Hi
I’m a newbie to openHAB 3.2.0 so please forgive the dumb questions.
I’m trying to drive an Insteon switch model 2633-522 via an Insteon
hub 2242-5222, PLM version 9D on a Windows 10 PC.
First I execute this command in cmd
C:\Program Files\openhab\start.bat
I’ve created an Insteon Network Thing with
/hub2/:@192.168.1.101:25105,poll_time=300
and it shows green ‘online’
I’ve also created an Insteon Device Thing which is a switch model
2635-522 (there is no device 2633-522 available in the dropdown menu
so I’m guessing this will do) and it too shows green online.
Then I have linked the switch via a channel and its code reads
label: Insteon Device
thingTypeUID: insteon:device
configuration:
productKey: F00.00.1B
address: 47.70.BD
bridgeUID: insteon:network:610433d870
Then I have created an InsteonDevice_Switch Item and the Channel link
shows green an online
However, the device does not respond to the on/off switch in the Item
panel.
LOGS:
2022-05-23 16:06:05.920 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘insteon:network:3bf5c5014b’ changed from UNKNOWN to OFFLINE (CONFIGURATION_ERROR): Initialization failed, unable to start the Insteon bridge with the port ‘/hub2/elhay:14736251@192.168.1.112:25105,poll_time=300’.
2022-05-26 19:49:43.132 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘insteon:network:3bf5c5014b’ changed from OFFLINE (CONFIGURATION_ERROR): Initialization failed, unable to start the Insteon bridge with the port ‘/hub2/elhay:14736251@192.168.1.112:25105,poll_time=300’. to REMOVING
2022-05-26 19:49:43.135 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘insteon:network:3bf5c5014b’ changed from REMOVING to REMOVED
2022-05-26 19:49:43.136 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘insteon:network:3bf5c5014b’ changed from REMOVED to UNINITIALIZED
2022-05-26 19:49:43.144 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘insteon:network:3bf5c5014b’ changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2022-05-26 19:51:23.407 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘insteon:network:610433d870’ changed from UNINITIALIZED to INITIALIZING
2022-05-26 19:51:23.410 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘insteon:network:610433d870’ changed from INITIALIZING to UNKNOWN
2022-05-26 19:51:28.481 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘insteon:network:610433d870’ changed from UNKNOWN to ONLINE
2022-05-26 19:59:30.485 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘insteon:device:610433d870:3599cd1ef6’ changed from UNINITIALIZED to INITIALIZING
2022-05-26 19:59:30.528 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘insteon:device:610433d870:3599cd1ef6’ changed from INITIALIZING to ONLINE
2022-05-26 20:03:19.315 [INFO ] [openhab.event.ItemCommandEvent ] - Item ‘InsteonDevice_Switch’ received command ON
2022-05-26 20:03:19.323 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item ‘InsteonDevice_Switch’ predicted to become ON
2022-05-26 20:03:19.330 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘InsteonDevice_Switch’ changed from NULL to ON
2022-05-26 20:03:24.974 [INFO ] [openhab.event.ItemCommandEvent ] - Item ‘InsteonDevice_Switch’ received command OFF
2022-05-26 20:03:24.975 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item ‘InsteonDevice_Switch’ predicted to become OFF
2022-05-26 20:03:24.977 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘InsteonDevice_Switch’ changed from ON to OFF
2022-05-26 20:03:35.806 [INFO ] [openhab.event.ItemCommandEvent ] - Item ‘InsteonDevice_Switch’ received command ON
2022-05-26 20:03:35.807 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item ‘InsteonDevice_Switch’ predicted to become ON
2022-05-26 20:03:35.809 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘InsteonDevice_Switch’ changed from OFF to ON
2022-05-26 20:03:37.456 [INFO ] [openhab.event.ItemCommandEvent ] - Item ‘InsteonDevice_Switch’ received command OFF
2022-05-26 20:03:37.457 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item ‘InsteonDevice_Switch’ predicted to become OFF
2022-05-26 20:03:37.458 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘InsteonDevice_Switch’ changed from ON to OFF
2022-05-26 20:53:38.878 [INFO ] [openhab.event.ItemCommandEvent ] - Item ‘InsteonDevice_Switch’ received command ON
2022-05-26 20:53:38.880 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item ‘InsteonDevice_Switch’ predicted to become ON
2022-05-26 20:53:38.882 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘InsteonDevice_Switch’ changed from OFF to ON
2022-05-26 20:53:41.383 [INFO ] [openhab.event.ItemCommandEvent ] - Item ‘InsteonDevice_Switch’ received command OFF
2022-05-26 20:53:41.384 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item ‘InsteonDevice_Switch’ predicted to become OFF
2022-05-26 20:53:41.386 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘InsteonDevice_Switch’ changed from ON to OFF
2022-05-26 20:57:56.771 [INFO ] [openhab.event.ItemCommandEvent ] - Item ‘InsteonDevice_Switch’ received command ON
2022-05-26 20:57:56.773 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item ‘InsteonDevice_Switch’ predicted to become ON
2022-05-26 20:57:56.774 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘InsteonDevice_Switch’ changed from OFF to ON
2022-05-26 20:57:58.278 [INFO ] [openhab.event.ItemCommandEvent ] - Item ‘InsteonDevice_Switch’ received command OFF
2022-05-26 20:57:58.279 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item ‘InsteonDevice_Switch’ predicted to become OFF
2022-05-26 20:57:58.280 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘InsteonDevice_Switch’ changed from ON to OFF
Anyone have any suggestions on how to address this?
Thanks in advance
