IpCamera: New IP Camera Binding
Yes not surprised as it will kill the ffmpeg that is fetching snapshots. If you use the snapshots.mjpeg it will probably work as you want. This area needs a tidy up by creating a new channel that makes sense, so expect a breaking change when it is done. A github issue is already open on it. Would you prefer two new channels added? One to stop the snapshots and the other for ipcamera.mjpeg?
edit:
@yfaway
That config should not change anything in relation to ffmpeg, leave it on default.
Yes it only fires up on demand when you open a stream with ipcamera.mjpeg and auto stops when it is not needed anymore. It is the snapshots that occur all the time unless you stop them with that channel.
I would think that a single channel makes more sense, as this specifically targets the spawn of ffmpeg. I would also suggest that if polImage is off than accessing all streaming or snapshot URL should generate an error. This shouldn’t affect existing users as most of them would unlikely set pollImage to off. If this is not done, pollImage would not be useful as the existence of a Video tag in the sitemap would spawn ffmpeg (even if its visibility is linked to the pollImage state).
What do you think about that?
I’m wondering if channel for RTSP URL for reolink camers instead returning rtsp://IPNUMBER:PORT/ should return: rtsp://admin:PASSWORD@IPNUMBER:PORT/
Help! I have many http camera and they work well. Since two years I tried to have a RTSP camera and never I was able to have it working (crashes, loop, cpu stressed).
First attempt with an EZVIZ C6N that after firmware updates stopped to work in RTSP.
Now I try a cheap d-link DCS-6100HL and I’m becoming mad. I do not find any example about the config, and I’m reading a lot of posts, but I cannot figure how to have it working. The problem is that I always have two ffmpeg processes, one for the stream and one for the snapshot. The stream (or the snapshot) forw for a while, but soon I must restart openhab because the stream is freezed.
I’m sure that I miss osmething important in my configuration, because all the other 5 cameras (all http-only) are working perfectly:
This is my thing file
Thing ipcamera:generic:divano “Webcam Sala” @ “Webcams”
[ ipAddress=“192.168.1.87”,
updateImageWhen=0,
ipWhitelist=“DISABLE”,
snapshotUrl=“”,
mjpegUrl=“ffmpeg”,
password=“******”,
username=“admin”,
ffmpegInput=“rtsp://192.168.1.87:554/live/profile.0/video”,
ffmpegOutput=“/TMPDIR/divano/”
And these are the two ffmpeg processes I have:
root@mhw:/etc/openhab # ps -ef | grep ffm
openhab    900 29658 16 15:20 ?        00:00:03 /usr/bin/ffmpeg -rtsp_transport tcp -threads 1 -skip_frame nokey -hide_banner -i rtsp://admin:517764@192.168.1.87:554/live/profile.0/video -an -vsync vfr -q:v 2 -update 1 http://127.0.0.1:8080/ipcamera/divano/snapshot.jpg
openhab    994 29658 56 15:20 ?        00:00:05 /usr/bin/ffmpeg -rtsp_transport tcp -hide_banner -i rtsp://admin:517764@192.168.1.87:554/live/profile.0/video -q:v 5 -r 2 -vf scale=640:-2 -update 1 http://127.0.0.1:8080/ipcamera/divano/ipcamera.jpg
Hi @matt1,
I have a question about the MP4_recording timer.
I start my records with
getActions("ipcamera", thingid).recordMP4(name,20)
Then the MP4_recording timer is set to 20 seconds.
But the end of the timer is very variable. See below… How do you set the timer?
