Hi All,
I am new to openHAB but not new to home automation.
Currently trying to get openHAB working with my Insteon Hub (2242-522 R) and running into some issues. I have added the Insteon PLM Binding to my addons folder and have updated my config file but I cannot determine if the binding is reading the state of my sensors which are linked to my hub.
I have a feeling I may not have updated my config file correctly.
The only line I have changed in the config file is this:
insteonplm:port_0=/hub2/XXXXX:XXXXXX@myinsteonhub.mydomain:25105,poll_time=1000
In which I have put in my username and password for the hub and uncommented the line. Do I need to change the myinsteonhub.mydomain part also? If so where can I locate the hub name and domain name?
Items I have included so far:
/Living Room Transducers/
Contact FrontDoorState “Front Door State [MAP(contact.map):%s]” (LivingRoom, Transducers) {insteonplm=“14.B3.2E:0x000049#contact”}
Contact MotionSensor “Motion Sensor [MAP(contact.map):%s]” {insteonplm=“21.DA.07:0x00004A#contact”}
Number MotionSensorBatteryLevel “Motion Sensor Battery Level [%.1f]” {insteonplm=“21.DA.07:0x00004A#data,field=battery_level”}
Number MotionSensorLightLevel “Motion Sensor Light Level [%.1f]” {insteonplm=“21.DA.07:0x00004A#data,field=light_level”}
Many thanks.
Simon
