Integration with Olisto
Hi all,
I work as a developer at Olisto (a cloud-based IOT rule engine, comparable to IFTTT, but much more awesome obviously) and purely out if personal interest I would like start a little spare-time project to create an integration for OpenHAB in Olisto. This integration would basically expose the devices in an OpenHAB installation to an Olisto account, much like the integrations for Alexa, Google Assistant and IFTTT do. Users would then be able to use their OpenHAB devices in actions, conditions and triggers in their Olisto rules. This would be available for free to any user of the Olisto app.
Would there be any interest in supporting me in doing this? I would mostly need a set of OAUTH2 credentials for myopenhab. @digitaldan, I’ve seen your name being mentioned in that context?
Also, any pointers to existence of something like webhooks or websockets for real-time event notifications would be appreciated, but if there’s no such thing I can probably make do with the eventstream endpoints used by the web UIs.
Sounds interesting. I can’t help but can wish you good luck!
In the mean time I’ve been working on this a bit and it works quite well. Apart from some fine-tuning the major part missing now is authentication. If anybody is interested, you can try it out by installing the Olisto app, creating an account. Since this is an experimental channel, it is not publicly available. To get access to it, log-in on this page with your Olisto account: https://connect.olisto.com/api/v0/user/superpowers/gyURNRXH3gFKAU8
After that, log out of- and back into the Olisto app. You should see OpenHAB in the channels list. Since OAUTH2 has not yet been made available to me, I’ve implemented a hacky login screen for now. You can either enter your myopenhab credentials or copy-paste a session cookie from an established myopenhab.com session. I’d go with the later option.
Be aware that this is very much in Beta. As long as it’s not officially released, stuff will change and therefore triggs you create with this may break.
@digitaldan it would be awesome if you could provide me with OAUTH credentials, so that I can stop asking people for stuff I don’t want to be asking them for :wink:
This is great. Especially since the Room API isn’t working anymore.
I logged in via the link but don’t see the channel in the app.
Should I do anything else ?
After logging in at the link, did you log out- and back in to the Olisto app (through the more → account tab)?
EDIT: channel found. What should I do at the openhab end?
Semi off topic, kudos voor Triggi op zich :smirking_face:
Update, got it working but sometimes don’t see the openHAB channel in Olisto. Is there anyway of getting the triggs in openHAB? With Logitech Harmony I can control the scenes in the remote.
Also, I am not a programmer but am enthousiast and willing to help/test functionality.
@danielr Again kudos for this and Olisto itself. In my opinion more user friendly than IFTTT :ok_hand:t3:
Hi @Michael117, thanks for the kudo’s!
You shouldn’t need to do anything special on the OpenHAB side. Once connected all the configured ‘Things’ that are dimmers, switches, color controls, contact sensors, generic numeric or text settings, temperature settings or illuminance sensors should show up and you should be able to use them in your actions/conditions. There is no way to see your triggs within OpenHAB.
Okay, cool. Will work with it. Thanks again !
Hi, I came across this topic, as Olisto could solve some off my probs.
I could active OpenHAB in Olisto, but I don’t see any items. Is this related to the fact, that myopenhab does not exposes the status of items any longer?
