I also installed the beta version in testflight.
Love the dark mode!!
I have 2 issues with the notifications, do you want me to place them here, in a github issue or via the testflight feedback option?
please open an issue in GitHub. This is known to work.
Alternatively try the built in features of TestFlight. Haven’t seen were the messages arrive there.
Does this have a short cut to HabPanel ?
All items in TestFlight good for me too - love your work
Is ios13 required for dark mode? I currently can’t upgrade, but didn’t see the menu option.
That’s correct dark mode was introduced in iOS 13
Already closed my issue due to a solution from another user but maybe good to mention here:
When you start beta testing the app via testflight it registers your device another time on myopenhab (https://myopenhab.org/devices) so you have 2 the same devices.
This will result in duplicate push messages on a notification.
Just delete one of the devices in myopenhab (the oldest one) will fix it.
Hanks was wondering why that was happening
I’ve never used TestFlight before not sure how crash reports work - do the devs get them? I can consistently crash the app
Only those with access to Crashlytics/ASC, but generally speaking, yes.
Please open an issue on github with steps to reproduce.
Done - thanks
I have trouble with autoupdate=“false” on items of type dimmer. They nevertheless jump to 100% and then back to x%.
No… Native Implemention is the same as manual Siri Shortcuts… Native Implementation only make the Config for you…
You can try it like this in your Shortcut…
https://username:password@www.myopenhab.org/rest/items/YOUR_OH_ITEM
I don’t use myopenhab.org , perhaps the URL is different to the Local RestAPI
Version 2.2 is out on the App Store.
It supports the beautiful Dark mode and addresses many issues
Is there a description how to create own icons for light and dark mode? My icons are black and of course not visible in dark mode
Hi Kevin
This issue was already reported by fellow users
For now there is no solution in the app. A workaround could be to set different icon set with white on black. But this needs to be investigated further
Tim
Does the item type ‘selection’ work in the iOS App ?
I have one of these item types in my sitemap and on Android it is showing me all the possible things I can select for that item but on iOS it’s just blank when I press on it.
Hi @digitaldan
what about shortcuts for the lockcsreen? do you think its possible?
lets say item from sitemap to become a shortcut
