Hello everyone, I can’t get the motion detection to work.
I have installed an AXIS M2036-LE. The camera runs and works perfectly with the Axis app. Motion is detected and reported.
I have installed the camera manually as a Thing via the ui. OpenHAB and the camera are running in different VLANs, OpenHAB also in the Docker container. I assume that this is why the automatic search did not work. ffmpeg was installed in the Docker container.
The camera is online. If I enter the url mentioned in the log in the browser, I can see the camera image (after entering the user and password).
I have linked each motion alarm channel to an item, but these always have the status NULL.
I have no idea where to look for the error and would be very grateful for a hint.
br
Leif
2024-07-22 20:50:42.401 [DEBUG] [ra.internal.IpCameraDiscoveryService] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDiscoveryService] : BundleComponentActivator : ComponentHolder created.
2024-07-22 20:50:42.402 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider] : BundleComponentActivator : ComponentHolder created.
2024-07-22 20:50:42.404 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory] : BundleComponentActivator : ComponentHolder created.
2024-07-22 20:50:42.405 [DEBUG] [ra.internal.IpCameraDiscoveryService] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDiscoveryService] : Dependency Manager created $000interface=org.openhab.core.net.NetworkAddressService, filter=null, policy=static, cardinality=1..1, bind=null, unbind=null, updated=null, field=null, field-option=null, collection-type=service, parameter=0
2024-07-22 20:50:42.406 [DEBUG] [ra.internal.IpCameraDiscoveryService] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDiscoveryService] : Dependency Manager created osgi.ds.satisfying.conditioninterface=org.osgi.service.condition.Condition, filter=(osgi.condition.id=true), policy=dynamic, cardinality=1..1, bind=null, unbind=null, updated=null, field=null, field-option=null, collection-type=null, parameter=null
2024-07-22 20:50:42.406 [DEBUG] [ra.internal.IpCameraDiscoveryService] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDiscoveryService] : Component created: DS=DS14, implementation=org.openhab.binding.ipcamera.internal.IpCameraDiscoveryService, immediate=false, default-enabled=true, factory=null, configuration-policy=optional, activate=activate, deactivate=deactivate, modified=null configuration-pid=[binding.ipcamera]
2024-07-22 20:50:42.407 [DEBUG] [ra.internal.IpCameraDiscoveryService] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDiscoveryService] : Component Services: scope=singleton, services=[org.openhab.core.config.discovery.DiscoveryService]
2024-07-22 20:50:42.407 [DEBUG] [ra.internal.IpCameraDiscoveryService] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDiscoveryService] : Component Properties: {osgi.ds.satisfying.condition.target=(osgi.condition.id=true)}
2024-07-22 20:50:42.408 [DEBUG] [ra.internal.IpCameraDiscoveryService] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDiscoveryService] : Querying state disabled
2024-07-22 20:50:42.410 [DEBUG] [ra.internal.IpCameraDiscoveryService] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDiscoveryService] : Querying state disabled
2024-07-22 20:50:42.410 [DEBUG] [ra.internal.IpCameraDiscoveryService] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDiscoveryService] : Component can not be activated since it is in state disabled
2024-07-22 20:50:42.411 [DEBUG] [ra.internal.IpCameraDiscoveryService] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDiscoveryService] : Querying state disabled
2024-07-22 20:50:42.417 [DEBUG] [ra.internal.IpCameraDiscoveryService] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDiscoveryService(404)] : Updating target filters
2024-07-22 20:50:42.418 [DEBUG] [ra.internal.IpCameraDiscoveryService] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDiscoveryService(404)] : No change in target property for dependency $000: currently registered: false
2024-07-22 20:50:42.418 [DEBUG] [ra.internal.IpCameraDiscoveryService] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDiscoveryService(404)] : No existing service listener to unregister for dependency $000
2024-07-22 20:50:42.419 [DEBUG] [ra.internal.IpCameraDiscoveryService] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDiscoveryService(404)] : Setting target property for dependency $000 to null
2024-07-22 20:50:42.419 [DEBUG] [ra.internal.IpCameraDiscoveryService] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDiscoveryService(404)] : New service tracker for $000, initial active: false, previous references: {}, classFilter: (objectClass=org.openhab.core.net.NetworkAddressService), initialReferenceFilter (objectClass=org.openhab.core.net.NetworkAddressService)
2024-07-22 20:50:42.419 [DEBUG] [ra.internal.IpCameraDiscoveryService] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDiscoveryService(404)] : dm $000 tracker reset (closed)
2024-07-22 20:50:42.420 [DEBUG] [ra.internal.IpCameraDiscoveryService] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDiscoveryService(404)] : dm $000 tracking 1 SingleStatic added {org.openhab.core.net.NetworkAddressService}={service.id=450, service.bundleid=154, service.scope=bundle, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), service.config.category=system, service.pid=org.openhab.network, service.config.label=Network Settings, component.name=org.openhab.core.net.NetUtil, service.config.description.uri=system:network, component.id=289} (enter)
2024-07-22 20:50:42.421 [DEBUG] [ra.internal.IpCameraDiscoveryService] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDiscoveryService(404)] : dm $000 tracking 1 SingleStatic active: false trackerOpened: false optional: false
2024-07-22 20:50:42.421 [DEBUG] [ra.internal.IpCameraDiscoveryService] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDiscoveryService(404)] : dm $000 tracking 1 SingleStatic added {org.openhab.core.net.NetworkAddressService}={service.id=450, service.bundleid=154, service.scope=bundle, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), service.config.category=system, service.pid=org.openhab.network, service.config.label=Network Settings, component.name=org.openhab.core.net.NetUtil, service.config.description.uri=system:network, component.id=289} (exit)
2024-07-22 20:50:42.422 [DEBUG] [ra.internal.IpCameraDiscoveryService] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDiscoveryService(404)] : dm $000 tracker opened
2024-07-22 20:50:42.422 [DEBUG] [ra.internal.IpCameraDiscoveryService] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDiscoveryService(404)] : registering service listener for dependency $000
2024-07-22 20:50:42.423 [DEBUG] [ra.internal.IpCameraDiscoveryService] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDiscoveryService(404)] : No existing service listener to unregister for dependency osgi.ds.satisfying.condition
2024-07-22 20:50:42.423 [DEBUG] [ra.internal.IpCameraDiscoveryService] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDiscoveryService(404)] : Setting target property for dependency osgi.ds.satisfying.condition to (osgi.condition.id=true)
2024-07-22 20:50:42.424 [DEBUG] [ra.internal.IpCameraDiscoveryService] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDiscoveryService(404)] : New service tracker for osgi.ds.satisfying.condition, initial active: false, previous references: {}, classFilter: (objectClass=org.osgi.service.condition.Condition), initialReferenceFilter (&(objectClass=org.osgi.service.condition.Condition)(osgi.condition.id=true))
