Interactive SVG Backgrounds / Dialog is not appearing
Hi folks,
I would use the new cool feature for Interactive SVG backgrounds.
I made an simple circle and activated the openhab = true parameter inside the svg and also the embedded SVG slider inside the canvas configuration.
When I’m cklicking the flash button the circle is highlighted, but when I’m clicking on the circle the configuration dialog isn’t appearing.
Could anyone suggest me whats wrong?
Animation
SVG Code:
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<!-- Uploaded to: SVG Repo, www.svgrepo.com, Generator: SVG Repo Mixer Tools -->
<svg
   fill="#000000"
   version="1.1"
   id="Capa_1"
   width="800px"
   height="800px"
   viewBox="0 0 595.021 595.021"
   xml:space="preserve"
   sodipodi:docname="2.svg"
   inkscape:version="1.3.2 (091e20e, 2023-11-25, custom)"
   xmlns:inkscape="http://www.inkscape.org/namespaces/inkscape"
   xmlns:sodipodi="http://sodipodi.sourceforge.net/DTD/sodipodi-0.dtd"
   xmlns="http://www.w3.org/2000/svg"
   xmlns:svg="http://www.w3.org/2000/svg"><defs
   id="defs4" /><sodipodi:namedview
   id="namedview4"
   pagecolor="#ffffff"
   bordercolor="#000000"
   borderopacity="0.25"
   inkscape:showpageshadow="2"
   inkscape:pageopacity="0.0"
   inkscape:pagecheckerboard="0"
   inkscape:deskcolor="#d1d1d1"
   inkscape:zoom="1.02625"
   inkscape:cx="400"
   inkscape:cy="400"
   inkscape:window-width="1920"
   inkscape:window-height="1017"
   inkscape:window-x="-8"
   inkscape:window-y="-8"
   inkscape:window-maximized="1"
   inkscape:current-layer="Capa_1" />
<path
   d="M 507.529,87.493 C 480.265,60.229 448.507,38.821 413.133,23.858 376.489,8.358 337.588,0.5 297.511,0.5 257.433,0.5 218.532,8.358 181.887,23.858 146.514,38.819 114.755,60.229 87.492,87.493 60.228,114.756 38.819,146.515 23.857,181.888 8.358,218.532 0.5,257.434 0.5,297.511 c 0,40.077 7.858,78.979 23.358,115.623 14.961,35.373 36.371,67.132 63.635,94.396 27.263,27.263 59.022,48.672 94.395,63.634 36.645,15.5 75.546,23.358 115.624,23.358 40.077,0 78.979,-7.858 115.623,-23.358 35.373,-14.961 67.133,-36.371 94.396,-63.634 27.263,-27.264 48.673,-59.022 63.634,-94.396 15.499,-36.645 23.358,-75.546 23.358,-115.623 0,-40.077 -7.858,-78.979 -23.358,-115.624 -14.963,-35.372 -36.373,-67.131 -63.636,-94.394 z M 297.511,551.682 C 157.136,551.682 43.34,437.885 43.34,297.511 43.34,157.136 157.136,43.34 297.511,43.34 c 140.374,0 254.171,113.796 254.171,254.171 0,140.374 -113.797,254.171 -254.171,254.171 z"
   id="path2"
   inkscape:label="path2"
   style="display:inline"
   openhab="true">
		</path></svg>
With the information you provided definitely not.
Can you please check the browser console (browser dev tools) for any errors?
Hopefully, this is the information you need:
Console output:
Unsubscribed from embedded SVG state tracking. app.4c26198030a158df86c4.js:2
No, unfortunately not.
Is there any error or warning (red or yellow) in the browser console when pressing the button and nothing happens?
(Pulling in @stefan.hoehn: Can you confirm it works for you?)
