I’m running openHAB 3.3M1 on a Pi4B running openhabian
I’m seeing a frequent invalid meter type warning in the log. Here is a DEBUG level log, filtered by the Node number:
(Thing configuration follows)
2022-03-07 18:49:55.394 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Application Command Request (ALIVE:DYNAMIC_VALUES)
2022-03-07 18:49:55.395 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: Incoming command class COMMAND_CLASS_METER, endpoint 0
2022-03-07 18:49:55.395 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: SECURITY NOT required on COMMAND_CLASS_METER
2022-03-07 18:49:55.396 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 3: Received COMMAND_CLASS_METER V3 METER_REPORT
2022-03-07 18:49:55.396 [DEBUG] [.commandclass.ZWaveMeterCommandClass] - NODE 3: Meter: Type=Electric(1), Scale=A(5), Value=0.07
2022-03-07 18:49:55.397 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Got an event from Z-Wave network: ZWaveMeterValueEvent
2022-03-07 18:49:55.398 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_METER, value=0.07
2022-03-07 18:49:55.398 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Updating channel state zwave:device:d55bff6cef:node3:meter_current to 0.07 [DecimalType]
2022-03-07 18:49:55.399 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Commands processed 1.
2022-03-07 18:49:55.399 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@1f7f805.
2022-03-07 18:49:55.493 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Application Command Request (ALIVE:DYNAMIC_VALUES)
2022-03-07 18:49:55.494 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: Incoming command class COMMAND_CLASS_METER, endpoint 0
2022-03-07 18:49:55.495 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: SECURITY NOT required on COMMAND_CLASS_METER
2022-03-07 18:49:55.496 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 3: Received COMMAND_CLASS_METER V3 METER_REPORT
2022-03-07 18:49:55.497 [DEBUG] [.commandclass.ZWaveMeterCommandClass] - NODE 3: Meter: Type=Electric(1), Scale=A(5), Value=0.07
2022-03-07 18:49:55.498 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Got an event from Z-Wave network: ZWaveMeterValueEvent
2022-03-07 18:49:55.499 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_METER, value=0.07
2022-03-07 18:49:55.499 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Updating channel state zwave:device:d55bff6cef:node3:meter_current to 0.07 [DecimalType]
2022-03-07 18:49:55.501 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Commands processed 1.
2022-03-07 18:49:55.502 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@6a836e.
2022-03-07 18:49:55.605 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Application Command Request (ALIVE:DYNAMIC_VALUES)
2022-03-07 18:49:55.606 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: Incoming command class COMMAND_CLASS_METER, endpoint 0
2022-03-07 18:49:55.607 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: SECURITY NOT required on COMMAND_CLASS_METER
2022-03-07 18:49:55.608 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 3: Received COMMAND_CLASS_METER V3 METER_REPORT
2022-03-07 18:49:55.608 [DEBUG] [.commandclass.ZWaveMeterCommandClass] - NODE 3: Meter: Type=Electric(1), Scale=A(5), Value=0.07
2022-03-07 18:49:55.609 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Got an event from Z-Wave network: ZWaveMeterValueEvent
2022-03-07 18:49:55.610 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_METER, value=0.07
2022-03-07 18:49:55.611 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Updating channel state zwave:device:d55bff6cef:node3:meter_current to 0.07 [DecimalType]
2022-03-07 18:49:55.612 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Commands processed 1.
2022-03-07 18:49:55.614 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@152d22f.
2022-03-07 18:49:57.624 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Application Command Request (ALIVE:DYNAMIC_VALUES)
2022-03-07 18:49:57.624 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: Incoming command class COMMAND_CLASS_METER, endpoint 0
2022-03-07 18:49:57.625 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: SECURITY NOT required on COMMAND_CLASS_METER
2022-03-07 18:49:57.626 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 3: Received COMMAND_CLASS_METER V3 METER_REPORT
2022-03-07 18:49:57.626 [WARN ] [.commandclass.ZWaveMeterCommandClass] - NODE 3: Invalid meter type 12
2022-03-07 18:49:57.627 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Commands processed 1.
2022-03-07 18:49:57.627 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@1d6c1da.
2022-03-07 18:49:57.864 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Application Command Request (ALIVE:DYNAMIC_VALUES)
2022-03-07 18:49:57.865 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: Incoming command class COMMAND_CLASS_METER, endpoint 0
2022-03-07 18:49:57.865 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: SECURITY NOT required on COMMAND_CLASS_METER
2022-03-07 18:49:57.866 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 3: Received COMMAND_CLASS_METER V3 METER_REPORT
2022-03-07 18:49:57.866 [WARN ] [.commandclass.ZWaveMeterCommandClass] - NODE 3: Invalid meter type 12
2022-03-07 18:49:57.867 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Commands processed 1.
2022-03-07 18:49:57.867 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@18d3375.
2022-03-07 18:49:57.944 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Application Command Request (ALIVE:DYNAMIC_VALUES)
2022-03-07 18:49:57.945 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: Incoming command class COMMAND_CLASS_METER, endpoint 0
2022-03-07 18:49:57.945 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: SECURITY NOT required on COMMAND_CLASS_METER
2022-03-07 18:49:57.946 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 3: Received COMMAND_CLASS_METER V3 METER_REPORT
2022-03-07 18:49:57.946 [WARN ] [.commandclass.ZWaveMeterCommandClass] - NODE 3: Invalid meter type 12
2022-03-07 18:49:57.947 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Commands processed 1.