2024-07-22 20:50:42.434 [DEBUG] [ra.internal.IpCameraDiscoveryService] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDiscoveryService(404)] : dm osgi.ds.satisfying.condition tracker reset (closed)
2024-07-22 20:50:42.434 [DEBUG] [ra.internal.IpCameraDiscoveryService] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDiscoveryService(404)] : dm osgi.ds.satisfying.condition tracking 2 SingleDynamic added {org.osgi.service.condition.Condition}={service.id=6, service.bundleid=0, service.scope=singleton, service.pid=0.org.osgi.service.condition.ConditionImpl, osgi.condition.id=true} (enter)
2024-07-22 20:50:42.435 [DEBUG] [ra.internal.IpCameraDiscoveryService] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDiscoveryService(404)] : dm osgi.ds.satisfying.condition tracking 2 SingleDynamic added {org.osgi.service.condition.Condition}={service.id=6, service.bundleid=0, service.scope=singleton, service.pid=0.org.osgi.service.condition.ConditionImpl, osgi.condition.id=true} (exit)
2024-07-22 20:50:42.437 [DEBUG] [ra.internal.IpCameraDiscoveryService] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDiscoveryService(404)] : dm osgi.ds.satisfying.condition tracker opened
2024-07-22 20:50:42.437 [DEBUG] [ra.internal.IpCameraDiscoveryService] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDiscoveryService(404)] : registering service listener for dependency osgi.ds.satisfying.condition
2024-07-22 20:50:42.453 [DEBUG] [ra.internal.IpCameraDiscoveryService] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDiscoveryService(404)] : Changed state from disabled to unsatisfiedReference
2024-07-22 20:50:42.453 [DEBUG] [ra.internal.IpCameraDiscoveryService] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDiscoveryService(404)] : Component enabled
2024-07-22 20:50:42.454 [DEBUG] [ra.internal.IpCameraDiscoveryService] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDiscoveryService(404)] : ActivateInternal
2024-07-22 20:50:42.454 [DEBUG] [ra.internal.IpCameraDiscoveryService] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDiscoveryService(404)] : Querying state unsatisfiedReference
2024-07-22 20:50:42.455 [DEBUG] [ra.internal.IpCameraDiscoveryService] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDiscoveryService(404)] : Querying state unsatisfiedReference
2024-07-22 20:50:42.456 [DEBUG] [ra.internal.IpCameraDiscoveryService] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDiscoveryService(404)] : Activating component from state unsatisfiedReference
2024-07-22 20:50:42.456 [DEBUG] [ra.internal.IpCameraDiscoveryService] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDiscoveryService(404)] : Querying state unsatisfiedReference
2024-07-22 20:50:42.457 [DEBUG] [ra.internal.IpCameraDiscoveryService] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDiscoveryService(404)] : Querying state unsatisfiedReference
2024-07-22 20:50:42.457 [DEBUG] [ra.internal.IpCameraDiscoveryService] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDiscoveryService(404)] : Changed state from unsatisfiedReference to satisfied
2024-07-22 20:50:42.458 [DEBUG] [ra.internal.IpCameraDiscoveryService] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDiscoveryService(404)] : registration change queue [registered]
2024-07-22 20:50:42.459 [DEBUG] [ra.internal.IpCameraDiscoveryService] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDiscoveryService(404)] : Checking constructor public org.openhab.binding.ipcamera.internal.IpCameraDiscoveryService(org.openhab.core.net.NetworkAddressService)
2024-07-22 20:50:42.460 [DEBUG] [ra.internal.IpCameraDiscoveryService] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDiscoveryService(404)] : getClassFromComponentClassLoader: Looking for interface class org.openhab.core.net.NetworkAddressService through loader of org.openhab.binding.ipcamera.internal.IpCameraDiscoveryService
2024-07-22 20:50:42.461 [DEBUG] [ra.internal.IpCameraDiscoveryService] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDiscoveryService(404)] : getClassFromComponentClassLoader: Found class org.openhab.core.net.NetworkAddressService
2024-07-22 20:50:42.478 [DEBUG] [ra.internal.IpCameraDiscoveryService] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDiscoveryService(404)] : Found constructor with 1 arguments : public org.openhab.binding.ipcamera.internal.IpCameraDiscoveryService(org.openhab.core.net.NetworkAddressService)
2024-07-22 20:50:42.479 [DEBUG] [ra.internal.IpCameraDiscoveryService] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDiscoveryService(404)] : This thread collected dependencies
2024-07-22 20:50:42.479 [DEBUG] [ra.internal.IpCameraDiscoveryService] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDiscoveryService(404)] : getService (single component manager) dependencies collected.
2024-07-22 20:50:42.484 [DEBUG] [ra.internal.IpCameraDiscoveryService] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDiscoveryService(404)] : Querying state satisfied
2024-07-22 20:50:42.485 [DEBUG] [ra.internal.IpCameraDiscoveryService] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDiscoveryService(404)] : Querying state satisfied
2024-07-22 20:50:42.485 [DEBUG] [ra.internal.IpCameraDiscoveryService] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDiscoveryService(404)] : For dependency $000, optional: false; to bind: [[RefPair: ref: [{org.openhab.core.net.NetworkAddressService}={service.id=450, service.bundleid=154, service.scope=bundle, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), service.config.category=system, service.pid=org.openhab.network, service.config.label=Network Settings, component.name=org.openhab.core.net.NetUtil, service.config.description.uri=system:network, component.id=289}] service: [null]]]
2024-07-22 20:50:42.486 [DEBUG] [ra.internal.IpCameraDiscoveryService] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDiscoveryService(404)] : For dependency osgi.ds.satisfying.condition, optional: false; to bind: [[RefPair: ref: [{org.osgi.service.condition.Condition}={service.id=6, service.bundleid=0, service.scope=singleton, service.pid=0.org.osgi.service.condition.ConditionImpl, osgi.condition.id=true}] service: [null]]]
2024-07-22 20:50:42.488 [DEBUG] [ra.internal.IpCameraDiscoveryService] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDiscoveryService(404)] : getting activate: activate
2024-07-22 20:50:42.489 [DEBUG] [ra.internal.IpCameraDiscoveryService] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDiscoveryService(404)] : Locating method activate in class org.openhab.binding.ipcamera.internal.IpCameraDiscoveryService
2024-07-22 20:50:42.490 [DEBUG] [ra.internal.IpCameraDiscoveryService] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDiscoveryService(404)] : Declared Method org.openhab.binding.ipcamera.internal.IpCameraDiscoveryService.activate([interface org.osgi.service.component.ComponentContext]) not found
2024-07-22 20:50:42.492 [DEBUG] [ra.internal.IpCameraDiscoveryService] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDiscoveryService(404)] : Locating method activate in class org.openhab.core.config.discovery.AbstractDiscoveryService
2024-07-22 20:50:42.492 [DEBUG] [ra.internal.IpCameraDiscoveryService] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDiscoveryService(404)] : Declared Method org.openhab.core.config.discovery.AbstractDiscoveryService.activate([interface org.osgi.service.component.ComponentContext]) not found
2024-07-22 20:50:42.493 [DEBUG] [ra.internal.IpCameraDiscoveryService] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDiscoveryService(404)] : Found activate method: protected void org.openhab.core.config.discovery.AbstractDiscoveryService.activate(java.util.Map)
