insteonPLM not registering fast ON/OFF
I have followed the instructions pretty faithfully for registering a switch as both a standard item, and a ‘fastonoff’ item, but the fastonoff item does not seem to trigger when I double tap on the switch.
Here is the .items
Switch OfficeLight "Office Light" <light> (office) [ "Lighting" ] {insteonplm="1B.41.E8:F00.00.02#switch"}
Switch OfficeLightFastOnOff "Office Light (fast on/off)" <light> {insteonplm="1B.41.E8:F00.00.02#fastonoff"}
I see the following from the logs:
(openhab.log)
2017-01-19 15:13:55.173 [INFO ] [onplm.internal.device.MessageHandler] - LightOnSwitchHandler: device 1B.41.E8 was switched on FAST.
and from events.log
2017-01-19 15:13:55.174 [ItemStateChangedEvent     ] - OfficeLight changed from OFF to ON
I’m using OH1 and i have the folowing:
.items file:
Dimmer bStairsLights2       "Basement Stairs Light 2"             {insteonplm="23.9F.AD:F00.00.11#dimmer,related=22.F8.74"}
Switch bStairsLights2Fast   "Basement Stairs Light 2 Fast On/Off" {insteonplm="23.9F.AD:F00.00.11#fastonoff,related=22.F8.74"}
openhab.log:
2017-01-19 18:47:48.147 [INFO ] [.o.b.i.i.device.MessageHandler] - LightOffSwitchHandler: device 23.9F.AD was switched off FAST.
2017-01-19 18:47:48.151 [INFO ] [.o.b.i.i.device.MessageHandler] - LightOffDimmerHandler: device 23.9F.AD was turned off FAST.
events.log
2017-01-19 18:47:48 - bStairsLights2Fast state updated to OFF
2017-01-19 18:47:48 - bStairsLights2 state updated to OFF
It looks like you are using OH2, the little I played around with OH2, it appears it doesn’t send duplicate events. What happens if you trigger a fast off then try a fast on?
Yes, I’m using OH2
It’s a bit erratic, but the most common scenario when I ‘fast off’ then ‘fast on’ is:
2017-01-19 17:10:22.199 [INFO ] [onplm.internal.device.MessageHandler] - LightOffSwitchHandler: device 1B.41.E8 was switched off FAST.
2017-01-19 17:10:22.200 [ItemStateChangedEvent     ] - OfficeLightFastOnOff changed from ON to OFF
Oddly, when I double tap ‘on’, it was never logged
This looks like some sort of different behavior between OH1 and OH2. If you enabled debug logging of InsteonPLM, this would give more detailed info on what the binding is doing. I have no idea on how to enable debugging with OH2.
How can I enable logging in insteonPLM?
The instructions for OH1 are at Insteon PLM Binding · openhab/openhab1-addons Wiki · GitHub
Logging works differently with OH2.
See
and
http://docs.openhab.org/administration/logging.html
OK, I’ve turned on logging… and WOW is it verbose. Please advise if there is something I should be looking for (wrt FASTON)
Here is the log timestamped from when I hit a double tap on a switch:
2017-01-20 16:38:15 org.openhab.binding.insteonplm.InsteonPLMActiveBinding$PortListener.msg(InsteonPLMActiveBinding.java:591) - got msg: IN:Cmd:0x50|fromAddress:1B.41.E8|toAddress:00.00.01|messageFlags:0xC7=ALL_LINK_BROADCAST:3:1|command1:0x12|command2:0x00|
2017-01-20 16:38:15 org.openhab.binding.insteonplm.internal.device.MessageDispatcher.handleAllLinkMessage(MessageDispatcher.java:75) - all link message: IN:Cmd:0x50|fromAddress:1B.41.E8|toAddress:00.00.01|messageFlags:0xC7=ALL_LINK_BROADCAST:3:1|command1:0x12|command2:0x00|
2017-01-20 16:38:15 org.openhab.binding.insteonplm.internal.device.MessageDispatcher.handleAllLinkMessage(MessageDispatcher.java:77) - all link message is no duplicate: true/true
2017-01-20 16:38:15 org.openhab.binding.insteonplm.internal.device.MessageDispatcher.handleAllLinkMessage(MessageDispatcher.java:79) - 1B.41.E8:FastOnOff->LightOnSwitchHandler cmd1:0x12 group 1/-1:IN:Cmd:0x50|fromAddress:1B.41.E8|toAddress:00.00.01|messageFlags:0xC7=ALL_LINK_BROADCAST:3:1|command1:0x12|command2:0x00|
2017-01-20 16:38:15 org.openhab.binding.insteonplm.internal.device.MessageHandler$LightOnSwitchHandler.handleMessage(MessageHandler.java:406) - LightOnSwitchHandler: device 1B.41.E8 was switched on FAST.
