Thanks for this. I was able to fix my FreeBSD installation with the help of the details in your post.
FreeBSD OPENHAB backup script requires 2 variables.
OPENHAB_USERDATA and OPENHAB_CONF
For sure userdata can be found under /var/db/openhab/userdata .
But is conf to find under /var/db/openhab/userdata/config ? I mean its the same path.
Is there anybody who knows? Thanks a lot.
Do you have a running openhab instance on that OS ?
Then login to the karaf console and do:
env | grep -i openhab
Beside other entries you should see something like ( example output is from a Pi installation ) :
String openhab.conf /etc/openhab
String openhab.userdata /var/lib/openhab
Hallo Wolfgang,
In a fresh FreeBSD Installation the variables are not set.
But I found the path to set:
setenv OPENHAB_USERDATA /var/db/openhab/userdata
setenv OPENHAB_CONF /usr/local/etc/openhab
setenv because Iam using the csh.
With bash it would be
export OPENHAB_USERDATA=/var/db/openhab/userdata
export OPENHAB_CONF=/usr/local/etc/openhab
Then the backup script is running fine.