2024-07-22 20:50:42.494 [DEBUG] [ra.internal.IpCameraDiscoveryService] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDiscoveryService(404)] : invoking activate: activate: parameters [org.apache.felix.scr.impl.helper.ReadOnlyDictionary]
2024-07-22 20:50:42.496 [DEBUG] [ra.internal.IpCameraDiscoveryService] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDiscoveryService(404)] : invoked activate: activate
2024-07-22 20:50:42.496 [DEBUG] [ra.internal.IpCameraDiscoveryService] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDiscoveryService(404)] : Set implementation object for component
2024-07-22 20:50:42.497 [DEBUG] [ra.internal.IpCameraDiscoveryService] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDiscoveryService(404)] : Changed state from satisfied to active
2024-07-22 20:50:42.509 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider] : Dependency Manager created $000interface=org.openhab.core.events.EventPublisher, filter=null, policy=static, cardinality=1..1, bind=null, unbind=null, updated=null, field=null, field-option=null, collection-type=service, parameter=0
2024-07-22 20:50:42.509 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider] : Dependency Manager created $001interface=org.openhab.core.thing.link.ItemChannelLinkRegistry, filter=null, policy=static, cardinality=1..1, bind=null, unbind=null, updated=null, field=null, field-option=null, collection-type=service, parameter=1
2024-07-22 20:50:42.510 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider] : Dependency Manager created $002interface=org.openhab.core.thing.i18n.ChannelTypeI18nLocalizationService, filter=null, policy=static, cardinality=1..1, bind=null, unbind=null, updated=null, field=null, field-option=null, collection-type=service, parameter=2
2024-07-22 20:50:42.510 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider] : Dependency Manager created osgi.ds.satisfying.conditioninterface=org.osgi.service.condition.Condition, filter=(osgi.condition.id=true), policy=dynamic, cardinality=1..1, bind=null, unbind=null, updated=null, field=null, field-option=null, collection-type=null, parameter=null
2024-07-22 20:50:42.511 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider] : Component created: DS=DS14, implementation=org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider, immediate=false, default-enabled=true, factory=null, configuration-policy=optional, activate=activate, deactivate=deactivate, modified=null configuration-pid=[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider]
2024-07-22 20:50:42.512 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider] : Component Services: scope=singleton, services=[org.openhab.core.thing.type.DynamicStateDescriptionProvider, org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider]
2024-07-22 20:50:42.512 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider] : Component Properties: {osgi.ds.satisfying.condition.target=(osgi.condition.id=true)}
2024-07-22 20:50:42.516 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider] : Querying state disabled
2024-07-22 20:50:42.517 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider] : Querying state disabled
2024-07-22 20:50:42.517 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider] : Component can not be activated since it is in state disabled
2024-07-22 20:50:42.520 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider] : Querying state disabled
2024-07-22 20:50:42.522 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider(405)] : Updating target filters
2024-07-22 20:50:42.523 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider(405)] : No change in target property for dependency $000: currently registered: false
2024-07-22 20:50:42.523 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider(405)] : No existing service listener to unregister for dependency $000
2024-07-22 20:50:42.525 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider(405)] : Setting target property for dependency $000 to null
2024-07-22 20:50:42.527 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider(405)] : New service tracker for $000, initial active: false, previous references: {}, classFilter: (objectClass=org.openhab.core.events.EventPublisher), initialReferenceFilter (objectClass=org.openhab.core.events.EventPublisher)
2024-07-22 20:50:42.527 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider(405)] : dm $000 tracker reset (closed)
2024-07-22 20:50:42.528 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider(405)] : dm $000 tracking 1 SingleStatic added {org.openhab.core.events.EventPublisher}={service.id=298, service.bundleid=154, service.scope=bundle, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), component.name=org.openhab.core.internal.events.OSGiEventPublisher, component.id=260} (enter)
2024-07-22 20:50:42.529 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider(405)] : dm $000 tracking 1 SingleStatic active: false trackerOpened: false optional: false
2024-07-22 20:50:42.529 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider(405)] : dm $000 tracking 1 SingleStatic added {org.openhab.core.events.EventPublisher}={service.id=298, service.bundleid=154, service.scope=bundle, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), component.name=org.openhab.core.internal.events.OSGiEventPublisher, component.id=260} (exit)
2024-07-22 20:50:42.530 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider(405)] : dm $000 tracker opened
2024-07-22 20:50:42.530 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider(405)] : registering service listener for dependency $000
2024-07-22 20:50:42.531 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider(405)] : No change in target property for dependency $001: currently registered: false
2024-07-22 20:50:42.531 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider(405)] : No existing service listener to unregister for dependency $001
2024-07-22 20:50:42.532 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider(405)] : Setting target property for dependency $001 to null
2024-07-22 20:50:42.532 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider(405)] : New service tracker for $001, initial active: false, previous references: {}, classFilter: (objectClass=org.openhab.core.thing.link.ItemChannelLinkRegistry), initialReferenceFilter (objectClass=org.openhab.core.thing.link.ItemChannelLinkRegistry)
2024-07-22 20:50:42.532 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider(405)] : dm $001 tracker reset (closed)
2024-07-22 20:50:42.533 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider(405)] : dm $001 tracking 2 SingleStatic added {org.openhab.core.thing.link.ItemChannelLinkRegistry}={service.id=422, service.bundleid=219, service.scope=bundle, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), component.name=org.openhab.core.thing.link.ItemChannelLinkRegistry, component.id=226} (enter)
2024-07-22 20:50:42.534 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider(405)] : dm $001 tracking 2 SingleStatic active: false trackerOpened: false optional: false
2024-07-22 20:50:42.534 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider(405)] : dm $001 tracking 2 SingleStatic added {org.openhab.core.thing.link.ItemChannelLinkRegistry}={service.id=422, service.bundleid=219, service.scope=bundle, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), component.name=org.openhab.core.thing.link.ItemChannelLinkRegistry, component.id=226} (exit)
2024-07-22 20:50:42.535 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider(405)] : dm $001 tracker opened
2024-07-22 20:50:42.535 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider(405)] : registering service listener for dependency $001
2024-07-22 20:50:42.535 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider(405)] : No change in target property for dependency $002: currently registered: false
2024-07-22 20:50:42.536 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider(405)] : No existing service listener to unregister for dependency $002
2024-07-22 20:50:42.536 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider(405)] : Setting target property for dependency $002 to null
2024-07-22 20:50:42.537 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider(405)] : New service tracker for $002, initial active: false, previous references: {}, classFilter: (objectClass=org.openhab.core.thing.i18n.ChannelTypeI18nLocalizationService), initialReferenceFilter (objectClass=org.openhab.core.thing.i18n.ChannelTypeI18nLocalizationService)
2024-07-22 20:50:42.537 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider(405)] : dm $002 tracker reset (closed)
2024-07-22 20:50:42.538 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider(405)] : dm $002 tracking 3 SingleStatic added {org.openhab.core.thing.i18n.ChannelTypeI18nLocalizationService}={service.id=337, service.bundleid=219, service.scope=bundle, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), component.name=org.openhab.core.thing.i18n.ChannelTypeI18nLocalizationService, component.id=205} (enter)
2024-07-22 20:50:42.539 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider(405)] : dm $002 tracking 3 SingleStatic active: false trackerOpened: false optional: false
2024-07-22 20:50:42.539 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider(405)] : dm $002 tracking 3 SingleStatic added {org.openhab.core.thing.i18n.ChannelTypeI18nLocalizationService}={service.id=337, service.bundleid=219, service.scope=bundle, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), component.name=org.openhab.core.thing.i18n.ChannelTypeI18nLocalizationService, component.id=205} (exit)
2024-07-22 20:50:42.539 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider(405)] : dm $002 tracker opened
2024-07-22 20:50:42.540 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider(405)] : registering service listener for dependency $002
2024-07-22 20:50:42.540 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider(405)] : No existing service listener to unregister for dependency osgi.ds.satisfying.condition
2024-07-22 20:50:42.542 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider(405)] : Setting target property for dependency osgi.ds.satisfying.condition to (osgi.condition.id=true)
2024-07-22 20:50:42.543 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider(405)] : New service tracker for osgi.ds.satisfying.condition, initial active: false, previous references: {}, classFilter: (objectClass=org.osgi.service.condition.Condition), initialReferenceFilter (&(objectClass=org.osgi.service.condition.Condition)(osgi.condition.id=true))
2024-07-22 20:50:42.544 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider(405)] : dm osgi.ds.satisfying.condition tracker reset (closed)
2024-07-22 20:50:42.545 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider(405)] : dm osgi.ds.satisfying.condition tracking 4 SingleDynamic added {org.osgi.service.condition.Condition}={service.id=6, service.bundleid=0, service.scope=singleton, service.pid=0.org.osgi.service.condition.ConditionImpl, osgi.condition.id=true} (enter)
2024-07-22 20:50:42.548 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider(405)] : dm osgi.ds.satisfying.condition tracking 4 SingleDynamic added {org.osgi.service.condition.Condition}={service.id=6, service.bundleid=0, service.scope=singleton, service.pid=0.org.osgi.service.condition.ConditionImpl, osgi.condition.id=true} (exit)
2024-07-22 20:50:42.549 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider(405)] : dm osgi.ds.satisfying.condition tracker opened
2024-07-22 20:50:42.550 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider(405)] : registering service listener for dependency osgi.ds.satisfying.condition
2024-07-22 20:50:42.553 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider(405)] : Changed state from disabled to unsatisfiedReference
2024-07-22 20:50:42.555 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider(405)] : Component enabled
2024-07-22 20:50:42.556 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider(405)] : ActivateInternal
2024-07-22 20:50:42.557 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider(405)] : Querying state unsatisfiedReference
2024-07-22 20:50:42.558 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider(405)] : Querying state unsatisfiedReference
2024-07-22 20:50:42.559 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider(405)] : Activating component from state unsatisfiedReference
2024-07-22 20:50:42.560 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider(405)] : Querying state unsatisfiedReference
2024-07-22 20:50:42.561 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider(405)] : Querying state unsatisfiedReference
2024-07-22 20:50:42.561 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider(405)] : Changed state from unsatisfiedReference to satisfied
2024-07-22 20:50:42.562 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider(405)] : registration change queue [registered]
2024-07-22 20:50:42.566 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider(405)] : Checking constructor public org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider(org.openhab.core.events.EventPublisher,org.openhab.core.thing.link.ItemChannelLinkRegistry,org.openhab.core.thing.i18n.ChannelTypeI18nLocalizationService)
2024-07-22 20:50:42.568 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider(405)] : getClassFromComponentClassLoader: Looking for interface class org.openhab.core.events.EventPublisher through loader of org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider
2024-07-22 20:50:42.569 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider(405)] : getClassFromComponentClassLoader: Found class org.openhab.core.events.EventPublisher
2024-07-22 20:50:42.570 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider(405)] : getClassFromComponentClassLoader: Looking for interface class org.openhab.core.thing.link.ItemChannelLinkRegistry through loader of org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider
2024-07-22 20:50:42.571 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider(405)] : getClassFromComponentClassLoader: Found class org.openhab.core.thing.link.ItemChannelLinkRegistry
2024-07-22 20:50:42.574 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider(405)] : getClassFromComponentClassLoader: Looking for interface class org.openhab.core.thing.i18n.ChannelTypeI18nLocalizationService through loader of org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider
2024-07-22 20:50:42.577 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider(405)] : getClassFromComponentClassLoader: Found class org.openhab.core.thing.i18n.ChannelTypeI18nLocalizationService
2024-07-22 20:50:42.578 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider(405)] : Found constructor with 3 arguments : public org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider(org.openhab.core.events.EventPublisher,org.openhab.core.thing.link.ItemChannelLinkRegistry,org.openhab.core.thing.i18n.ChannelTypeI18nLocalizationService)
2024-07-22 20:50:42.578 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider(405)] : This thread collected dependencies
2024-07-22 20:50:42.579 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider(405)] : getService (single component manager) dependencies collected.
2024-07-22 20:50:42.580 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider(405)] : Querying state satisfied
2024-07-22 20:50:42.581 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider(405)] : Querying state satisfied
2024-07-22 20:50:42.582 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider(405)] : For dependency $000, optional: false; to bind: [[RefPair: ref: [{org.openhab.core.events.EventPublisher}={service.id=298, service.bundleid=154, service.scope=bundle, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), component.name=org.openhab.core.internal.events.OSGiEventPublisher, component.id=260}] service: [null]]]
2024-07-22 20:50:42.582 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider(405)] : For dependency $001, optional: false; to bind: [[RefPair: ref: [{org.openhab.core.thing.link.ItemChannelLinkRegistry}={service.id=422, service.bundleid=219, service.scope=bundle, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), component.name=org.openhab.core.thing.link.ItemChannelLinkRegistry, component.id=226}] service: [null]]]
2024-07-22 20:50:42.583 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider(405)] : For dependency $002, optional: false; to bind: [[RefPair: ref: [{org.openhab.core.thing.i18n.ChannelTypeI18nLocalizationService}={service.id=337, service.bundleid=219, service.scope=bundle, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), component.name=org.openhab.core.thing.i18n.ChannelTypeI18nLocalizationService, component.id=205}] service: [null]]]
2024-07-22 20:50:42.587 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider(405)] : For dependency osgi.ds.satisfying.condition, optional: false; to bind: [[RefPair: ref: [{org.osgi.service.condition.Condition}={service.id=6, service.bundleid=0, service.scope=singleton, service.pid=0.org.osgi.service.condition.ConditionImpl, osgi.condition.id=true}] service: [null]]]
2024-07-22 20:50:42.588 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider(405)] : getting activate: activate
2024-07-22 20:50:42.589 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider(405)] : Locating method activate in class org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider
2024-07-22 20:50:42.590 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider(405)] : Declared Method org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider.activate([interface org.osgi.service.component.ComponentContext]) not found
2024-07-22 20:50:42.596 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider(405)] : Locating method activate in class org.openhab.core.thing.binding.BaseDynamicStateDescriptionProvider
2024-07-22 20:50:42.598 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider(405)] : Declared Method org.openhab.core.thing.binding.BaseDynamicStateDescriptionProvider.activate([interface org.osgi.service.component.ComponentContext]) not found
2024-07-22 20:50:42.598 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider(405)] : Locating method activate in class org.openhab.core.thing.binding.AbstractDynamicDescriptionProvider
2024-07-22 20:50:42.599 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider(405)] : Found activate method: protected void org.openhab.core.thing.binding.AbstractDynamicDescriptionProvider.activate(org.osgi.service.component.ComponentContext)
2024-07-22 20:50:42.600 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider(405)] : invoking activate: activate: parameters [org.apache.felix.scr.impl.manager.ComponentContextImpl]
2024-07-22 20:50:42.601 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider(405)] : invoked activate: activate
2024-07-22 20:50:42.606 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider(405)] : Set implementation object for component
2024-07-22 20:50:42.610 [DEBUG] [ameraDynamicStateDescriptionProvider] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider(405)] : Changed state from satisfied to active
2024-07-22 20:50:42.612 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory] : Dependency Manager created $000interface=org.openhab.core.net.NetworkAddressService, filter=null, policy=static, cardinality=1..1, bind=null, unbind=null, updated=null, field=null, field-option=null, collection-type=service, parameter=0
2024-07-22 20:50:42.613 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory] : Dependency Manager created $001interface=org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider, filter=null, policy=static, cardinality=1..1, bind=null, unbind=null, updated=null, field=null, field-option=null, collection-type=service, parameter=1
2024-07-22 20:50:42.614 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory] : Dependency Manager created $002interface=org.osgi.service.http.HttpService, filter=null, policy=static, cardinality=1..1, bind=null, unbind=null, updated=null, field=null, field-option=null, collection-type=service, parameter=2
2024-07-22 20:50:42.616 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory] : Dependency Manager created osgi.ds.satisfying.conditioninterface=org.osgi.service.condition.Condition, filter=(osgi.condition.id=true), policy=dynamic, cardinality=1..1, bind=null, unbind=null, updated=null, field=null, field-option=null, collection-type=null, parameter=null
2024-07-22 20:50:42.619 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory] : Component created: DS=DS14, implementation=org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory, immediate=false, default-enabled=true, factory=null, configuration-policy=optional, activate=activate, deactivate=deactivate, modified=null configuration-pid=[binding.ipcamera]
2024-07-22 20:50:42.622 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory] : Component Services: scope=singleton, services=[org.openhab.core.thing.binding.ThingHandlerFactory]
2024-07-22 20:50:42.623 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory] : Component Properties: {osgi.ds.satisfying.condition.target=(osgi.condition.id=true)}
2024-07-22 20:50:42.624 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory] : Querying state disabled
2024-07-22 20:50:42.625 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory] : Querying state disabled
2024-07-22 20:50:42.626 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory] : Component can not be activated since it is in state disabled
2024-07-22 20:50:42.627 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory] : Querying state disabled
2024-07-22 20:50:42.629 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory(406)] : Updating target filters
2024-07-22 20:50:42.630 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory(406)] : No change in target property for dependency $000: currently registered: false
2024-07-22 20:50:42.631 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory(406)] : No existing service listener to unregister for dependency $000
2024-07-22 20:50:42.632 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory(406)] : Setting target property for dependency $000 to null
2024-07-22 20:50:42.636 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory(406)] : New service tracker for $000, initial active: false, previous references: {}, classFilter: (objectClass=org.openhab.core.net.NetworkAddressService), initialReferenceFilter (objectClass=org.openhab.core.net.NetworkAddressService)
2024-07-22 20:50:42.638 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory(406)] : dm $000 tracker reset (closed)
2024-07-22 20:50:42.639 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory(406)] : dm $000 tracking 1 SingleStatic added {org.openhab.core.net.NetworkAddressService}={service.id=450, service.bundleid=154, service.scope=bundle, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), service.config.category=system, service.pid=org.openhab.network, service.config.label=Network Settings, component.name=org.openhab.core.net.NetUtil, service.config.description.uri=system:network, component.id=289} (enter)
