IPCamera binding 'filter_complex': Filter not found
I am using the recordGIF Channel to send animated gifs from my entrance door via pushover.
This worked for years but has stopped working after I upgraded to openHAB 5.0.1 and a couple of days later to Debian 13 with Temurin Java21.
So I cannot tell exactly which of these two changes broke that.
I always used the default option for GIF Out Options
-r 2 -filter_complex scale=-2:360:flags=lanczos,setpts=0.5*PTS,split[o1][o2];[o1]palettegen[p];[o2]fifo[o3];[o3][p]paletteuse
which leads to this error message:
2025-09-06 19:08:33.181 [DEBUG] [hab.binding.ipcamera.internal.IpCameraActions] - Recording ipcamera.gif for 2 seconds.
2025-09-06 19:08:33.213 [DEBUG] [org.openhab.binding.ipcamera.internal.Ffmpeg ] - Starting ffmpeg with this command now: -y -t 2 -hide_banner -loglevel warning -rtsp_transport tcp -i rtsp://admin:********@192.168.2.234:554 -r 2 -filter_complex scale=-2:360:flags=lanczos,setpts=0.5*PTS,split[o1][o2];[o1]palettegen[p];[o2]fifo[o3];[o3][p]paletteuse /opt/openhab/conf/html/dahua2/ipcamera.gif
2025-09-06 19:08:33.335 [TRACE] [org.openhab.binding.ipcamera.internal.Ffmpeg ] - [AVFilterGraph @ 0x555cb737f440] No such filter: 'fifo'
2025-09-06 19:08:33.358 [TRACE] [org.openhab.binding.ipcamera.internal.Ffmpeg ] - Failed to set value 'scale=-2:360:flags=lanczos,setpts=0.5*PTS,split[o1][o2];[o1]palettegen[p];[o2]fifo[o3];[o3][p]paletteuse' for option 'filter_complex': Filter not found
2025-09-06 19:08:33.383 [TRACE] [org.openhab.binding.ipcamera.internal.Ffmpeg ] - Error parsing global options: Filter not found
When omitting the -filter_complex part and only using -r 2 I can make it work again.
Any ideas?
Changing from Temurin Java 21 to the default Debian 13 openJDK Java 21 did not help.
Going back to Debian 12 with Temurin 21 solves the problem.
Solution can be found here:
