Uninstall the binding from the UI
Drop the jar file after being unzipped into that folder
It should then work no restart needed
If you get errors in the logs, then install the tellstick binding to supply the netty library that will be causing the errors.
Very simple and you don’t need to restart.
@sheldon
After doing some more testing, I did find a bug so make sure you download the newer ZIP which has it fixed.
The WARN about user/pass wrong, this was stopping the binding from setting up the alarm server automatically. Only effects INSTAR. Fixed in todays newer PM jar so thanks for reporting it.
The second WARN means the camera or the binding has a full queue of http requests, this may happen if the cameras server is busy and wont answer the binding. You may be getting 50x http errors logged in trace mode, so if you can capture it happening in trace that would help work out the cause.
Either PM me or open a new thread to keep this one cleaner.
thanks, the problem seems to be fixed. Both cameras work as expected. However, I decided to uninstall the snapshot release and wait for the next milestone release because the Tellstick binding caused some trouble. I got the following exception in the log:
[ERROR] [l.discovery.TellstickBridgeDiscovery] - Could not load telldus core, please make sure Telldus is installed and correct 32/64 bit java.
And there were also some warnings related to other serial devices (Modbus, EnOcean).
I hope that the Tellstick dependency is not permanent?
No not permanent which is why when you uninstall the ipcamera binding it then misses the needed dependencies. There are other ways to install them via console commands, or downloading the jar files from maven repos.
Now that the newer binding has setup the cameras alarm server settings, you should find it will keep working even when you use the m3 version, just ignore the WARN as it will occur. It only needs to setup the alarm server once.
when I replace “ipcamera.mjpeg” by “snapshots.mjpeg” it is working.
I didn’t change anything to the camera (afaik)
Is there something I can check?
I have a Hikvision camera DS-2CD2T85FWD
If it can’t be a binding issue I will downgrade to 3.1 and try again, just to be sure it hasn’t anything to do with the camera.
Thanks.
You can leave the port 80 out if you have reconfigured openHAB to serve on that port and as you wrote if the other ones work it must be something else. What does the TRACE log show if you pause all cameras except 1 and capture when you open the first stream? The log will tell you it saw the GET request and provide some more hints. If you don’t see the log of the GET request then triple check the URL has the correct uniqueID as that has caught me a few times when deleting and re-adding cameras to test with.
My Hik cameras are working fine, but I need to do a firmware update which I’ll do tonight and retest. If you have not updated the firmware yet, HIK has a security flaw discovered that needs an update to fix.
Edit: @PeterB Still working here after firmware update done to latest to fix security flaw in cameras firmware. Will need trace logs to look at further.
Try making sure your user / pass is correct and then restart the camera. Hik has a feature where it will lock you out if you get the password wrong 3 times and only restarting the camera will reset it. Hard to know if the 401 or the 503 is the reason.
Do you have digest or basic auth setup on the camera?
I rebooted the camera, but it didn’t change anything.
Both RTSP Authentication and WEB Authentication are set to digest.
I don’t have issues accessing the camera via the web interface.
Btw, I am using the binding shipped with the milestone, not your updated version.
EDIT: I reverted back to openhab 3.1 release and the old URL: http://192.168.178.20:50001/ipcamera.mjpeg is working again, but the errors in the log file are still there.
Digest has a 401 error every time, that is how it works so each request is made twice with the first one failing. So the 503 has stopped when you reverted? How often did you get the 503? I will need to have a in depth look as the reason is not obvious and your logs do not show the GET request is received so it may not even be from the point in time that the request was made.
The URL in the log is for the snapshot and not the stream.
I also encounter the following messages into the log:
[DEBUG] [amera.internal.servlet.CameraServlet] - GET:/ipcamera.mjpeg, received from 127.0.0.1
[DEBUG] [amera.internal.servlet.CameraServlet] - First stream requested, opening up stream from camera
[TRACE] [era.internal.handler.IpCameraHandler] - Sending camera: GET: http://192.168.120.52:80/ISAPI/Streaming/channels/102/httppreview
[WARN ] [era.internal.handler.IpCameraHandler] - !!!! Camera possibly closed the channel on the binding, cause reported is: Queue full
This is the cause of the problem with missing/freeze mjpeg stream mentioned into 11301. In case the stream starts, it works for few (maximum 5) seconds and then freeze.
I confirm that the code from this commit fixed the issue. Thank you, Matt!
The 503 errors were only appearing on my Hikvision cameras and I was able to reproduce some issues here, they should be fixed in the changes in the PR linked above. If anyone can help test that would be great.
So I was not having any issues (reolink cameras), but wanted to report the new IP camera binding with breaking changes uses less CPU on my Rpi4. Here is a picture of before and after. A little hard to read, but the change is about the middle of the graph. The spikes are when video was triggered.
Thanks @matt1 for all your efforts. I think it is a very important OH binding.
Good to hear its working and always interesting to see graphs that show things have changed, either in the positive or negative direction. The newer changes not yet merged should further reduce system loads for cameras that use digest auths weather it is enough to be seen on graphs I don’t know. The other big change is that for people that leave streams open on tablets 24-7 the binding is getting some TLC to ensure the camera can go offline for unlimited time and it should still having a working picture on the tablet when the camera comes back online. A lot is changing in the binding at the moment so any help with testing and giving feedback is apricated.
I installed the updated binding, but noticed some strange things:
I can now see again the ipcamer.mjpeg stream in my sitemap view. The weird thing is that if I am not viewing the sitemap, either on my PC or my android app, then I can’t view the ipcamera.mjpeg stream in my browser by using a direct URL. If I open the app on my phone then I can see it in my browser. The snapshots.mjpeg is not affected by this.
What is the name of the zip file you downloaded or is it in milestone 3? I made some changes that may help in the downloadable jar found in first post.
