Running the ipCamera discovery features provides the following error:
17:17:08.875 [ERROR] [internal.DiscoveryServiceRegistryImpl] - Cannot trigger scan for thing types '[ipcamera:foscam, ipcamera:onvif, ipcamera:hikvision, ipcamera:amcrest, ipcamera:instar, ipcamera:dahua, ipcamera:generic, ipcamera:doorbird]' on 'IpCameraDiscoveryService'!
io.netty.channel.ChannelPipelineException: org.openhab.binding.ipcamera.internal.onvif.OnvifDiscovery$2 is not a @Sharable handler, so can't be added or removed multiple times.
at io.netty.channel.DefaultChannelPipeline.checkMultiplicity(DefaultChannelPipeline.java:604) ~[?:?]
at io.netty.channel.DefaultChannelPipeline.addLast(DefaultChannelPipeline.java:202) ~[?:?]
at io.netty.channel.DefaultChannelPipeline.addLast(DefaultChannelPipeline.java:385) ~[?:?]
at io.netty.channel.DefaultChannelPipeline.addLast(DefaultChannelPipeline.java:372) ~[?:?]
at io.netty.bootstrap.Bootstrap.init(Bootstrap.java:259) ~[?:?]
Do you have any idea on the reason?
My install:
OH3.0.1 version running on Docker running on synology DS916+ and DSM7 / Java11
