Hi!
We are building a new one family house. Roof is on top and windows installed, the electrician is currently doing the wiring. The wires are installed in conventional way, no bus/KNX system or something.
The rollershutters are with Somfy (IO Homecontrol), didn’t research before ordering
. So we have to deal with them. Rollershutters are 17 in total.
Also we have four electric velux roof windows with (velux) electric rollershutter on each roof window.
For each window/rollershutter we have a somfy/velux “remote”/wireless switch.
To get those shutters/windows a bit smart, I want to use openhab with velux KLF200 binding. Too I want to install some additional Homematic switches which should control velux window+rollershutter.
This should be implemented:
- 17x Somfy rollershutter
→ controlled directly by somfy remote
→ binding to openhab via velux klf200 - 4x velux window
→ controlled directly by velux remote
→ binding to openhab via velux klf200 - 4x velux rollershutter
→ binding to openhab via velux klf200 - 4x homematic 2-way push-button
→ binding to openhab via ccu
→ each push-button is mapped to one velux window (open+close) with rollershutter (up+down) with 4 actions: top/bottom + long/short press - openhab
→ controll all roleshutters + roof windows by openhab ui and do some automatic stuff (e.g. close rollershutter at x o’clock…)
Question 1:
Is it possible to setup things like described?
Question 2:
As I understand, the homematic switch/push-button is universal and can be installed with adapter to match the other switch design series (Busch-Jäger, Gira, etc.), right? So it integrates smooth into the design series frame?
Question 3:
The Velux KLF200 has 5 hardware in/out. Those are independent/not needed for the io-homecontrol devices. There are up to 200 or 250 io-homecontrol devices possible to connect.
Right?
Question 4:
Is there something (simple/low-cost additional work) which should be done by the electrician to be prepared for the future?
For example: he should wire the light switches with neutral for cross connection etc.
I have done some researches and think it could be possible but want to be sure before I order (expensive) stuff which will not work as expected. I’m a beginner to home automation and there is so much stuff I don’t understand or do not understand what it stands for…
Thanks!
Achim