Gimme some time, I will definitely investigate it on the weekend. In case I forget, ping me again :wink:
There is an error after loading the page:
Error:
:8080/settings/pages/layout/page_746b1603ac:1  Blocked aria-hidden on an element because its descendant retained focus. The focus must not be hidden from assistive technology users. Avoid using aria-hidden on a focused element or its ancestor. Consider using the inert attribute instead, which will also prevent focus. For more details, see the aria-hidden section of the WAI-ARIA specification at https://w3c.github.io/aria/#aria-hidden.
Element with focus: a
Ancestor with aria-hidden:  <div class=​"page page-previous page-with-subnavbar" aria-hidden=​"true">​…​</div>​
ausführlich / detailed:
app.4c26198030a158df86c4.js:2 Start tracking states
app.4c26198030a158df86c4.js:2 new SSE connection: http://openhab.local:8080/rest/events/states, 2 open
app.4c26198030a158df86c4.js:2 (2) [EventSource, EventSource]
app.4c26198030a158df86c4.js:2 Setting initial tracking list (0 tracked Items): []
app.4c26198030a158df86c4.js:2 Setting keepalive interval seconds 10
after clicking on the circle the error / detailed messages are the same.
It is actually working flawlessly on my side. I can click on your circle and the dialog comes up.
Can you create a new fixed-canvas, goto the code tab and paste this into the code?
  layoutType: fixed
  fixedType: canvas
  label: circle_floor
  imageUrl: /static/circle-floor.svg
  embedSvg: true
  embedSvgFlashing: true
blocks: []
masonry: []
grid: []
canvas: []
Then hover over the circle and when the circle flashes red → click.
when i create an new page configure the canvas layout from scratch the dialouges opens when I’m clicking on the circle as described in the documentaion…
I don’t know what i have done in the first page…
Maybe you can find a problem :wink:
Here is the code of the page which isn’t working:
  layoutType: fixed
  fixedType: canvas
  imageUrl: /static/2.svg
  label: Test_Canvas
  sidebar: true
  visibleTo:
    - role:administrator
  embedSvg: true
  showFullscreenIcon: true
  gridEnable: true
  grid: 10
  screenWidth: 1920
  screenHeight: 1080
  hideNavbar: true
blocks: []
masonry: []
grid: []
canvas:
  - component: oh-canvas-layer
      preload: true
    slots:
      default: []
I will investigate it but does it now work when you started from scratch? Otherwise I would offer you to make a remote session with me, so we can analyse it together.
I had found another hint i will give you, but I’m not sure if i should open a new thread.
If I put a status color for in and off in the Dialog, which is in my case red / green then I got the following console messages:
invalid rgb values in configured color: green   app.4c26198030a158df86c4.js:2
invalid rgb values in configured color: red     app.4c26198030a158df86c4.js:2
If I take the hex format for the color, everything is fine. If this is the way to do there should be an hint under the color input field :wink:
Yes it works now from scratch.
This is the way to go, color names are not supported. Yep, maybe I’ll add that to the text or at least to the documentation.
Thanks for your reply about the documentation I think the text under the input field is also important, because real man don’t need a documentation :smiley:
I also got another thing with displayState as Text which isn’t working.
Should I open another threat or post all the details here?
Jut go on here, so we can sort all issues out here.
Tell me your usecase (I hope you have read Fixed Layout Pages | openHAB)
The incompatibility is with enabling the grid, don’t know why. This needs to be investigated. I wouldn’t mind if you created an issue for that on github.
(cc @florian-h05)
You are right, it seems to be the grid. If I made it invisible again, the dialog is visible.
I will open an issue afterwards.
Issue: https://github.com/openhab/openhab-webui/issues/2944
Actual workaround: set the grid as invisible.
Thanks, Patrick. I will eventually look into to it.
so now here is the second i already announced yesterday :wink: is there the possibility to use another state as on / off for changing the color? Especially for a door switch like open / close?
Yes, openclosed is also supported by default.
And you can use expressions to calculate the color, e.g.
