEBUG o.o.b.i.internal.driver.Port[:415]- writing (0): OUT:Cmd:0x60|
2016-08-14 01:09:31 DEBUG o.o.b.i.internal.driver.Port[:139]- clearing modem db!
2016-08-14 01:09:31 DEBUG o.o.b.i.InsteonPLMActiveBinding[:380]- ports started
2016-08-14 01:09:31 DEBUG o.o.b.i.InsteonPLMActiveBinding[:386]- initialization complete, found 1 port!
2016-08-14 01:09:32 DEBUG o.o.b.i.InsteonPLMActiveBinding[:215]- item Light_Dinette binding changed: addr=3C.FC.53|prodKey:F00.00.01|feature:dimmer
2016-08-14 01:09:32 DEBUG o.o.b.i.i.d.DeviceTypeLoader[:205]- loaded 42 devices:
2016-08-14 01:09:32 DEBUG o.o.b.i.i.d.DeviceTypeLoader[:183]- 0x000041 ->pk:0x000041|model:2484DWH8|desc:KeypadLinc Countdown Timer|features:fastonoff=FastOnOff:lastheardfrom=GenericLastTime:manualchange=ManualChange:dimmer=GenericDimmer|groups
2016-08-14 01:09:32 DEBUG o.o.b.i.i.d.DeviceTypeLoader[:183]- F00.00.0A ->pk:F00.00.0A|model:2852-222|desc:Leak Sensor|features:contact=LeakSensorContact:lastheardfrom=GenericLastTime|groups
2016-08-14 01:09:32 DEBUG o.o.b.i.i.d.DeviceTypeLoader[:183]- F00.00.0D ->pk:F00.00.0D|model:2634-222|desc:On/Off Dual-Band Outdoor Module|features:lastheardfrom=GenericLastTime:switch=GenericSwitch|groups
2016-08-14 01:09:32 DEBUG o.o.b.i.i.d.DeviceTypeLoader[:183]- 0x000049 ->pk:0x000049|model:2843-222|desc:Wireless Open/Close Sensor|features:contact=GenericContact:lastheardfrom=GenericLastTime|groups
2016-08-14 01:09:32 DEBUG o.o.b.i.i.d.DeviceTypeLoader[:183]- F00.00.0C ->pk:F00.00.0C|model:2476D|desc:SwitchLinc Dimmer|features:fastonoff=FastOnOff:lastheardfrom=GenericLastTime:manualchange=ManualChange:dimmer=GenericDimmer|groups
2016-08-14 01:09:32 DEBUG o.o.b.i.i.d.DeviceTypeLoader[:183]- F00.00.0B ->pk:F00.00.0B|model:2672-422|desc:LED Dimmer|features:fastonoff=FastOnOff:lastheardfrom=GenericLastTime:manualchange=ManualChange:dimmer=GenericDimmer|groups
2016-08-14 01:09:32 DEBUG o.o.b.i.i.d.DeviceTypeLoader[:183]- 0x000068 ->pk:0x000068|model:2472D|desc:OutletLincDimmer|features:fastonoff=FastOnOff:lastheardfrom=GenericLastTime:manualchange=ManualChange:dimmer=GenericDimmer|groups
2016-08-14 01:09:32 DEBUG o.o.b.i.i.d.DeviceTypeLoader[:183]- 0x000045 ->pk:0x000045|model:2413U|desc:PowerLinc 2413U USB modem|features:broadcastonoff=GroupBroadcastOnOff|groups
2016-08-14 01:09:32 DEBUG o.o.b.i.i.d.DeviceTypeLoader[:183]- 0x00004A ->pk:0x00004A|model:2842-222|desc:Motion Sensor|features:data=MotionSensorData:contact=WirelessMotionSensorContact:lastheardfrom=GenericLastTime|groups
2016-08-14 01:09:32 DEBUG o.o.b.i.i.d.DeviceTypeLoader[:183]- F00.00.01 ->pk:F00.00.01|model:2477D|desc:SwitchLinc Dimmer|features:fastonoff=FastOnOff:lastheardfrom=GenericLastTime:manualchange=ManualChange:dimmer=GenericDimmer|groups