2022-03-07 18:49:57.947 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@1dea919.
2022-03-07 18:49:59.020 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Application Command Request (ALIVE:DYNAMIC_VALUES)
2022-03-07 18:49:59.021 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: Incoming command class COMMAND_CLASS_METER, endpoint 0
2022-03-07 18:49:59.023 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: SECURITY NOT required on COMMAND_CLASS_METER
2022-03-07 18:49:59.024 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 3: Received COMMAND_CLASS_METER V3 METER_REPORT
2022-03-07 18:49:59.026 [WARN ] [.commandclass.ZWaveMeterCommandClass] - NODE 3: Invalid meter type 12
2022-03-07 18:49:59.027 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Commands processed 1.
2022-03-07 18:49:59.027 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@44dc27.
2022-03-07 18:49:59.085 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Application Command Request (ALIVE:DYNAMIC_VALUES)
2022-03-07 18:49:59.086 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: Incoming command class COMMAND_CLASS_METER, endpoint 0
2022-03-07 18:49:59.086 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: SECURITY NOT required on COMMAND_CLASS_METER
2022-03-07 18:49:59.087 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 3: Received COMMAND_CLASS_METER V3 METER_REPORT
2022-03-07 18:49:59.088 [WARN ] [.commandclass.ZWaveMeterCommandClass] - NODE 3: Invalid meter type 12
2022-03-07 18:49:59.089 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Commands processed 1.
2022-03-07 18:49:59.089 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@1810264.
2022-03-07 18:50:00.858 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Application Command Request (ALIVE:DYNAMIC_VALUES)
2022-03-07 18:50:00.858 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: Incoming command class COMMAND_CLASS_METER, endpoint 0
2022-03-07 18:50:00.859 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: SECURITY NOT required on COMMAND_CLASS_METER
2022-03-07 18:50:00.860 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 3: Received COMMAND_CLASS_METER V3 METER_REPORT
2022-03-07 18:50:00.860 [WARN ] [.commandclass.ZWaveMeterCommandClass] - NODE 3: Invalid meter type 14
2022-03-07 18:50:00.861 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Commands processed 1.
2022-03-07 18:50:00.861 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@1802f11.
2022-03-07 18:50:00.893 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Application Command Request (ALIVE:DYNAMIC_VALUES)
2022-03-07 18:50:00.893 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: Incoming command class COMMAND_CLASS_METER, endpoint 0
2022-03-07 18:50:00.893 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: SECURITY NOT required on COMMAND_CLASS_METER
2022-03-07 18:50:00.894 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 3: Received COMMAND_CLASS_METER V3 METER_REPORT
2022-03-07 18:50:00.894 [WARN ] [.commandclass.ZWaveMeterCommandClass] - NODE 3: Invalid meter type 14
2022-03-07 18:50:00.895 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Commands processed 1.
2022-03-07 18:50:00.895 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@bb8fe7.
2022-03-07 18:50:00.911 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Application Command Request (ALIVE:DYNAMIC_VALUES)
2022-03-07 18:50:00.911 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: Incoming command class COMMAND_CLASS_METER, endpoint 0
2022-03-07 18:50:00.912 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: SECURITY NOT required on COMMAND_CLASS_METER
2022-03-07 18:50:00.912 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 3: Received COMMAND_CLASS_METER V3 METER_REPORT
2022-03-07 18:50:00.913 [WARN ] [.commandclass.ZWaveMeterCommandClass] - NODE 3: Invalid meter type 14
2022-03-07 18:50:00.913 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Commands processed 1.
2022-03-07 18:50:00.914 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@19c2581.
2022-03-07 18:50:01.171 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Application Command Request (ALIVE:DYNAMIC_VALUES)
2022-03-07 18:50:01.172 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: Incoming command class COMMAND_CLASS_METER, endpoint 0
2022-03-07 18:50:01.172 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: SECURITY NOT required on COMMAND_CLASS_METER
2022-03-07 18:50:01.173 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 3: Received COMMAND_CLASS_METER V3 METER_REPORT
2022-03-07 18:50:01.174 [WARN ] [.commandclass.ZWaveMeterCommandClass] - NODE 3: Invalid meter type 14
2022-03-07 18:50:01.174 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Commands processed 1.
2022-03-07 18:50:01.175 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@1aeab12.
2022-03-07 18:50:01.517 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Application Command Request (ALIVE:DYNAMIC_VALUES)
2022-03-07 18:50:01.518 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: Incoming command class COMMAND_CLASS_METER, endpoint 0
2022-03-07 18:50:01.518 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: SECURITY NOT required on COMMAND_CLASS_METER
2022-03-07 18:50:01.519 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 3: Received COMMAND_CLASS_METER V3 METER_REPORT
2022-03-07 18:50:01.520 [WARN ] [.commandclass.ZWaveMeterCommandClass] - NODE 3: Invalid meter type 14
2022```
Thing configuration:
```yaml
UID: zwave:device:d55bff6cef:node3
label: Garage Refrigerator Power Plug
thingTypeUID: zwave:shenzhen_powerplug_00_000
configuration:
config_10_1: 1
group_1:
- controller
group_2: []
action_heal: false
config_1_1: 1
config_7_1: 1
config_8_1: 0
config_9_2: 150
config_2_2: 300
config_3_1: 13
config_4_1: 12
config_5_1: 1
config_6_1: 5
node_id: 3
bridgeUID: zwave:serial_zstick:d55bff6cef
I would appreciate any assistance in troubleshooting this. Thanks in advance.