I need the finish of the record to do some ffmpeg converts…
2024-03-31 19:59:18 ReolinkRLC410WKeller_MotionAlarm changed to ON
2024-03-31 19:59:18 ReolinkRLC410WKeller_MP4_Recording changed to 20
2024-03-31 19:59:20 ReolinkRLC410WKeller_MotionAlarm changed to OFF
2024-03-31 19:59:43 ReolinkRLC410WKeller_MP4_Recording changed to 0
2024-03-31 20:04:44 ReolinkRLC410WKeller_MotionAlarm changed to ON
2024-03-31 20:04:44 ReolinkRLC410WKeller_MP4_Recording changed to 20
2024-03-31 20:04:45 ReolinkRLC410WKeller_MotionAlarm changed to OFF
2024-03-31 20:05:21 ReolinkRLC410WKeller_MP4_Recording changed to 0
2024-03-31 20:31:33 ReolinkRLC410WKeller_MotionAlarm changed to ON
2024-03-31 20:31:33 ReolinkRLC410WKeller_MP4_Recording changed to 20
2024-03-31 20:31:34 ReolinkRLC410WKeller_MotionAlarm changed to OFF
2024-03-31 20:31:58 ReolinkRLC410WKeller_MP4_Recording changed to 0
You can see the ffmpeg command that is used in the debug level log. Ffmpeg gets told how long to record for and it handles it, so your best to use Google and search using ffmpeg in your search term and read what is said that matches your symptoms. You could also try the command in a terminal and see what ffmpeg is telling you, it may be your cameras is using a variable frame rate or something that ffmpeg is not setup or detecting and it may be giving you hints. Not a lot to go on sorry.
Edit, if you mean the recording is correct and it is only the state of the channel you questioning I believe it just sets the state when the command terminates. I guess it could be varying if your camera drops out and does not provide the frames. Make sure the camera is using tcp and not udp for the stream.
Yes, the recording is correct and it’s 20 seconds long…
I tried and the mp4 recording timer resets to 0 when the ffmpeg process is finished… So it takes around double the time as the recording is…
Thx and Greets…
Edit: with another camera it last 5 seconds longer… (25 seconds till timer is 0)
With third camera it lasts 28 seconds…
I need to find out what’s going on here…
the settings are almost the same…
My guess is it has something to do with ffmpeg needing to convert the cameras format into what you are asking it to do with the ffmpeg command. Sounds like it is not a bug, just ffmpeg taking longer to close due to x reason.
I am using OH 4.1 with the IPcamera binding. Everything is working except the Motion Detection with the Foscam C5M camera. When enabling the channel “Enable Motion Alarm” it goes back automatically after about 5s and I have no idea why?!
When reading the CGI I get following output:
<CGI_Result>
    <result>0</result>
    <isEnable>1</isEnable>
    <linkage>0</linkage>
    <snapInterval>0</snapInterval>
    <sensitivity>0</sensitivity>
    <triggerInterval>0</triggerInterval>
    <isMovAlarmEnable>1</isMovAlarmEnable>
    <isPirAlarmEnable>0</isPirAlarmEnable>
    <schedule0>0</schedule0>
    <schedule1>0</schedule1>
    <schedule2>0</schedule2>
    <schedule3>0</schedule3>
    <schedule4>0</schedule4>
    <schedule5>0</schedule5>
    <schedule6>0</schedule6>
    <area0>0</area0>
    <area1>0</area1>
    <area2>0</area2>
    <area3>0</area3>
    <area4>0</area4>
    <area5>0</area5>
    <area6>0</area6>
    <area7>0</area7>
    <area8>0</area8>
    <area9>0</area9>
    <humanEnable>1</humanEnable>
    <carEnable>0</carEnable>
    <petEnable>0</petEnable>
    <crossLineEnable>0</crossLineEnable>
    <OnlyDtPed>0</OnlyDtPed>
    <isEnableLine0>0</isEnableLine0>
    <line0Direction>0</line0Direction>
    <line0StartX>0</line0StartX>
    <line0StartY>0</line0StartY>
    <line0EndX>0</line0EndX>
    <line0EndY>0</line0EndY>
    <isEnableLine1>0</isEnableLine1>
    <line1Direction>0</line1Direction>
    <line1StartX>0</line1StartX>
    <line1StartY>0</line1StartY>
    <line1EndX>0</line1EndX>
    <line1EndY>0</line1EndY>
    <isEnableLine2>0</isEnableLine2>
    <line2Direction>0</line2Direction>
    <line2StartX>0</line2StartX>
    <line2StartY>0</line2StartY>
    <line2EndX>0</line2EndX>
    <line2EndY>0</line2EndY>
    <isEnableLine3>0</isEnableLine3>
    <line3Direction>0</line3Direction>
    <line3StartX>0</line3StartX>
    <line3StartY>0</line3StartY>
    <line3EndX>0</line3EndX>
    <line3EndY>0</line3EndY>
</CGI_Result>
In the event log I see:
Item 'IP_Kamera_OG__Foscam_Camera_with_API_Enable_Motion_Alarm' updated to OFF
Item 'IP_Kamera_OG__Foscam_Camera_with_API_LED_Controls' updated to 0
Here I see “1”. So what I am doing wrong here? Do I need to update something or.? Please help
Thank you
@matt1
I have started to get some problems with the alarmstream, it does not work any longer.