2016-08-14 01:09:32 DEBUG o.o.b.i.i.d.DeviceTypeLoader[:183]- F00.00.05 ->pk:F00.00.05|model:2456D3|desc:LampLinc V2|features:fastonoff=FastOnOff:lastheardfrom=GenericLastTime:manualchange=ManualChange:dimmer=GenericDimmer|groups
2016-08-14 01:09:32 DEBUG o.o.b.i.i.d.DeviceTypeLoader[:183]- F00.00.04 ->pk:F00.00.04|model:2876S|desc:ICON Switch|features:lastheardfrom=GenericLastTime:switch=GenericSwitch|groups
2016-08-14 01:09:32 DEBUG o.o.b.i.i.d.DeviceTypeLoader[:183]- F00.00.03 ->pk:F00.00.03|model:2845-222|desc:Hidden Door Sensor|features:data=HiddenDoorSensorData:contact=WirelessMotionSensorContact:lastheardfrom=GenericLastTime|groups
2016-08-14 01:09:32 DEBUG o.o.b.i.i.d.DeviceTypeLoader[:183]- F00.00.02 ->pk:F00.00.02|model:2477S|desc:SwitchLinc Switch|features:fastonoff=FastOnOff:lastheardfrom=GenericLastTime:switch=GenericSwitch|groups
2016-08-14 01:09:32 DEBUG o.o.b.i.i.d.DeviceTypeLoader[:183]- F00.00.09 ->pk:F00.00.09|model:2458-A1|desc:MorningLinc RF Lock Controller|features:switch=GenericSwitch|groups
2016-08-14 01:09:32 DEBUG o.o.b.i.i.d.DeviceTypeLoader[:183]- F00.00.08 ->pk:F00.00.08|model:2452-222|desc:DIN Rail Dimmer|features:fastonoff=FastOnOff:lastheardfrom=GenericLastTime:manualchange=ManualChange:dimmer=GenericDimmer|groups
2016-08-14 01:09:32 DEBUG o.o.b.i.i.d.DeviceTypeLoader[:183]- F00.00.07 ->pk:F00.00.07|model:2453-222|desc:DIN Rail On/Off|features:lastheardfrom=GenericLastTime:switch=GenericSwitch|groups
2016-08-14 01:09:32 DEBUG o.o.b.i.i.d.DeviceTypeLoader[:183]- F00.00.06 ->pk:F00.00.06|model:2442-222|desc:Micro Dimmer|features:fastonoff=FastOnOff:lastheardfrom=GenericLastTime:manualchange=ManualChange:dimmer=GenericDimmer|groups
2016-08-14 01:09:32 DEBUG o.o.b.i.i.d.DeviceTypeLoader[:183]- 0x000051 ->pk:0x000051|model:2486DWH8|desc:KeypadLinc Dimmer - 8 Button|features:loaddimmer=LoadDimmerButton:fastonoff=LoadDimmerFastOnOff:keypadbuttonD=KeyPadButton4:keypadbuttonE=KeyPadButton5:keypadbuttonB=KeyPadButton2:keypadbuttonC=KeyPadButton3:keypadbuttonH=KeyPadButton8:lastheardfrom=GenericLastTime:keypadbuttonF=KeyPadButton6:keypadbuttonG=KeyPadButton7:manualchange=ManualChange:rampdimmer=LoadDimmerRamp|groups:button_group=keypadbuttonB,keypadbuttonC,keypadbuttonD,keypadbuttonE,keypadbuttonF,keypadbuttonG,keypadbuttonH
2016-08-14 01:09:32 DEBUG o.o.b.i.i.d.DeviceTypeLoader[:183]- 0x000050 ->pk:0x000050|model:2486DWH6|desc:KeypadLinc Dimmer - 6 Button|features:loaddimmer=LoadDimmerButton:fastonoff=LoadDimmerFastOnOff:keypadbuttonA=KeyPadButton3:keypadbuttonD=KeyPadButton6:keypadbuttonB=KeyPadButton4:keypadbuttonC=KeyPadButton5:lastheardfrom=GenericLastTime:manualchange=ManualChange:rampdimmer=LoadDimmerRamp|groups:button_group=keypadbuttonA,keypadbuttonB,keypadbuttonC,keypadbuttonD
