I’ve known about a bug in my programming for a while, I finally tracked it down tonight. Maybe someone later will have the same problem and come here to find the fix.
I have several rules that are triggered by Inseton switches as follows:
Item Kitchen received update OFF
Dining.sendCommand(OFF)
Seems simple, right? Well occasionally I would get into a situation where this rule would trigger unexpectedly. I would be in the room, Kitchen would be “OFF” and Dining would be “ON” - then the rule was triggered and Dining would turn OFF.
I finally tracked it down to Insteon modem scenes. If Switch1 is turned off in a scene - then Switch2 is turned on before Switch1 is polled again - the next poll of Switch1 will trigger the scene.
Important items:
Switch Group20 "20 Inside Off" {insteonplm="44.85.d6:0x000045#broadcastonoff,group=20"}
Switch Kitchen "Kitchen" {insteonplm="43.f9.6c:F00.00.02#switch"}
Switch Dining "Dining" {insteonplm="45.1d.81:F00.00.02#switch"}
Group20 turns off both Kitchen and Dining. So if the log file goes something like:
10:00:00 Kitchen polled "ON"
10:00:30 Group20 turns off // sends "OFF" command to Kitchen and Dining
10:01:00 Dining room turned "ON"
10:02:00 Kitchen polled "OFF" // as turned off by Group20
10:02:01 Dining room turns "OFF" // this would be unexpected
So to fix this I’ve basically made a rule like:
Item Group20 received command OFF
Kitchen.sendCommand(OFF)
So that the Insteon polling system expects it to be “OFF” instead of noting it as a status change and triggering an “item updated” rule. Note: “postUpdate” does NOT work for this rule. I only use this trigger on 2 switches so it’s pretty simple to work around.
If anyone out there has come across this issue and has a different fix please share! I’ve only seen it happen 2 or 3 times since I made that rule like 6 months ago but it was driving me nuts. I’ll sleep well tonight knowing it’s fixed.