2024-07-22 20:50:42.640 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory(406)] : dm $000 tracking 1 SingleStatic active: false trackerOpened: false optional: false
2024-07-22 20:50:42.644 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory(406)] : dm $000 tracking 1 SingleStatic added {org.openhab.core.net.NetworkAddressService}={service.id=450, service.bundleid=154, service.scope=bundle, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), service.config.category=system, service.pid=org.openhab.network, service.config.label=Network Settings, component.name=org.openhab.core.net.NetUtil, service.config.description.uri=system:network, component.id=289} (exit)
2024-07-22 20:50:42.645 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory(406)] : dm $000 tracker opened
2024-07-22 20:50:42.650 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory(406)] : registering service listener for dependency $000
2024-07-22 20:50:42.650 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory(406)] : No change in target property for dependency $001: currently registered: false
2024-07-22 20:50:42.651 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory(406)] : No existing service listener to unregister for dependency $001
2024-07-22 20:50:42.652 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory(406)] : Setting target property for dependency $001 to null
2024-07-22 20:50:42.652 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory(406)] : New service tracker for $001, initial active: false, previous references: {}, classFilter: (objectClass=org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider), initialReferenceFilter (objectClass=org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider)
2024-07-22 20:50:42.652 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory(406)] : dm $001 tracker reset (closed)
2024-07-22 20:50:42.653 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory(406)] : dm $001 tracking 2 SingleStatic added {org.openhab.core.thing.type.DynamicStateDescriptionProvider, org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider}={service.id=636, service.bundleid=279, service.scope=bundle, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), component.name=org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider, component.id=405} (enter)
2024-07-22 20:50:42.662 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory(406)] : dm $001 tracking 2 SingleStatic active: false trackerOpened: false optional: false
2024-07-22 20:50:42.662 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory(406)] : dm $001 tracking 2 SingleStatic added {org.openhab.core.thing.type.DynamicStateDescriptionProvider, org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider}={service.id=636, service.bundleid=279, service.scope=bundle, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), component.name=org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider, component.id=405} (exit)
2024-07-22 20:50:42.663 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory(406)] : dm $001 tracker opened
2024-07-22 20:50:42.663 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory(406)] : registering service listener for dependency $001
2024-07-22 20:50:42.663 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory(406)] : No change in target property for dependency $002: currently registered: false
2024-07-22 20:50:42.664 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory(406)] : No existing service listener to unregister for dependency $002
2024-07-22 20:50:42.664 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory(406)] : Setting target property for dependency $002 to null
2024-07-22 20:50:42.665 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory(406)] : New service tracker for $002, initial active: false, previous references: {}, classFilter: (objectClass=org.osgi.service.http.HttpService), initialReferenceFilter (objectClass=org.osgi.service.http.HttpService)
2024-07-22 20:50:42.666 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory(406)] : dm $002 tracker reset (closed)
2024-07-22 20:50:42.668 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory(406)] : dm $002 tracking 3 SingleStatic added {org.osgi.service.http.HttpService, org.ops4j.pax.web.service.WebContainer}={org.ops4j.pax.web.log.ncsa.extended=true, org.ops4j.pax.web.ssl.keystore.password=********, service.scope=bundle, org.ops4j.pax.web.ssl.key.password=********, org.ops4j.pax.web.session.cookie.name=JSESSIONID, org.osgi.service.http.connector.name=default, org.ops4j.pax.web.enc.iterationcount=1000, org.ops4j.pax.web.log.ncsa.file=yyyy_mm_dd.request.log, org.ops4j.pax.web.server.eventDispatcherThreadCount=1, org.osgi.service.http.checkForwardedHeaders=false, org.ops4j.pax.web.enc.suffix=), org.ops4j.pax.web.digestAuth.maxNonceAge=60000, org.ops4j.pax.web.ssl.ciphersuites.included=, org.ops4j.pax.web.session.url=jsessionid, org.ops4j.pax.web.formAuth.errorRedirect=false, org.ops4j.pax.web.ssl.ciphersuites.excluded=^.*_(MD5|SHA|SHA1)$,^TLS_RSA_.*$,^SSL_.*$,^.*_NULL_.*$,^.*_anon_.*, org.ops4j.pax.web.enc.prefix=ENC(, org.ops4j.pax.web.server.maxThreads=50, org.ops4j.pax.web.validatePeerCerts=false, service.id=124, org.ops4j.pax.web.session.cookie.maxAge=-1, org.ops4j.pax.web.ssl.truststore.password=********, org.ops4j.pax.web.ssl.session.cacheSize=-1, org.ops4j.pax.web.ssl.truststore.type=JKS, org.ops4j.pax.web.ssl.keystore.type=JKS, org.ops4j.pax.web.ssl.session.enabled=true, org.ops4j.pax.web.ssl.protocol=TLSv1.3, org.osgi.service.http.port=8080, org.ops4j.pax.web.log.ncsa.file.date.format=yyyy-MM-dd, org.ops4j.pax.web.ssl.renegotiationLimit=-1, org.osgi.service.http.secure.enabled=true, org.osgi.service.http.enabled=true, org.ops4j.pax.web.server.idleTimeout=300000, org.ops4j.pax.web.log.ncsa.retaindays=90, org.ops4j.pax.web.log.ncsa.logtimezone=GMT, org.ops4j.pax.web.enc.algorithm=PBEWithHmacSHA256AndAES_128, org.ops4j.pax.web.validateCerts=false, org.ops4j.pax.web.config.files=/openhab/runtime/etc/jetty.xml, org.ops4j.pax.web.ssl.renegotiationAllowed=true, org.ops4j.pax.web.digestAuth.maxNonceCount=1024, org.ops4j.pax.web.enableOCSP=false, org.ops4j.pax.web.ssl.clientauth.needed=false, org.ops4j.pax.web.enc.enabled=false, org.osgi.service.http.port.secure=8443, javax.servlet.context.tempdir=/openhab/userdata/tmp, org.ops4j.pax.web.enableCRLDP=false, org.ops4j.pax.web.server.connector.idleTimeout=30000, org.ops4j.pax.web.session.timeout=10, org.ops4j.pax.web.ssl.clientauth.wanted=false, org.ops4j.pax.web.ssl.protocols.excluded=SSL,SSLv2,SSLv2Hello,SSLv3, service.bundleid=230, org.ops4j.pax.web.server.minThreads=2, org.ops4j.pax.web.session.cookie.secure=false, org.ops4j.pax.web.enc.masterpassword=********, org.ops4j.pax.web.log.ncsa.append=true, org.osgi.service.http.secure.connector.name=secureDefault, org.ops4j.pax.web.ssl.session.timeout=-1, org.ops4j.pax.web.listening.addresses=0.0.0.0, org.ops4j.pax.web.log.ncsa.buffered=true, org.ops4j.pax.web.session.cookie.sameSite=unset, org.ops4j.pax.web.log.ncsa.enabled=false, org.ops4j.pax.web.ssl.protocols.included=, org.ops4j.pax.web.session.cookie.httpOnly=true, org.ops4j.pax.web.server.showStacks=false} (enter)
2024-07-22 20:50:42.671 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory(406)] : dm $002 tracking 3 SingleStatic active: false trackerOpened: false optional: false