2016-08-14 01:09:32 DEBUG o.o.b.i.i.d.DeviceTypeLoader[:183]- F00.00.1B ->pk:F00.00.1B|model:2635-222|desc:On/Off Module|features:lastheardfrom=GenericLastTime:switch=GenericSwitch|groups
2016-08-14 01:09:32 DEBUG o.o.b.i.i.d.DeviceTypeLoader[:183]- F00.00.1A ->pk:F00.00.1A|model:2475SDB|desc:In-LineLinc Relay|features:lastheardfrom=GenericLastTime:switch=GenericSwitch|groups
2016-08-14 01:09:32 DEBUG o.o.b.i.i.d.DeviceTypeLoader[:183]- F00.00.1F ->pk:F00.00.1F|model:2477SA1|desc:220V 30-amp Load Controller N/O|features:fastonoff=FastOnOff:lastheardfrom=GenericLastTime:switch=GenericSwitch|groups
2016-08-14 01:09:32 DEBUG o.o.b.i.i.d.DeviceTypeLoader[:183]- 0x000039 ->pk:0x000039|model:2663-222|desc:On/Off Outlet|features:bottomoutlet=BottomOutlet:lastheardfrom=GenericLastTime:topoutlet=GenericSwitch|groups
2016-08-14 01:09:32 DEBUG o.o.b.i.i.d.DeviceTypeLoader[:183]- F00.00.1E ->pk:F00.00.1E|model:2674-222|desc:LED Bulb (recessed)|features:fastonoff=FastOnOff:lastheardfrom=GenericLastTime:manualchange=ManualChange:dimmer=GenericDimmer:rampdimmer=RampDimmer|groups
2016-08-14 01:09:32 DEBUG o.o.b.i.i.d.DeviceTypeLoader[:183]- F00.00.1D ->pk:F00.00.1D|model:2456S3|desc:ApplianceLinc|features:lastheardfrom=GenericLastTime:switch=GenericSwitch|groups
2016-08-14 01:09:32 DEBUG o.o.b.i.i.d.DeviceTypeLoader[:183]- 0x000037 ->pk:0x000037|model:2486D|desc:KeypadLinc Dimmer|features:fastonoff=FastOnOff:lastheardfrom=GenericLastTime:manualchange=ManualChange:dimmer=GenericDimmer|groups
2016-08-14 01:09:32 DEBUG o.o.b.i.i.d.DeviceTypeLoader[:183]- F00.00.1C ->pk:F00.00.1C|model:2475F|desc:FanLinc Module|features:fan=FanLincFan:lightdimmer=GenericDimmer:lastheardfrom=GenericLastTime|groups
2016-08-14 01:09:32 DEBUG o.o.b.i.i.d.DeviceTypeLoader[:183]- F00.00.12 ->pk:F00.00.12|model:2466S|desc:ToggleLinc Switch|features:lastheardfrom=GenericLastTime:switch=GenericSwitch|groups
2016-08-14 01:09:32 DEBUG o.o.b.i.i.d.DeviceTypeLoader[:183]- F00.00.11 ->pk:F00.00.11|model:2466D|desc:ToggleLinc Dimmer|features:fastonoff=FastOnOff:lastheardfrom=GenericLastTime:manualchange=ManualChange:dimmer=GenericDimmer:rampdimmer=RampDimmer|groups
2016-08-14 01:09:32 DEBUG o.o.b.i.i.d.DeviceTypeLoader[:183]- F00.00.10 ->pk:F00.00.10|model:2342-2|desc:Mini Remote|features:buttonD=RemoteButtonD:buttonB=RemoteButtonB:buttonC=RemoteButtonC:lastheardfrom=GenericLastTime:buttonA=RemoteButtonA|groups
2016-08-14 01:09:32 DEBUG o.o.b.i.i.d.DeviceTypeLoader[:183]- X00.00.03 ->pk:X00.00.03|model:X10 motion sensor|desc:Generic X10 motion sensor|features:contact=X10Contact|groups