2024-04-09 09:05:31.029 [WARN ] [netty.channel.DefaultChannelPipeline] - An exceptionCaught() event was fired, and it reached at the tail of the pipeline. It usually means the last handler in the pipeline did not handle the exception.
java.lang.IndexOutOfBoundsException: Index 0 out of bounds for length 0
        at jdk.internal.util.Preconditions.outOfBounds(Preconditions.java:64) ~[?:?]
        at jdk.internal.util.Preconditions.outOfBoundsCheckIndex(Preconditions.java:70) ~[?:?]
        at jdk.internal.util.Preconditions.checkIndex(Preconditions.java:266) ~[?:?]
        at java.util.Objects.checkIndex(Objects.java:361) ~[?:?]
        at java.util.ArrayList.set(ArrayList.java:441) ~[?:?]
        at org.openhab.binding.ipcamera.internal.HikvisionHandler.channelRead(HikvisionHandler.java:181) ~[?:?]
        at io.netty.channel.AbstractChannelHandlerContext.invokeChannelRead(AbstractChannelHandlerContext.java:442) [bundleFile:4.1.104.Final]
        at io.netty.channel.AbstractChannelHandlerContext.invokeChannelRead(AbstractChannelHandlerContext.java:420) [bundleFile:4.1.104.Final]
        at io.netty.channel.AbstractChannelHandlerContext.fireChannelRead(AbstractChannelHandlerContext.java:412) [bundleFile:4.1.104.Final]
        at io.netty.channel.ChannelInboundHandlerAdapter.channelRead(ChannelInboundHandlerAdapter.java:93) [bundleFile:4.1.104.Final]
        at org.openhab.binding.ipcamera.internal.handler.IpCameraHandler$CommonCameraHandler.channelRead(IpCameraHandler.java:297) [bundleFile:?]
        at org.openhab.binding.ipcamera.internal.MyNettyAuthHandler.channelRead(MyNettyAuthHandler.java:182) [bundleFile:?]
        at io.netty.channel.CombinedChannelDuplexHandler$DelegatingChannelHandlerContext.fireChannelRead(CombinedChannelDuplexHandler.java:436) [bundleFile:4.1.104.Final]
        at io.netty.handler.codec.ByteToMessageDecoder.fireChannelRead(ByteToMessageDecoder.java:346) [bundleFile:4.1.104.Final]
        at io.netty.handler.codec.ByteToMessageDecoder.channelRead(ByteToMessageDecoder.java:318) [bundleFile:4.1.104.Final]
        at io.netty.channel.CombinedChannelDuplexHandler.channelRead(CombinedChannelDuplexHandler.java:251) [bundleFile:4.1.104.Final]
        at io.netty.handler.timeout.IdleStateHandler.channelRead(IdleStateHandler.java:286) [bundleFile:4.1.104.Final]
        at io.netty.channel.DefaultChannelPipeline$HeadContext.channelRead(DefaultChannelPipeline.java:1410) [bundleFile:4.1.104.Final]
        at io.netty.channel.AbstractChannelHandlerContext.invokeChannelRead(AbstractChannelHandlerContext.java:440) [bundleFile:4.1.104.Final]
        at io.netty.channel.DefaultChannelPipeline.fireChannelRead(DefaultChannelPipeline.java:919) [bundleFile:4.1.104.Final]
        at io.netty.channel.nio.AbstractNioByteChannel$NioByteUnsafe.read(AbstractNioByteChannel.java:166) [bundleFile:4.1.104.Final]
        at io.netty.channel.nio.NioEventLoop.processSelectedKey(NioEventLoop.java:788) [bundleFile:4.1.104.Final]
        at io.netty.channel.nio.NioEventLoop.processSelectedKeysOptimized(NioEventLoop.java:724) [bundleFile:4.1.104.Final]
        at io.netty.channel.nio.NioEventLoop.processSelectedKeys(NioEventLoop.java:650) [bundleFile:4.1.104.Final]
        at io.netty.channel.nio.NioEventLoop.run(NioEventLoop.java:562) [bundleFile:4.1.104.Final]
