Morty
(Morty)
November 18, 2017, 1:48pm
#1
Hello together,
i am using OH2 and i had installed z-wave rollershutter “Fibaro FRGM-222”.
Now i can control them by Basic-UI and via rules.
So far - so good!
But in my sitemap the icon , shows the inverse state.
When the blinds are open (100%) the icon shows closed blinds.
When the blinds are closed (100) the icon shows open blinds.
sitemap:
Switch item=RollerShutter_01_Control label="Wohnzimmer 1 [%d %%]" icon="rollershutter"
The z-wave modul is correct calibrated.
Is there a chance to shows the correct state of my blinds?
Can i use my own icons or can i modify the existing icons?
sihui
(SiHui)
November 18, 2017, 4:41pm
#2
Go to your Blinds Control channel and change the “Invert percentage value”:
Morty
(Morty)
November 18, 2017, 6:28pm
#3
Thanks for your answer.
But there is noch parameter to invert the values.
Do you have a parameter-number of the modul? (e.g. switch-type = 14)
Then i can set the parameter directly in the nodex.xml file.
sihui
(SiHui)
November 18, 2017, 7:30pm
#4
Those are there since ages, take a look again:
PaperUI:
Then click pencil/edit sign:
or use HABmin:
That won’t help, next time the device gets reinitialized the manual changes are gone.
Morty
(Morty)
November 19, 2017, 7:09am
#5
In my Paper-UI settings, there is no option to invert the value.
And i dont have HABmin in use.
Attached there is a screenshot of my Paper-UI view.
Thanks!
sihui
(SiHui)
November 19, 2017, 7:17am
#6
You are at the wrong place, that is your zwave thing .
You need to go to the channel (see my picture above)
Morty
(Morty)
November 19, 2017, 8:01am
#7
Ahhhhhh! Now i found the setting!
I thougt, it must be a basic setting of the thing.
Thank you so much!
Morty