2016-08-14 01:09:32 DEBUG o.o.b.i.i.d.DeviceTypeLoader[:183]- F00.00.16 ->pk:F00.00.16|model:2334-232|desc:Keypad Dimmer Switch, 8-Button |features:loaddimmer=LoadDimmerButton:fastonoff=LoadDimmerFastOnOff:keypadbuttonD=KeyPadButton4:keypadbuttonE=KeyPadButton5:keypadbuttonB=KeyPadButton2:keypadbuttonC=KeyPadButton3:keypadbuttonH=KeyPadButton8:lastheardfrom=GenericLastTime:keypadbuttonF=KeyPadButton6:keypadbuttonG=KeyPadButton7:manualchange=ManualChange:rampdimmer=LoadDimmerRamp|groups:button_group=keypadbuttonB,keypadbuttonC,keypadbuttonD,keypadbuttonE,keypadbuttonF,keypadbuttonG,keypadbuttonH
2016-08-14 01:09:32 DEBUG o.o.b.i.i.d.DeviceTypeLoader[:183]- X00.00.02 ->pk:X00.00.02|model:X10 dimmer|desc:Generic X10 Dimmer without preset|features:dimmer=X10Dimmer:switch=X10Switch|groups
2016-08-14 01:09:32 DEBUG o.o.b.i.i.d.DeviceTypeLoader[:183]- F00.00.15 ->pk:F00.00.15|model:2334-232|desc:Keypad Dimmer Switch, 6-Button |features:loaddimmer=LoadDimmerButton:fastonoff=LoadDimmerFastOnOff:keypadbuttonA=KeyPadButton3:keypadbuttonD=KeyPadButton6:keypadbuttonB=KeyPadButton4:keypadbuttonC=KeyPadButton5:lastheardfrom=GenericLastTime:manualchange=ManualChange:rampdimmer=LoadDimmerRamp|groups:button_group=keypadbuttonA,keypadbuttonB,keypadbuttonC,keypadbuttonD
2016-08-14 01:09:32 DEBUG o.o.b.i.i.d.DeviceTypeLoader[:183]- X00.00.01 ->pk:X00.00.01|model:X10 switch|desc:any simple X10 switch|features:switch=X10Switch|groups
2016-08-14 01:09:32 DEBUG o.o.b.i.i.d.DeviceTypeLoader[:183]- F00.00.14 ->pk:F00.00.14|model:2487S|desc:KeypadLinc On/Off 6-Button Scene Control |features:keypadbuttonA=KeyPadButton3:manualchangebuttonD=ManualChangeButton6:keypadbuttonD=KeyPadButton6:manualchangebuttonA=ManualChangeButton3:keypadbuttonB=KeyPadButton4:manualchangebuttonC=ManualChangeButton5:keypadbuttonC=KeyPadButton5:manualchangebuttonB=ManualChangeButton4:loadswitchmanualchange=LoadSwitchManualChange:loadswitchfastonoff=LoadSwitchFastOnOff:fastonoffbuttonB=FastOnOffButton4:fastonoffbuttonC=FastOnOffButton5:lastheardfrom=GenericLastTime:fastonoffbuttonD=FastOnOffButton6:loadswitch=LoadSwitchButton:fastonoffbuttonA=FastOnOffButton3|groups:manualchange_button_group=manualchangebuttonA,manualchangebuttonB,manualchangebuttonC,manualchangebuttonD:fastonoff_button_group=fastonoffbuttonA,fastonoffbuttonB,fastonoffbuttonC,fastonoffbuttonD:button_group=keypadbuttonA,keypadbuttonB,keypadbuttonC,keypadbuttonD
2016-08-14 01:09:32 DEBUG o.o.b.i.i.d.DeviceTypeLoader[:183]- F00.00.13 ->pk:F00.00.13|model:2672-222|desc:LED Bulb|features:fastonoff=FastOnOff:lastheardfrom=GenericLastTime:manualchange=ManualChange:dimmer=GenericDimmer:rampdimmer=RampDimmer_3435|groups
2016-08-14 01:09:32 DEBUG o.o.b.i.i.d.DeviceTypeLoader[:183]- F00.00.19 ->pk:F00.00.19|model:2457D2|desc:LampLinc Dimmer|features:fastonoff=FastOnOff:lastheardfrom=GenericLastTime:manualchange=ManualChange:dimmer=GenericDimmer|groups