        at io.netty.util.concurrent.SingleThreadEventExecutor$4.run(SingleThreadEventExecutor.java:997) [bundleFile:4.1.104.Final]
        at io.netty.util.internal.ThreadExecutorMap$2.run(ThreadExecutorMap.java:74) [bundleFile:4.1.104.Final]
        at io.netty.util.concurrent.FastThreadLocalRunnable.run(FastThreadLocalRunnable.java:30) [bundleFile:4.1.104.Final]
This is my things
Thing ipcamera:hikvision:front "Front Camera" @ "Cameras"
    ipAddress="192.168.192.82", password="X",
    username="admin",
    serverPort=50001,
    ffmpegOutput="/tmpfs/front/",
    ffmpegInput="rtsp://admin:X@192.168.192.82/Streaming/channels/102",
	  hlsOutOptions="-strict -2 -acodec aac -vcodec copy -hls_flags delete_segments -hls_time 1 -hls_list_size 4"
//"-acodec aac -vcodec copy -hls_flags delete_segments"
Thing ipcamera:hikvision:pool "Pool Camera" @ "Cameras"
    ipAddress="192.168.192.86", password="X",
    username="admin",
    serverPort=50002,
    ffmpegOutput="/tmpfs/pool/",
	  ffmpegInput="rtsp://admin:X@192.168.192.86/Streaming/channels/102",
Thing ipcamera:hikvision:terrace "Terrace Camera" @ "Cameras"
    ipAddress="192.168.192.84", password="X",
    username="admin",
    serverPort=50003,
    ffmpegOutput="/tmpfs/terrace/",
	  ffmpegInput="rtsp://admin:X@192.168.192.84/Streaming/channels/101",
 Thing ipcamera:group:OutsideCameras "Group Display" @ "Cameras"
    pollTime=2000, serverPort=50000,
    ffmpegOutput="/tmpfs/OutsideGroup/",
    firstCamera="front",
    secondCamera="pool",
    thirdCamera="",
    forthCamera="",
    motionChangesOrder=true
Log before exception
2024-04-09 09:34:53.962 [TRACE] [g.ipcamera.internal.HikvisionHandler] - HTTP Result from /ISAPI/System/IO/capabilities contains        :<?xml version="1.0" encoding="UTF-8"?>
<IOCap  version="2.0" xmlns="http://www.hikvision.com/ver20/XMLSchema">
<IOInputPortNums>1</IOInputPortNums>
<IOOutputPortNums>1</IOOutputPortNums>
<isSupportStrobeLamp>false</isSupportStrobeLamp>
</IOCap>
2024-04-09 09:34:53.962 [WARN ] [netty.channel.DefaultChannelPipeline] - An exceptionCaught() event was fired, and it reached at the tail of the pipeline. It usually means the last handler in the pipeline did not handle the exception.
and that gives
2024-04-09 09:30:24.478 [TRACE] [g.ipcamera.internal.HikvisionHandler] - HTTP Result from /ISAPI/Event/notification/alertStream contains        :--boundary
Content-Type: application/xml; charset="UTF-8"
Content-Length: 539
<EventNotificationAlert version="2.0" xmlns="http://www.hikvision.com/ver20/XMLSchema">
<ipAddress>192.168.192.82</ipAddress>
<portNo>80</portNo>
<protocol>HTTP</protocol>
<macAddress>a4:14:37:6e:94:28</macAddress>
<channelID>1</channelID>
<dateTime>2024-04-09T09:30:24+01:00</dateTime>
<activePostCount>22</activePostCount>
<eventType>IO</eventType>
<eventState>active</eventState>
<eventDescription>IO alarm</eventDescription>
<inputIOPortID>1</inputIOPortID>
<channelName>Camera 01</channelName>
</EventNotificationAlert>
2024-04-09 09:30:24.478 [DEBUG] [g.ipcamera.internal.HikvisionHandler] - Unrecognised Hikvision eventType=IO
Thank you for reporting this. I have found and fixed the bug (thank you the info you provided made it quick and easy to find) and will upload a new build with today’s date on the zip file here once I have made some changes to it for another user having issues. Should be in a few hours time so wait till the ZIP with today’s date gets uploaded.
