Integrating Valetudo for Robot Vacuum Control
I recently integrated my robot vacuum, which runs on Valetudo, with openHAB and wanted to share my setup in case it’s helpful for others. Valetudo provides a great way to locally control your vacuum without relying on cloud services.
Valetudo offers an official guide for integrating with openHAB: Valetudo openHAB Integration. The integration mainly involves sending commands via MQTT.
While there’s a widget for MainUI I prefer using Sitemaps. Also I want a faster way than “Look at a map” => “Select a room” => “Click on Start”, so I created two Items and a corresponding rule:
  • String Item Robot with mappings for basic commands (Start, Stop, Home) and for each room.
  • Number Item Robot_Wiederholungen for repeated cleans, e.g. two times.
// This rule is triggered, when Robot receives a command.
var roomId = 0
switch (String(event.itemCommand)) {
  case "Stop":
    items.getItem("Robot_Operation").sendCommand("STOP")
    break;
  case "Start":
    items.getItem("Robot_Operation").sendCommand("START")
    break;
  case "Pause":
    items.getItem("Robot_Operation").sendCommand("PAUSE")
    break;
  case "Aufladen":
    items.getItem("Robot_Operation").sendCommand("HOME")
    break;
  case "Wohnzimmer":
    roomId = 2  // To get the ID, select the room in Valetudo, then long-press "CLEAN 1 SEGMENTS" button.
    break;
  case "Schlafzimmer":
    roomId = 8
    break;
if (roomId != 0) {
  val iterations = items.getItem("Robot_Wiederholungen").state
  val roomPayload = {
    "action": "start_segment_action",
    "segment_ids": [
      "${roomId}"
    "iterations": iterations,
    "customOrder": true
  items.getItem("Robot_Clean_segments").sendCommand(JSON.stringify(roomPayload))
Sitemap which also contains the map in case I need it:
Selection item=Robot
Default icon=none item=Robot_Mode label="[]"
Setpoint item=Robot_Wiederholungen
Text icon=none label="Karte" {
	Webview height=20 url="http://<local ip>/#/"
Thank you very much for sharing. Do you have thing-files and item files for text configuration too? Would be great if you can share too. :slight_smile:
