Following the successful debut of the Theengs Plug, we’re excited to introduce the Theengs Bridge - your new Ethernet BLE to MQTT bridge. Loaded with OpenMQTTGateway, it brings exceptional range with its external antenna, ensuring your BLE devices stay connected, whether through ethernet or WiFi.
Optimized for Flexibility: Local and Cloud-Compatible
The Bridge supports local operation, letting you maintain autonomy over your network. Its compatibility with over 80 devices makes it a powerful hub for a variety of applications.
OpenHAB integration
Connecting to OpenHAB is a breeze with MQTT auto-discovery.
Why Choose the Theengs Bridge?
- Exceptional Range: An external antenna guarantees wide-reaching connectivity.
- Dual Connectivity: Stability of a wired connection or the freedom of WiFi.
- Expansive Device Support: With a growing list of compatible devices, the Bridge is constantly evolving alongside your smart home needs.
- Development ready: the USB C port can be used to reprogram it following your needs, the Theengs Bridge is also a modular development board.
The Bridge That Supports Open-Source Progress
By opting for the Theengs Bridge, you’re not just upgrading your smart home; you’re also helping open-source project development.
