Lomex
(Thomas Bachhofer)
January 13, 2025, 12:37pm
1
Hello community.
In the past, I liked to insert SVGs as a floor plan in HABPanel. Now (openhab 4.3.0) this is also possible in the MainUI without HABPanel. Interaction is also possible, e.g. displaying the lamp status by changing the color or switching it on and off.
But I can’t change the text in an SVG text object (displaying a temperature or as in my example below: The set brightness of the LED strip in front of the garage door).
My path:
I have given a text object the attribute “openhab=true” in Inkscape and added a state item to the object in Openhab. The code for this looks like this:
text4647-9-6-3-6:
action: toggle
actionCommand: ON
actionCommandAlt: OFF
stateAsOpacity: false
stateItems:
- DMX_Dimmer_Garagentor_Brightness
useProxyElementForState: false
useDisplayState: false
But nothing happend.
I have read this procedure carefully: [Fixed Layout Pages | openHAB ]
I also saw the post of Stefan Höhn [Interactive SVG Backgrounds / Dialog is not appearing - #20 by stefan.hoehn ] with his YAML-example. It says:
aussentemperatur_text:
action: toggle
actionCommand: ON
useDisplayState: true
Why is there no link to a state item? And why is this working?
What am I doing wrong?
Best regards
Thomas
The reason it is not working because there was something missing that I uploaded - sorry:
This is the right setting:
action: toggle
actionCommand: ON
stateItems:
- garten_temperature
You need to configure the item via the state item:
btw, I also updated the post of the link that you referred to.
and I’d loved to see what you are creating with it
Lomex
(Thomas Bachhofer)
January 13, 2025, 2:25pm
3
Yes, I understand.
In my code, I also selected a state item. The only difference is:
But that shouldn’t be relevant.
From line 523 is the code for the text object (or try to find “text4647-9-6-3-6:”). Maybe this helps to find my mistake:
label: Grundriss Alle
sidebar: true
layoutType: fixed
fixedType: canvas
screenWidth: 400
screenHeight: 1700
imageUrl: /static/floorplans/s_all.svg
embedSvg: true
embedSvgFlashing: true
embeddedSvgActions:
rect2269-5-5:
actionCommand: ON
stateItems:
- KNX_Heizaktor_H2_Status_Stellwert_OG_West
stateOnColor: "#ffe5e5"
rect2269-5-5-2:
actionCommand: ON
stateItems:
- KNX_Heizaktor_H2_Status_Stellwert_OG_Sud
rect2269-5-5-2-8:
actionCommand: ON
stateItems:
- KNX_Heizaktor_H2_Status_Stellwert_OG_Ost
rect2269-5-5-2-8-5:
actionCommand: ON
stateItems:
- KNX_Heizaktor_H2_Status_Stellwert_OG_Treppenhaus
rect2269-5-9-8:
actionCommand: ON
stateItems:
- KNX_Heizaktor_H2_Status_Stellwert_OG_Bad
rect2269-5-9:
actionCommand: ON
stateItems:
rect2269-5-5-2-8-5-7:
actionCommand: ON
stateItems:
- KNX_Heizaktor_H2_Status_Stellwert_OG_Flur
rect2269-5-5-2-8-5-7-5:
actionCommand: ON
stateItems:
rect2269-63:
actionCommand: ON
stateItems:
- KNX_Heizaktor_H1_Status_Stellwert_Schlafen_EG
rect2269-1-1-8:
actionCommand: ON
stateItems:
- KNX_Heizaktor_H1_Status_Stellwert_Wohnen
rect2269-1-1-8-4:
actionCommand: ON
stateItems:
- KNX_Heizaktor_H1_Status_Stellwert_Essen
rect2269-1-1-8-4-4:
actionCommand: ON
stateItems:
- KNX_Heizaktor_H1_Status_Stellwert_Kueche
rect2269-1-1-8-4-4-5:
actionCommand: ON
stateItems:
- KNX_Heizaktor_H1_Status_Stellwert_Treppenhaus
rect2269-1-1-8-4-4-5-7:
actionCommand: ON
stateItems:
- KNX_Heizaktor_H1_Status_Stellwert_Schleuse
rect2269-1-1:
actionCommand: ON
stateItems:
- KNX_Heizaktor_H1_Status_Stellwert_WC
rect2269-1:
actionCommand: ON
stateItems:
- KNX_Heizaktor_H1_Status_Stellwert_Bad_EG
rect2269:
actionCommand: ON
stateItems:
- KNX_Heizaktor_H2_Status_Stellwert_OG_Schlafen
g58648-6:
action: toggle
actionCommand: ON
actionItem: KNX_Schaltaktor_A3_Deckenlicht_Bad_OG
stateItems:
- KNX_Schaltaktor_A3_Deckenlicht_Bad_OG
stateOnColor: "#ffff00"
stateOffColor: "#000000"
path1053-0-7-9-8-6:
action: toggle
actionCommand: ON
g58648-6-6:
action: toggle
actionCommand: ON
actionItem: KNX_Schaltaktor_A3_Deckenlicht_Abstellraum_OG
stateItems:
- KNX_Schaltaktor_A3_Deckenlicht_Abstellraum_OG
path1053-0-7-9-8-6-2:
action: toggle
actionCommand: ON
stateItems:
g58648:
action: toggle
actionCommand: ON
path1053-9-5-2:
action: toggle
actionCommand: ON
actionItem: KNX_Schaltaktor_A3_Beleuchtung_Fassade_Sud_Balkon
stateItems:
- KNX_Schaltaktor_A3_Beleuchtung_Fassade_Sud_Balkon
g1675-68:
action: toggle
actionCommand: ON
stateItems:
path1053-9-5-9-8-7:
action: toggle
actionCommand: ON
actionItem: KNX_Schaltaktor_A3_Stromversorgung_Balkon
g58648-0:
action: toggle
actionCommand: ON
actionItem: KNX_Schaltaktor_A1_Deckenlicht_Buro
stateItems:
- KNX_Schaltaktor_A1_Deckenlicht_Buro
path1053-2:
action: toggle
actionCommand: ON
g58648-1:
action: toggle
actionCommand: ON
actionItem: KNX_Schaltaktor_A1_Deckenlicht_Heizung
stateItems:
- KNX_Schaltaktor_A1_Deckenlicht_Heizung
path1053-9-5-2-6-4-5-3-8:
action: toggle
actionCommand: ON
g58648-1-1:
action: toggle
actionCommand: ON
actionItem: KNX_Schaltaktor_A1_Deckenlicht_Technik_Elektro
stateItems:
- KNX_Schaltaktor_A1_Deckenlicht_Technik_Elektro
path1053-9-5-2-6-4-5-3:
action: toggle
actionCommand: ON
path1053-9-5-2-6-4-5:
action: toggle
actionCommand: ON
actionItem: KNX_Schaltaktor_A1_Deckenlicht_Flur_UG
g58648-1-1-0:
action: toggle
actionCommand: ON
stateItems:
- KNX_Schaltaktor_A1_Deckenlicht_Flur_UG
path1053-9-5-2-6-4:
action: toggle
actionCommand: ON
actionItem: KNX_Schaltaktor_A1_Deckenlicht_Treppenhaus_UG
g58648-1-1-0-3:
action: toggle
actionCommand: ON
stateItems:
- KNX_Schaltaktor_A1_Deckenlicht_Treppenhaus_UG
path1053-9:
action: toggle
actionCommand: ON
actionItem: KNX_Schaltaktor_A1_Deckenlicht_Lager
g58648-1-1-0-3-7-9-9-4:
action: toggle
actionCommand: ON
stateItems:
- KNX_Schaltaktor_A1_Deckenlicht_Lager
path1053-9-5:
action: toggle
actionCommand: ON
actionItem: KNX_Schaltaktor_A1_Deckenlicht_Waschkuche
g58648-1-1-0-3-7-9-9:
action: toggle
actionCommand: ON
stateItems:
- KNX_Schaltaktor_A1_Deckenlicht_Waschkuche
path1053-9-5-2-0:
action: toggle
actionCommand: ON
actionItem: KNX_Schaltaktor_A1_Deckenlicht_Vorratskammer
g58648-1-1-0-3-7-9:
action: toggle
actionCommand: ON
stateItems:
- KNX_Schaltaktor_A1_Deckenlicht_Vorratskammer
path1053-9-5-2-6:
action: toggle
actionCommand: ON
actionItem: KNX_Schaltaktor_A1_Deckenlicht_Kellerraum
g58648-1-1-0-3-7:
action: toggle
actionCommand: ON
stateItems:
- KNX_Schaltaktor_A1_Deckenlicht_Kellerraum
g1006-3:
action: toggle
actionCommand: ON