http://pcmus.com/openhab/IpCameraBinding/
Now it is working.
Hi @matt1, I have a question.
How can I see the ffmpeg log?
in trace log is see only
Starting ffmpeg with this command now: -hide_banner -loglevel warning -rtsp_transport tcp -i rtsp://ad......
but if it ended with error I don’t see the error.
how can I log the ffmpeg output?
Greets
First of all thank you for this great binding matt1.
I have still some problems with my Hikvision Cameras DS-2CD2346G2P-ISU/SL regarding switching on and off the field alarm or line crossing alarm during i´m home in openhab binding.
I have read the comments in the middle of the posts how to setup the user in hikvision setup but it is not working. Can someone help me out how to setup this in hikvision setup?
Maybe other users are also happy for this step by step setup.
  1. I have activated under “Integration protocol” ONVIF and activated Digest &ws username token in the hikvision setup.
  2. I added a user “xyz” as a role/user type “Betreiber/user”
  3. I added password and ticked all relevant items in the popup menu
  4. failed security logins are ticked off in hikvision setup
  5. I added in openhab binding the user “xyz” with the given passwd under onvif user.
Problem is that the camera is not switching on or off the alarm through openhab binding.
If field alarm happens open hab is showing this correctly under field detection alarm.
Also under hikvision setup the tick box is not following the switch under openhab if im setting the field alarm to on/off.
Maybe someone can give me a hint.
Thank you in advance.
log after on/off command:
11:15:54.943 [WARN ] [.ipcamera.internal.MyNettyAuthHandler] - 403 Forbidden: Check camera setup or has the camera activated the illegal login lock?
after finally migrating from Openhab 2.5 to 4.1.2 to get the “sendTelegramAnimation” functionality I was always looking forward to, I might have either a configuration, or an understanding issue in regards to the IP Camera Binding, installed via the UI.
My Dahua is configured:
Thing ipcamera:dahua:einfahrt "Camera Einfahrt"
    ipAddress="192.168.0.108",
    username="**********",
    password="**********",
    onvifPort=80,
    serverPort=54324,
    ffmpegLocation="/usr/bin/ffmpeg",
    ffmpegOutput="/etc/openhab/html/cameras/camera-einfahrt/",
    ffmpegInput="rtsp://192.168.0.108:554/cam/realmonitor?channel=1&subtype=2",
//    snapshotUrl="http://192.168.0.108:80/cgi-bin/snapshot.cgi?1", //big picture
    snapshotUrl="ffmpeg", //subtpe 2 small picture, 1 big picture
    pollTime=1000,
    gifPreroll=0,
    gifPostroll=3,
    updateImageWhen="0"
and the appropriate .items and .rules to have it utilized.
This will generate a GIF in the requested duration using
getActions("ipcamera", "ipcamera:dahua:einfahrt").recordGIF("ipcamera",5)
and I can see
Item 'Einfahrt_recordingGif' changed from 0 to 5
Item 'Einfahrt_recordingGif' changed from 5 to 0
in the log events.log
However, if I want to use the “gifPreroll” functionality (for example gifPreroll=3, ), I still get the
but the item will never change to “0”
If I use the camera-provided snapshot URL instead of the “ffmpeg” configuration (the one commented out in the .things shown above), gifPreroll is working as expected, setting “recordingGif” to 5 and then to 0 again, and providing images of the past…
But this will, in parallel to creating snapshot*.jpg files on my Openhab system, unfortunately also spam my NAS with snapshot images (one every 3-4 seconds) since the Dahua uses the “motion detection” setting also for manually triggered snapshots (and I need the motion-detection snapshots for security purposes).