2016-08-14 01:09:32 DEBUG o.o.b.i.i.d.DeviceTypeLoader[:183]- F00.00.18 ->pk:F00.00.18|model:2441TH|desc:Insteon Thermostat|features:tempcelsius=ThermostatTemperatureCelsius:humidityhigh=ThermostatHumidityHigh:tempfahrenheit=ThermostatTemperatureFahrenheit:stage1duration=ThermostatStage1Duration:humiditylow=ThermostatHumidityLow:systemmode=ThermostatSystemMode:isheating=ThermostatIsHeating:fanmode=ThermostatFanMode:iscooling=ThermostatIsCooling:heatsetpoint=ThermostatHeatSetPoint:coolsetpoint=ThermostatCoolSetPoint:humidity=ThermostatHumidity:lastheardfrom=GenericLastTime:acdelay=ThermostatACDelay:backlightduration=ThermostatBackLightDuration|groups:data1b_group=humidityhigh,humiditylow,stage1duration:data2_group=coolsetpoint,heatsetpoint,systemmode,fanmode,isheating,iscooling,tempcelsius,tempfahrenheit,humidity:data1_group=backlightduration,acdelay
2016-08-14 01:09:32 DEBUG o.o.b.i.i.d.DeviceTypeLoader[:183]- 0x00001A ->pk:0x00001A|model:2450|desc:IO Link|features:contact=IOLincContact:lastheardfrom=GenericLastTime:switch=IOLincSwitch|groups
2016-08-14 01:09:32 DEBUG o.o.b.i.i.d.DeviceTypeLoader[:183]- F00.00.17 ->pk:F00.00.17|model:2423A1|desc:iMeter Solo Power Meter|features:meter=PowerMeter:lastheardfrom=GenericLastTime|groups
2016-08-14 01:09:32 DEBUG o.o.b.i.InsteonPLMActiveBinding[:215]- item Light_Dinette_Fast binding changed: addr=3C.FC.53|prodKey:F00.00.01|feature:fastonoff
2016-08-14 01:09:32 DEBUG o.o.b.i.InsteonPLMActiveBinding[:215]- item Light_KitchenSink binding changed: addr=32.A6.CA|prodKey:F00.00.02|feature:switch
2016-08-14 01:09:32 DEBUG o.o.b.i.InsteonPLMActiveBinding[:215]- item Light_EntranceKeypadMain binding changed: addr=3D.8F.F8|prodKey:F00.00.14|feature:loadswitch
2016-08-14 01:09:32 DEBUG o.o.b.i.i.device.InsteonDevice[:544]- manualchange_button_group connected feature: ManualChangeButton3(0:1:2)
2016-08-14 01:09:32 DEBUG o.o.b.i.i.device.InsteonDevice[:544]- manualchange_button_group connected feature: ManualChangeButton4(0:1:2)
2016-08-14 01:09:32 DEBUG o.o.b.i.i.device.InsteonDevice[:544]- manualchange_button_group connected feature: ManualChangeButton5(0:1:2)
2016-08-14 01:09:32 DEBUG o.o.b.i.i.device.InsteonDevice[:544]- manualchange_button_group connected feature: ManualChangeButton6(0:1:2)
2016-08-14 01:09:32 DEBUG o.o.b.i.i.device.InsteonDevice[:544]- fastonoff_button_group connected feature: FastOnOffButton3(0:1:2)
2016-08-14 01:09:32 DEBUG o.o.b.i.i.device.InsteonDevice[:544]- fastonoff_button_group connected feature: FastOnOffButton4(0:1:2)
2016-08-14 01:09:32 DEBUG o.o.b.i.i.device.InsteonDevice[:544]- fastonoff_button_group connected feature: FastOnOffButton5(0:1:2)
2016-08-14 01:09:32 DEBUG o.o.b.i.i.device.InsteonDevice[:544]- fastonoff_button_group connected feature: FastOnOffButton6(0:1:2)