State On Color:
=(items.AZ_Govee_Light_Strip_Power.state===‘ON’) ? items.AZ_Govee_Schreibtisch_Light_Strip_Color.state: ‘#aaaaaa
In this case the element reflects the color of the lamp if the lamp is on, if it is off it will become gray. (I use this to color my led light strips in my room)
By the way, maybe this example could help you, which I used for testing during the development. It should give you a number of ideas. I hope it works without the items on your side.
Use the attached SVG
Obergeschoss-fixed
and this yaml
  embedSvg: true
  embeddedSvgActions:
    AZ_main_light_slider:
      action: toggle
      actionCommand: ON
      actionCommandAlt: OFF
      actionItem: F2_Office_Main_Light
      stateItems:
        - F2_Office_Main_Light
      stateOffAsStyleClass: sz_main_light_buttonLine:buttonLine_toOff,
        sz_main_light_roundedButton:roundedButton_toOff
      stateOnAsStyleClass: sz_main_light_buttonLine:buttonLine_toOn,
        sz_main_light_roundedButton:roundedButton_toOn
    AZ_main_light_state_info_text:
      action: toggle
      actionCommand: ON
      stateItems:
      stateOffColor: "#00FFFF"
      stateOnColor: "#FFFF00"
    Sofa:
      action: toggle
      actionCommand: ON
      stateItems:
      stateOnColor: "#0000FF"
      useProxyElementForState: true
    andrea:
      action: toggle
      actionCommand: ON
      invertStateOpacity: false
      stateAsOpacity: true
      stateItems:
        - AndreasPhone
      stateMinOpacity: "0.2"
      useProxyElementForState: false
    aussentemperatur_text:
      action: toggle
      actionCommand: ON
      useDisplayState: true
      stateItems:
        - garten_temperature
    az-main-lightbulb:
      action: toggle
      actionCommand: ON
      stateAsOpacity: false
      stateItems:
      stateOnColor: "#00FF00"
    az-main-lightbulb2:
      action: toggle
      actionCommand: ON
      actionItem: F2_Office_Desk_Light
      stateItems:
        - F2_Office_Desk_Light
    az-nano-triangles:
      action: toggle
      actionCommand: ON
      actionItem: AZ_Govee_Light_Strip_Power
    az_balkon_tuer_group:
      actionCommand: ON
      stateItems:
        - AZTuerSensor
    az_fenster_seite_group_l:
      actionCommand: ON
      stateItems:
        - AZ_Fenster_Seite_OpenClose
    az_fenster_seite_group_r:
      actionCommand: ON
      stateItems:
    az_nano_duck:
      action: toggle
      actionCommand: ON
      actionItem: AZNano_Theduck
    az_nano_triangles:
      action: group
      actionCommand: ON
      actionGroupPopupItem: NanoleafAZTriangles
    az_neon_strip:
      action: toggle
      actionCommand: ON
      stateItems:
        - AZ_Govee_Light_Strip_Power
        - AZ_Govee_Schreibtisch_Light_Strip_Color
      stateOnColor: "=(items.AZ_Govee_Light_Strip_Power.state==='ON') ?
        items.AZ_Govee_Schreibtisch_Light_Strip_Color.state: '#aaaaaa'"
    az_seite_rollladen:
      invertStateOpacity: true
      stateItems:
        - F2_Office_shutter_side
    call_jonas:
      actionCommand: ON
      stateItems:
        - TestTrigger2
      stateOnAsStyleClass: jonas_astro_animate:animate
    jonas:
      action: toggle
      actionCommand: ON
      stateItems:
        - JonasPhone3_Online
    stefan:
      actionCommand: ON
      stateItems:
        - StefansPhone2
  fixedType: canvas
  imageUrl: /static/Obergeschoss-fixed.svg
  label: Obergeschoss (fixed)
  layoutType: fixed
  screenWidth: 1300
  sidebar: true
  style:
    background-color: black
blocks: []
masonry: []
grid: []
canvas: []
