Ipcamera HLS widget (with auto play)
Hi @matt1 ,
I’m in need of a simple widget that I can just put a HLS URL in and it displays the video (ideally auto starting it).
I use your clickable widget already BUT there is NO clickable image with this scenario and this is for an external HLS feed also. It could be used against your binding also (as an incentive).
Here’s the URL I want to stream in the widget.
https://wza.utk.edu/rock/front.stream/playlist.m3u8
Currently, I have it in an iFrame in HabPanel but it’s not exactly pretty.
Any quick code code you provide me to create the widget?
Best, Jay