2024-07-22 20:50:42.673 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory(406)] : dm $002 tracking 3 SingleStatic added {org.osgi.service.http.HttpService, org.ops4j.pax.web.service.WebContainer}={org.ops4j.pax.web.log.ncsa.extended=true, org.ops4j.pax.web.ssl.keystore.password=********, service.scope=bundle, org.ops4j.pax.web.ssl.key.password=********, org.ops4j.pax.web.session.cookie.name=JSESSIONID, org.osgi.service.http.connector.name=default, org.ops4j.pax.web.enc.iterationcount=1000, org.ops4j.pax.web.log.ncsa.file=yyyy_mm_dd.request.log, org.ops4j.pax.web.server.eventDispatcherThreadCount=1, org.osgi.service.http.checkForwardedHeaders=false, org.ops4j.pax.web.enc.suffix=), org.ops4j.pax.web.digestAuth.maxNonceAge=60000, org.ops4j.pax.web.ssl.ciphersuites.included=, org.ops4j.pax.web.session.url=jsessionid, org.ops4j.pax.web.formAuth.errorRedirect=false, org.ops4j.pax.web.ssl.ciphersuites.excluded=^.*_(MD5|SHA|SHA1)$,^TLS_RSA_.*$,^SSL_.*$,^.*_NULL_.*$,^.*_anon_.*, org.ops4j.pax.web.enc.prefix=ENC(, org.ops4j.pax.web.server.maxThreads=50, org.ops4j.pax.web.validatePeerCerts=false, service.id=124, org.ops4j.pax.web.session.cookie.maxAge=-1, org.ops4j.pax.web.ssl.truststore.password=********, org.ops4j.pax.web.ssl.session.cacheSize=-1, org.ops4j.pax.web.ssl.truststore.type=JKS, org.ops4j.pax.web.ssl.keystore.type=JKS, org.ops4j.pax.web.ssl.session.enabled=true, org.ops4j.pax.web.ssl.protocol=TLSv1.3, org.osgi.service.http.port=8080, org.ops4j.pax.web.log.ncsa.file.date.format=yyyy-MM-dd, org.ops4j.pax.web.ssl.renegotiationLimit=-1, org.osgi.service.http.secure.enabled=true, org.osgi.service.http.enabled=true, org.ops4j.pax.web.server.idleTimeout=300000, org.ops4j.pax.web.log.ncsa.retaindays=90, org.ops4j.pax.web.log.ncsa.logtimezone=GMT, org.ops4j.pax.web.enc.algorithm=PBEWithHmacSHA256AndAES_128, org.ops4j.pax.web.validateCerts=false, org.ops4j.pax.web.config.files=/openhab/runtime/etc/jetty.xml, org.ops4j.pax.web.ssl.renegotiationAllowed=true, org.ops4j.pax.web.digestAuth.maxNonceCount=1024, org.ops4j.pax.web.enableOCSP=false, org.ops4j.pax.web.ssl.clientauth.needed=false, org.ops4j.pax.web.enc.enabled=false, org.osgi.service.http.port.secure=8443, javax.servlet.context.tempdir=/openhab/userdata/tmp, org.ops4j.pax.web.enableCRLDP=false, org.ops4j.pax.web.server.connector.idleTimeout=30000, org.ops4j.pax.web.session.timeout=10, org.ops4j.pax.web.ssl.clientauth.wanted=false, org.ops4j.pax.web.ssl.protocols.excluded=SSL,SSLv2,SSLv2Hello,SSLv3, service.bundleid=230, org.ops4j.pax.web.server.minThreads=2, org.ops4j.pax.web.session.cookie.secure=false, org.ops4j.pax.web.enc.masterpassword=********, org.ops4j.pax.web.log.ncsa.append=true, org.osgi.service.http.secure.connector.name=secureDefault, org.ops4j.pax.web.ssl.session.timeout=-1, org.ops4j.pax.web.listening.addresses=0.0.0.0, org.ops4j.pax.web.log.ncsa.buffered=true, org.ops4j.pax.web.session.cookie.sameSite=unset, org.ops4j.pax.web.log.ncsa.enabled=false, org.ops4j.pax.web.ssl.protocols.included=, org.ops4j.pax.web.session.cookie.httpOnly=true, org.ops4j.pax.web.server.showStacks=false} (exit)
2024-07-22 20:50:42.676 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory(406)] : dm $002 tracker opened
2024-07-22 20:50:42.677 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory(406)] : registering service listener for dependency $002
2024-07-22 20:50:42.678 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory(406)] : No existing service listener to unregister for dependency osgi.ds.satisfying.condition
2024-07-22 20:50:42.679 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory(406)] : Setting target property for dependency osgi.ds.satisfying.condition to (osgi.condition.id=true)
2024-07-22 20:50:42.680 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory(406)] : New service tracker for osgi.ds.satisfying.condition, initial active: false, previous references: {}, classFilter: (objectClass=org.osgi.service.condition.Condition), initialReferenceFilter (&(objectClass=org.osgi.service.condition.Condition)(osgi.condition.id=true))
2024-07-22 20:50:42.681 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory(406)] : dm osgi.ds.satisfying.condition tracker reset (closed)
2024-07-22 20:50:42.682 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory(406)] : dm osgi.ds.satisfying.condition tracking 4 SingleDynamic added {org.osgi.service.condition.Condition}={service.id=6, service.bundleid=0, service.scope=singleton, service.pid=0.org.osgi.service.condition.ConditionImpl, osgi.condition.id=true} (enter)
2024-07-22 20:50:42.683 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory(406)] : dm osgi.ds.satisfying.condition tracking 4 SingleDynamic added {org.osgi.service.condition.Condition}={service.id=6, service.bundleid=0, service.scope=singleton, service.pid=0.org.osgi.service.condition.ConditionImpl, osgi.condition.id=true} (exit)
2024-07-22 20:50:42.684 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory(406)] : dm osgi.ds.satisfying.condition tracker opened
2024-07-22 20:50:42.685 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory(406)] : registering service listener for dependency osgi.ds.satisfying.condition
2024-07-22 20:50:42.685 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory(406)] : Changed state from disabled to unsatisfiedReference
2024-07-22 20:50:42.686 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory(406)] : Component enabled
2024-07-22 20:50:42.687 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory(406)] : ActivateInternal
2024-07-22 20:50:42.688 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory(406)] : Querying state unsatisfiedReference
2024-07-22 20:50:42.689 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory(406)] : Querying state unsatisfiedReference
2024-07-22 20:50:42.690 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory(406)] : Activating component from state unsatisfiedReference
2024-07-22 20:50:42.691 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory(406)] : Querying state unsatisfiedReference
2024-07-22 20:50:42.692 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory(406)] : Querying state unsatisfiedReference
2024-07-22 20:50:42.692 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory(406)] : Changed state from unsatisfiedReference to satisfied
2024-07-22 20:50:42.693 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory(406)] : registration change queue [registered]
2024-07-22 20:50:42.694 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory(406)] : Checking constructor public org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory(org.openhab.core.net.NetworkAddressService,org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider,org.osgi.service.http.HttpService)
2024-07-22 20:50:42.695 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory(406)] : getClassFromComponentClassLoader: Looking for interface class org.openhab.core.net.NetworkAddressService through loader of org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory
2024-07-22 20:50:42.696 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory(406)] : getClassFromComponentClassLoader: Found class org.openhab.core.net.NetworkAddressService
2024-07-22 20:50:42.696 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory(406)] : getClassFromComponentClassLoader: Looking for interface class org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider through loader of org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory
2024-07-22 20:50:42.697 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory(406)] : getClassFromComponentClassLoader: Found class org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider
2024-07-22 20:50:42.698 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory(406)] : getClassFromComponentClassLoader: Looking for interface class org.osgi.service.http.HttpService through loader of org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory
2024-07-22 20:50:42.698 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory(406)] : getClassFromComponentClassLoader: Found class org.osgi.service.http.HttpService
2024-07-22 20:50:42.699 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory(406)] : Found constructor with 3 arguments : public org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory(org.openhab.core.net.NetworkAddressService,org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider,org.osgi.service.http.HttpService)
2024-07-22 20:50:42.700 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory(406)] : This thread collected dependencies
2024-07-22 20:50:42.701 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory(406)] : getService (single component manager) dependencies collected.