actionItem: KNX_Schaltaktor_A2_Deckenlicht_Terrasse
stateItems:
- KNX_Schaltaktor_A2_Deckenlicht_Terrasse
path1053-9-5-2-2:
action: toggle
actionCommand: ON
path1053-9-5-9-8:
action: toggle
actionCommand: ON
actionItem: KNX_Schaltaktor_A2_Stromversorgung_Terrasse
g1220-80:
action: toggle
actionCommand: ON
stateItems:
- KNX_Schaltaktor_A2_Stromversorgung_Terrasse
stateOnColor: "#ff0000"
path1053-9-5-9-9:
action: toggle
actionCommand: ON
actionItem: KNX_Schaltaktor_A2_Fassadenbeleuchtung_Ost
g1675-6-0:
action: toggle
actionCommand: ON
stateItems:
- KNX_Schaltaktor_A2_Fassadenbeleuchtung_Ost
path1053-9-5-9-1-4:
action: toggle
actionCommand: ON
actionItem: KNX_Schaltaktor_A2_Deckenlicht_Mulleimer
g1006:
action: toggle
actionCommand: ON
stateItems:
- KNX_Schaltaktor_A2_Deckenlicht_Mulleimer
g58648-6-6-2:
action: toggle
actionCommand: ON
rect1034-1-8-5:
action: toggle
actionCommand: ON
stateItems:
- KNX_Schaltaktor_A2_Deckenlicht_Garage
rect1034-1-8:
action: toggle
actionCommand: ON
stateItems:
path1053-9-5-9-1-7:
action: toggle
actionCommand: ON
actionItem: KNX_Schaltaktor_A2_Deckenlicht_Garage
path1053-0-7-9-8-6-2-9-4-3:
action: toggle
actionCommand: ON
actionItem: KNX_Schaltaktor_A1_Deckenlicht_HWR
g58648-6-6-1-9-4-8:
action: toggle
actionCommand: ON
stateItems:
- KNX_Schaltaktor_A1_Deckenlicht_HWR
path1053-0-7-9-8-6-2-9-4:
action: toggle
actionCommand: ON
actionItem: KNX_Schaltaktor_A1_Deckenlicht_Bad_EG
g58648-6-6-1-9-4:
action: toggle
actionCommand: ON
stateItems:
- KNX_Schaltaktor_A1_Deckenlicht_Bad_EG
path1053-0-7-9-8-6-2-9:
action: toggle
actionCommand: ON
actionItem: KNX_Schaltaktor_A1_Deckenlicht_WC
g58648-6-6-1-9:
action: toggle
actionCommand: ON
stateItems:
- KNX_Schaltaktor_A1_Deckenlicht_WC
path1053-0-7-9-8-6-2-2:
action: toggle
actionCommand: ON
actionItem: KNX_Schaltaktor_A1_Deckenlicht_Abstellraum_EG
g58648-6-6-1:
action: toggle
actionCommand: ON
stateItems:
- KNX_Schaltaktor_A1_Deckenlicht_Abstellraum_EG
g1220-0:
action: toggle
actionCommand: ON
stateItems:
- KNX_Schaltaktor_A3_Stromversorgung_Balkon
path1053-0-7-9-8-6-2-9-4-3-1:
action: toggle
actionCommand: ON
actionItem: KNX_Schaltaktor_A1_Deckenlicht_Wohnzimmer
g58648-6-6-1-9-4-8-9:
action: toggle
actionCommand: ON
stateItems:
- KNX_Schaltaktor_A1_Deckenlicht_Wohnzimmer
path1053-0-7-9-8-6-2-9-4-3-1-7:
action: toggle
actionCommand: ON
actionItem: KNX_Schaltaktor_A1_Deckenlicht_Esszimmer
g58648-6-6-1-9-4-8-9-9:
action: toggle
actionCommand: ON
stateItems:
- KNX_Schaltaktor_A1_Deckenlicht_Esszimmer
path1053-0-7-9-8-6-2-9-4-3-1-7-4-6:
action: toggle
actionCommand: ON
actionItem: KNX_Schaltaktor_A2_Deckenlicht_Kuche
g58648-6-6-1-9-4-8-9-9-5:
action: toggle
actionCommand: ON
stateItems:
- KNX_Schaltaktor_A2_Deckenlicht_Kuche
path1053-0-7-9-8-6-2-9-4-3-1-7-4:
action: toggle
actionCommand: ON
actionItem: KNX_Schaltaktor_A2_Deckenlicht_Speisekammer
g58648-6-6-1-9-4-8-9-9-5-0:
action: toggle
actionCommand: ON
stateItems:
- KNX_Schaltaktor_A2_Deckenlicht_Speisekammer
rect1034:
action: toggle
actionCommand: ON
stateItems:
stateAsOpacity: true
stateOffColor: "#00ffff"
invertStateOpacity: true
text4647-9-6-3-6-7:
action: toggle
actionCommand: ON
stateOnColor: =(items.KNX_Schaltaktor_A1_Deckenlicht_HWR.state==='ON') ?
