I am running #3480 on a Win11 platform (Zulu JRE 17) with 4 Hikvision cameras implemented as API things.
FFMpeg motion detection is switched off but basically working.
Since some builds I am facing flooding of Item “xxx MotionAlarm” switched to off although
FFMpeg motion alarm is disabled. CAmeras however are working as expected but I suspect that it takes processing power. Any clue how to fix?
09:33:21.194 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘DVBT_Grabber_Pingzeit’ updated to UNDEF
09:33:21.404 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘CAM03_MotionAlarm’ updated to OFF
09:33:21.405 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘CAM03_MotionAlarm’ updated to OFF
09:33:21.406 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘CAM03_MotionAlarm’ updated to OFF
09:33:21.640 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘CAM07_MotionAlarm’ updated to OFF
09:33:21.714 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘CAM03_MotionAlarm’ updated to OFF
09:33:21.715 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘CAM03_MotionAlarm’ updated to OFF
09:33:21.940 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘CAM07_MotionAlarm’ updated to OFF
09:33:21.941 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘CAM07_MotionAlarm’ updated to OFF
09:33:22.025 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘CAM03_MotionAlarm’ updated to OFF
09:33:22.026 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘CAM03_MotionAlarm’ updated to OFF
09:33:22.027 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘CAM03_MotionAlarm’ updated to OFF
09:33:22.333 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘CAM03_MotionAlarm’ updated to OFF
09:33:22.335 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘CAM03_MotionAlarm’ updated to OFF
09:33:22.644 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘CAM03_MotionAlarm’ updated to OFF
09:33:22.645 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘CAM03_MotionAlarm’ updated to OFF
09:33:22.954 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘CAM03_MotionAlarm’ updated to OFF
09:33:22.955 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘CAM03_MotionAlarm’ updated to OFF
09:33:22.956 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘CAM03_MotionAlarm’ updated to OFF
09:33:23.265 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘CAM03_MotionAlarm’ updated to OFF
09:33:23.266 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘CAM03_MotionAlarm’ updated to OFF
09:33:23.504 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘ZW_ZWStick_01_sof’ updated to 42706
09:33:23.505 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘ZW_ZWStick_01_sof’ changed from 42705 to 42706
09:33:23.506 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘ZW_FGBS001_01_Temp01_acq’ updated to 22.31 °C
09:33:23.509 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘ZW_FGBS001_01_Temp01_acq’ changed from 22.37 °C to 22.31 °C
09:33:23.511 [INFO ] [org.openhab.core.model.script.rules ] - Check Hoval T1 value
09:33:23.513 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘ZW_FGBS001_01_Temp01_flt’ updated to 22.31 °C
09:33:23.514 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘ZW_FGBS001_01_Temp01_flt’ changed from 22.37 °C to 22.31 °C
09:33:23.514 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘dspASt23Vorlauf’ updated to 22,4 °C
09:33:23.525 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘ZW_ZWStick_01_sof’ updated to 42707
09:33:23.526 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘ZW_ZWStick_01_sof’ changed from 42706 to 42707
09:33:23.527 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘ZW_FGBS001_01_Temp02_acq’ updated to 22.25 °C
09:33:23.528 [INFO ] [org.openhab.core.model.script.rules ] - Check Hoval T2 value
09:33:23.529 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘ZW_FGBS001_01_Temp02_flt’ updated to 22.25 °C
09:33:23.574 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘CAM03_MotionAlarm’ updated to OFF
09:33:23.575 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘CAM03_MotionAlarm’ updated to OFF
09:33:23.602 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘ZW_FGBS001_01_Temp02_avg24’ updated to 21.9802877997635 °C
09:33:23.603 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘ZW_FGBS001_01_Temp02_avg24’ changed from 21.9797323818954 °C to 21.9802877997635 °C
09:33:23.666 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘ZW_FGBS001_01_Temp01_avg24’ updated to 22.37732431023995 °C
09:33:23.667 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘ZW_FGBS001_01_Temp01_avg24’ changed from 22.37675234892126 °C to 22.37732431023995 °C
09:33:23.884 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘CAM03_MotionAlarm’ updated to OFF
09:33:23.885 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘CAM03_MotionAlarm’ updated to OFF
09:33:24.198 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘CAM03_MotionAlarm’ updated to OFF
09:33:24.199 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘CAM03_MotionAlarm’ updated to OFF
09:33:24.505 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘CAM03_MotionAlarm’ updated to OFF
09:33:24.506 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item ‘CAM03_MotionAlarm’ updated to OFF
