I have updated my grafana from 5.x to 7.1.1 and all my charts in the Sitemap on the iOS OpenHab app did not work anymore but just showed a {“message”: “Invalid username or password”}
If I open the basic UI in a browser instead of the App everything works fine.
After testing the WebView with a “https://postman-echo.com/get” URL it turned out that the iOS App always sends a “authorization”: Basic header.
Any idea how to prevent this? One option would be to explicitly add a username/password to all the grafana URLs in my sitemap.
Dominik
How did you do the update from 5.x to 7.1.1 ?
What is the content of /etc/grafana/grafana.ini ?
For reference see https://grafana.com/docs/grafana/latest/auth/overview/#basic-authentication
I run grafana in a docker container and simply updated the image. The grafana.ini file is not used at all but I specify the following environment variables in the docker-compose file:
environment:
- GF_AUTH_ANONYMOUS_ENABLED=true
- GF_SECURITY_ALLOW_EMBEDDING=true
The interesting thing is that if I access the openhab basic_ui in the browser everything works fine and only when using the ios app I get the error message. The problem seems to be that the ios app is always sending the basic auth header even if no username/password is specified.