'#ffffff':'#000000'
stateOffColor: "#bbbbbb"
stateItems:
text4647-9-6-3-6:
action: toggle
actionCommand: ON
stateItems:
path1053-9-5-9-1:
action: toggle
actionCommand: ON
actionItem: KNX_Messaktor_M1_Stromversorgung_TV
g1220-8:
action: toggle
actionCommand: ON
stateItems:
- KNX_Messaktor_M1_Stromversorgung_TV
path1053-9-5-9-1-6:
action: toggle
actionCommand: ON
actionItem: KNX_Schaltaktor_A2_Stromversorgung_Steckdose_bei_Klavier
g1220-8-5:
action: toggle
actionCommand: ON
stateItems:
- KNX_Schaltaktor_A2_Stromversorgung_Steckdose_bei_Klavier
path1053-9-5-9:
action: toggle
actionCommand: ON
actionItem: KNX_Schaltaktor_A2_Stromversorgung_Steckdose_fur_Weihnachtsbaum_beim_Staubsaugerroboter
g1220:
action: toggle
actionCommand: ON
stateItems:
- KNX_Schaltaktor_A2_Stromversorgung_Steckdose_fur_Weihnachtsbaum_beim_Staubsaugerroboter
text4256:
action: toggle
actionCommand: ON
stateItems:
- Bewegungsmelder_M17_Temperatur_IST
useProxyElementForState: true
path17759:
action: toggle
actionCommand: ON
stateItems:
- Multidose_157_Fensterkontakt_Ost
stateOnColor: =(items.Multidose_160_Turkontakt_Hauswirtschaftsraum.state=='OPEN')
? '#ff0000':'#000000'
stateOffColor: "#0000ff"
path18049:
action: toggle
actionCommand: ON
stateItems:
stateOnColor: =(items.Multidose_160_Turkontakt_Hauswirtschaftsraum.state==='OPEN')
gridEnable: false
colNum: 6
blocks: []
masonry: []
grid: []
canvas: []
I have also deleted the cache of the current browser and I also checked this with Firefox and Chrome.
I haven’t seen any UI changes regarding dealing with SVGs from 4.3.0 to 4.3.1, so I haven’t updated to 4.3.1 yet.
Attached the screenshot (currently no access to SVG) for the mobil phone version of the gardenview:
Before we do a private remote session to debug it on your side, I put together a simple example that works which only contains a text:
Here is the svg (click on it and “save as…”):
and here is how I defined the text (note that the item is linked to the tspan element, not the text element)
<text
xml:space="preserve"
style="font-style:normal;font-weight:normal;font-size:10.5833px;line-height:1.25;font-family:sans-serif;fill:#000000;fill-opacity:1;stroke:none;stroke-width:0.264583"
x="8.426899"
y="36.443012"
id="text1"><tspan
sodipodi:role="line"
id="textContent"
style="stroke-width:0.264583"
x="8.426899"
y="36.443012"
flash="true"
openhab="true">MyText</tspan></text>
Here is the definition of the canvas (paste it into the code tab):
embedSvg: true
embeddedSvgActions:
textContent:
action: toggle
actionCommand: ON
stateItems:
- slider1
fixedType: canvas
grid: 10
hideNavbar: true
imageUrl: /static/text.svg
label: circle_floor
layoutType: fixed
screenHeight: 1080
screenWidth: 1920
sidebar: false
visibleTo:
- role:administrator
blocks: []
masonry: []
grid: []
canvas:
- component: oh-canvas-layer
preload: true
slots:
default: []
Define the item 'slider1" as follows:
label: Slider 1
type: Dimmer
category: light
groupNames:
- verschiedenes
tags:
- Point
Result (item set to 77 and canvas displaying 77):
Lomex
(Thomas Bachhofer)
January 14, 2025, 5:58pm
5
You made my day, @stefan.hoehn !
With your help I found the problem. I had set the “openhab=true” with inkscape, but unfortunately within <text> and not within <tspan>. I didn’t notice the error because in the past I also had links with “ng-bind” and “ng-class” and so on in the SVGs, these were within the <text> area and it worked.
Now the result of the garden view looks much better due to the content:
In my opinion, there is no need to change the documentation [Fixed Layout Pages | openHAB ], it is already pretty much written there. You just have to read it properly (and understand it).
Thank you for your support.