2017-01-20 16:38:15 org.openhab.binding.insteonplm.internal.device.DeviceFeature.publish(DeviceFeature.java:321) - 1B.41.E8:FastOnOff publishing: ON
2017-01-20 16:38:15 org.openhab.binding.insteonplm.internal.device.MessageDispatcher.handleAllLinkMessage(MessageDispatcher.java:79) - 1B.41.E8:GenericSwitch->LightOnSwitchHandler cmd1:0x12 group 1/1:IN:Cmd:0x50|fromAddress:1B.41.E8|toAddress:00.00.01|messageFlags:0xC7=ALL_LINK_BROADCAST:3:1|command1:0x12|command2:0x00|
2017-01-20 16:38:15 org.openhab.binding.insteonplm.internal.device.DeviceFeature.publish(DeviceFeature.java:321) - 1B.41.E8:GenericSwitch publishing: ON
2017-01-20 16:38:15 org.openhab.binding.insteonplm.internal.device.DeviceFeature.publish(DeviceFeature.java:321) - 1B.41.E8:GenericLastTime publishing: 2017-01-20T16:38:15
And, here is the complete ‘events’ log:
2017-01-20 16:38:15.941 [InsteonPLMActiveBinding   ] - got msg: IN:Cmd:0x50|fromAddress:1B.41.E8|toAddress:00.00.01|messageFlags:0xC7=ALL_LINK_BROADCAST:3:1|command1:0x12|command2:0x00|
2017-01-20 16:38:15.942 [MessageDispatcher         ] - all link message: IN:Cmd:0x50|fromAddress:1B.41.E8|toAddress:00.00.01|messageFlags:0xC7=ALL_LINK_BROADCAST:3:1|command1:0x12|command2:0x00|
2017-01-20 16:38:15.942 [MessageDispatcher         ] - all link message is no duplicate: true/true
2017-01-20 16:38:15.942 [MessageDispatcher         ] - 1B.41.E8:FastOnOff->LightOnSwitchHandler cmd1:0x12 group 1/-1:IN:Cmd:0x50|fromAddress:1B.41.E8|toAddress:00.00.01|messageFlags:0xC7=ALL_LINK_BROADCAST:3:1|command1:0x12|command2:0x00|
2017-01-20 16:38:15.942 [MessageHandler            ] - LightOnSwitchHandler: device 1B.41.E8 was switched on FAST.
2017-01-20 16:38:15.942 [DeviceFeature             ] - 1B.41.E8:FastOnOff publishing: ON
2017-01-20 16:38:15.942 [MessageDispatcher         ] - 1B.41.E8:GenericSwitch->LightOnSwitchHandler cmd1:0x12 group 1/1:IN:Cmd:0x50|fromAddress:1B.41.E8|toAddress:00.00.01|messageFlags:0xC7=ALL_LINK_BROADCAST:3:1|command1:0x12|command2:0x00|
2017-01-20 16:38:15.943 [MessageHandler            ] - LightOnSwitchHandler: device 1B.41.E8 was switched on FAST.
2017-01-20 16:38:15.943 [DeviceFeature             ] - 1B.41.E8:GenericSwitch publishing: ON
2017-01-20 16:38:15.943 [DeviceFeature             ] - 1B.41.E8:GenericLastTime publishing: 2017-01-20T16:38:15
2017-01-20 16:38:16.142 [InsteonPLMActiveBinding   ] - got msg: IN:Cmd:0x50|fromAddress:1B.41.E8|toAddress:0F.9D.D9|messageFlags:0x41=ALL_LINK_CLEANUP:1:0|command1:0x12|command2:0x01|
2017-01-20 16:38:16.143 [MessageDispatcher         ] - all link message: IN:Cmd:0x50|fromAddress:1B.41.E8|toAddress:0F.9D.D9|messageFlags:0x41=ALL_LINK_CLEANUP:1:0|command1:0x12|command2:0x01|
2017-01-20 16:38:16.143 [DeviceFeature             ] - 1B.41.E8:GenericLastTime publishing: 2017-01-20T16:38:16
I think I’m making some progress, the problem was my rule file…!!!
I had this:
rule "OfficeFastOn"
	Item OfficeLightFastOnOff received command ON
    logDebug("rulelog", "Office Light FASTON")
When it should have been this:
rule "OfficeFastOn"
	Item OfficeLightFastOnOff received update ON
update, instead of command! Now, it’s not the most reliable atm, but I think that might have to do more with insteon strangeness, than anything else.
Every time you see:
You should see a corresponding event indicating the item OfficeLightFastOnOff is ON. At least that’s how it works with OH1. Maybe you also need to force the state back to OFF in you rule:
    OfficeLightFastOnOff.postUpdate(OFF)