2016-08-14 01:09:32 DEBUG o.o.b.i.i.device.InsteonDevice[:544]- button_group connected feature: KeyPadButton3(0:1:6)
2016-08-14 01:09:32 DEBUG o.o.b.i.i.device.InsteonDevice[:544]- button_group connected feature: KeyPadButton4(0:1:6)
2016-08-14 01:09:32 DEBUG o.o.b.i.i.device.InsteonDevice[:544]- button_group connected feature: KeyPadButton5(0:1:6)
2016-08-14 01:09:32 DEBUG o.o.b.i.i.device.InsteonDevice[:544]- button_group connected feature: KeyPadButton6(0:1:6)
2016-08-14 01:09:32 DEBUG o.o.b.i.InsteonPLMActiveBinding[:215]- item Light_EntranceKeypadHome binding changed: addr=3D.8F.F8|prodKey:F00.00.15|feature:keypadbuttonA|params:group=7
2016-08-14 01:09:32 DEBUG o.o.b.i.InsteonPLMActiveBinding[:215]- item Light_EntranceKeypadNight binding changed: addr=3D.8F.F8|prodKey:F00.00.15|feature:keypadbuttonB|params:related=32.9B.02,group=8
2016-08-14 01:09:32 DEBUG o.o.b.i.InsteonPLMActiveBinding[:215]- item Light_LivingRoom binding changed: addr=3D.8F.F8|prodKey:F00.00.15|feature:keypadbuttonD|params:related=38.93.62+35.23.A9,group=4
2016-08-14 01:09:32 DEBUG o.o.b.i.InsteonPLMActiveBinding[:215]- item Light_LivingRoomLamps binding changed: addr=35.23.A9|prodKey:F00.00.01|feature:dimmer|params:related=38.93.62+3D.8F.F8
2016-08-14 01:09:32 DEBUG o.o.b.i.InsteonPLMActiveBinding[:215]- item Light_LivingRoomSwitch binding changed: addr=38.93.62|prodKey:F00.00.01|feature:dimmer|params:related=35.23.A9+3D.8F.F8
2016-08-14 01:09:32 DEBUG o.o.b.i.InsteonPLMActiveBinding[:215]- item Light_UpstairsHall binding changed: addr=32.9B.02|prodKey:F00.00.02|feature:switch
2016-08-14 01:09:32 DEBUG o.o.b.i.InsteonPLMActiveBinding[:215]- item Light_BA_Hallway2 binding changed: addr=3D.39.FE|prodKey:F00.00.02|feature:switch
2016-08-14 01:09:32 DEBUG o.o.b.i.InsteonPLMActiveBinding[:215]- item Light_BA_Hallway2_Fast binding changed: addr=3D.39.FE|prodKey:F00.00.02|feature:fastonoff
2016-08-14 01:09:32 DEBUG o.o.b.i.InsteonPLMActiveBinding[:215]- item GarageDoorOpener binding changed: addr=3D.8F.F8|prodKey:F00.00.15|feature:keypadbuttonC|params:group=10
2016-08-14 01:09:32 DEBUG o.o.b.i.InsteonPLMActiveBinding[:215]- item GarageDoorContact binding changed: addr=34.89.34|prodKey: 0x00001A|feature:contact
2016-08-14 01:09:32 DEBUG o.o.b.i.InsteonPLMActiveBinding[:215]- item PoolPump binding changed: addr=2E.8B.AF|prodKey:F00.00.02|feature:switch
2016-08-14 01:09:32 DEBUG o.o.b.i.InsteonPLMActiveBinding[:215]- item PoolLights binding changed: addr=3D.25.74|prodKey:F00.00.02|feature:switch
2016-08-14 01:11:31 WARN o.o.b.i.i.d.ModemDBBuilder[:76]- modem database download unsuccessful, restarting!
2016-08-14 01:11:31 DEBUG o.o.b.i.internal.driver.Port[:139]- clearing modem db!
I’m never able to get a connection to the hub, once I put back the 1.8.3 binding everything is fine.