2024-07-22 20:50:42.702 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory(406)] : Querying state satisfied
2024-07-22 20:50:42.703 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory(406)] : Querying state satisfied
2024-07-22 20:50:42.705 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory(406)] : For dependency $000, optional: false; to bind: [[RefPair: ref: [{org.openhab.core.net.NetworkAddressService}={service.id=450, service.bundleid=154, service.scope=bundle, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), service.config.category=system, service.pid=org.openhab.network, service.config.label=Network Settings, component.name=org.openhab.core.net.NetUtil, service.config.description.uri=system:network, component.id=289}] service: [null]]]
2024-07-22 20:50:42.706 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory(406)] : For dependency $001, optional: false; to bind: [[RefPair: ref: [{org.openhab.core.thing.type.DynamicStateDescriptionProvider, org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider}={service.id=636, service.bundleid=279, service.scope=bundle, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), component.name=org.openhab.binding.ipcamera.internal.IpCameraDynamicStateDescriptionProvider, component.id=405}] service: [null]]]
2024-07-22 20:50:42.707 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory(406)] : For dependency $002, optional: false; to bind: [[RefPair: ref: [{org.osgi.service.http.HttpService, org.ops4j.pax.web.service.WebContainer}={org.ops4j.pax.web.log.ncsa.extended=true, org.ops4j.pax.web.ssl.keystore.password=********, service.scope=bundle, org.ops4j.pax.web.ssl.key.password=********, org.ops4j.pax.web.session.cookie.name=JSESSIONID, org.osgi.service.http.connector.name=default, org.ops4j.pax.web.enc.iterationcount=1000, org.ops4j.pax.web.log.ncsa.file=yyyy_mm_dd.request.log, org.ops4j.pax.web.server.eventDispatcherThreadCount=1, org.osgi.service.http.checkForwardedHeaders=false, org.ops4j.pax.web.enc.suffix=), org.ops4j.pax.web.digestAuth.maxNonceAge=60000, org.ops4j.pax.web.ssl.ciphersuites.included=, org.ops4j.pax.web.session.url=jsessionid, org.ops4j.pax.web.formAuth.errorRedirect=false, org.ops4j.pax.web.ssl.ciphersuites.excluded=^.*_(MD5|SHA|SHA1)$,^TLS_RSA_.*$,^SSL_.*$,^.*_NULL_.*$,^.*_anon_.*, org.ops4j.pax.web.enc.prefix=ENC(, org.ops4j.pax.web.server.maxThreads=50, org.ops4j.pax.web.validatePeerCerts=false, service.id=124, org.ops4j.pax.web.session.cookie.maxAge=-1, org.ops4j.pax.web.ssl.truststore.password=********, org.ops4j.pax.web.ssl.session.cacheSize=-1, org.ops4j.pax.web.ssl.truststore.type=JKS, org.ops4j.pax.web.ssl.keystore.type=JKS, org.ops4j.pax.web.ssl.session.enabled=true, org.ops4j.pax.web.ssl.protocol=TLSv1.3, org.osgi.service.http.port=8080, org.ops4j.pax.web.log.ncsa.file.date.format=yyyy-MM-dd, org.ops4j.pax.web.ssl.renegotiationLimit=-1, org.osgi.service.http.secure.enabled=true, org.osgi.service.http.enabled=true, org.ops4j.pax.web.server.idleTimeout=300000, org.ops4j.pax.web.log.ncsa.retaindays=90, org.ops4j.pax.web.log.ncsa.logtimezone=GMT, org.ops4j.pax.web.enc.algorithm=PBEWithHmacSHA256AndAES_128, org.ops4j.pax.web.validateCerts=false, org.ops4j.pax.web.config.files=/openhab/runtime/etc/jetty.xml, org.ops4j.pax.web.ssl.renegotiationAllowed=true, org.ops4j.pax.web.digestAuth.maxNonceCount=1024, org.ops4j.pax.web.enableOCSP=false, org.ops4j.pax.web.ssl.clientauth.needed=false, org.ops4j.pax.web.enc.enabled=false, org.osgi.service.http.port.secure=8443, javax.servlet.context.tempdir=/openhab/userdata/tmp, org.ops4j.pax.web.enableCRLDP=false, org.ops4j.pax.web.server.connector.idleTimeout=30000, org.ops4j.pax.web.session.timeout=10, org.ops4j.pax.web.ssl.clientauth.wanted=false, org.ops4j.pax.web.ssl.protocols.excluded=SSL,SSLv2,SSLv2Hello,SSLv3, service.bundleid=230, org.ops4j.pax.web.server.minThreads=2, org.ops4j.pax.web.session.cookie.secure=false, org.ops4j.pax.web.enc.masterpassword=********, org.ops4j.pax.web.log.ncsa.append=true, org.osgi.service.http.secure.connector.name=secureDefault, org.ops4j.pax.web.ssl.session.timeout=-1, org.ops4j.pax.web.listening.addresses=0.0.0.0, org.ops4j.pax.web.log.ncsa.buffered=true, org.ops4j.pax.web.session.cookie.sameSite=unset, org.ops4j.pax.web.log.ncsa.enabled=false, org.ops4j.pax.web.ssl.protocols.included=, org.ops4j.pax.web.session.cookie.httpOnly=true, org.ops4j.pax.web.server.showStacks=false}] service: [null]]]
2024-07-22 20:50:42.708 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory(406)] : For dependency osgi.ds.satisfying.condition, optional: false; to bind: [[RefPair: ref: [{org.osgi.service.condition.Condition}={service.id=6, service.bundleid=0, service.scope=singleton, service.pid=0.org.osgi.service.condition.ConditionImpl, osgi.condition.id=true}] service: [null]]]
2024-07-22 20:50:42.710 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory(406)] : getting activate: activate
2024-07-22 20:50:42.711 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory(406)] : Locating method activate in class org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory
2024-07-22 20:50:42.712 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory(406)] : Declared Method org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory.activate([interface org.osgi.service.component.ComponentContext]) not found
2024-07-22 20:50:42.713 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory(406)] : Locating method activate in class org.openhab.core.thing.binding.BaseThingHandlerFactory
2024-07-22 20:50:42.716 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory(406)] : Found activate method: protected void org.openhab.core.thing.binding.BaseThingHandlerFactory.activate(org.osgi.service.component.ComponentContext)
2024-07-22 20:50:42.718 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory(406)] : invoking activate: activate: parameters [org.apache.felix.scr.impl.manager.ComponentContextImpl]
2024-07-22 20:50:42.719 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory(406)] : invoked activate: activate
2024-07-22 20:50:42.721 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory(406)] : Set implementation object for component
2024-07-22 20:50:42.722 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:4.1.3 (279)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory(406)] : Changed state from satisfied to active