So I’m wondering:
Is there something wrong with “ffmpeg” snapshots and gifPreroll not working when set?
Or some crucial parameter missing to make it work?
Or is this exactly as it should be, and gifPreroll will only work with the snapshot URL of the camera (with the downside of the camera generating snapshots also on the configured storage device).
Would be great if some could shed some light on the matter.
Thx, David
As this is my first post here, first of all my thanks for this great open source project including this great binding.
I have a problem with one of my cameras since I updated to 4.2.0.M3 (Build).
The camera stays in initializing state an does not go online.
After looking into the log I wonder why the binding tries to connect to port 80 and fails, as the configured http port is 8000.
Locking to my other camera that is working perfektly, I found that there the http port is the default port 80.
I seems to be a bug in the Milestone version and maybe I can help to clean it up before it comes to stable
First update to the latest from the jfrog server here as some changes got merged 3 weeks ago. Best to test with the latest code:
https://openhab.jfrog.io/artifactory/libs-snapshot-local/org/openhab/addons/bundles/org.openhab.binding.ipcamera/4.2.0-SNAPSHOT/org.openhab.binding.ipcamera-4.2.0-20240614.032510-140.jar
I would check with TRACE level logging to see if it turns up any more info. One thing I note here is that it does not appear the camera has given a snapshot or RTSP stream URLS.
What version were you using? Looking at what changed between then and now would be a good idea.
As for port 80 without knowing what the TRACE shows I can not comment more. ONVIF gives a reply with all of the Xaddress’ in it and the binding should follow the ports in each of the xadress’. Would need to check this reply comes back from the camera before the binding is making requests otherwise it would default to port 80.
2024-06-17 07:23:31.406 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found: IPCProfilesToken0
2024-06-17 07:23:31.408 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found: IPCProfilesToken1
2024-06-17 07:23:31.410 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request: GetSnapshotUri to http://192.168.178.33:8000/onvif/Media
2024-06-17 07:23:31.415 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request: GetStreamUri to http://192.168.178.33:8000/onvif/Media
2024-06-17 07:23:31.419 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request: GetNodes to http://192.168.178.33:8000/onvif/PTZ
2024-06-17 07:23:31.421 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request: GetEventProperties to http:///onvif/device_service
2024-06-17 07:23:31.424 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request: GetServiceCapabilities to http:///onvif/device_service
2024-06-17 07:23:31.434 [DEBUG] [amera.internal.onvif.OnvifConnection] - connect failed - cause Verbindungsaufbau abgelehnt: /192.168.178.33:80
2024-06-17 07:23:31.435 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request: Unsubscribe to http:///onvif/device_service
2024-06-17 07:23:31.442 [DEBUG] [amera.internal.onvif.OnvifConnection] - connect failed - cause Verbindungsaufbau abgelehnt: /192.168.178.33:80
2024-06-17 07:23:31.463 [TRACE] [amera.internal.onvif.OnvifConnection] - ONVIF reply is: <?xml version="1.0" encoding="UTF-8"?>
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://www.w3.org/2003/05/soap-envelope" xmlns:SOAP-ENC="http://www.w3.org/2003/05/soap-encoding" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:chan="http://schemas.microsoft.com/ws/2005/02/duplex" xmlns:wsa5="http://schemas.xmlsoap.org/ws/2004/08/addressing" xmlns:c14n="http://www.w3.org/2001/10/xml-exc-c14n#" xmlns:wsu="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd" xmlns:xenc="http://www.w3.org/2001/04/xmlenc#" xmlns:wsc="http://docs.oasis-open.org/ws-sx/ws-secureconversation/200512" xmlns:ds="http://www.w3.org/2000/09/xmldsig#" xmlns:wsse="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd" xmlns:xmime="http://tempuri.org/xmime.xsd" xmlns:xop="http://www.w3.org/2004/08/xop/include" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:wsrfbf="http://docs.oasis-open.org/wsrf/bf-2" xmlns:wstop="http://docs.oasis-open.org/wsn/t-1" xmlns:wsrfr="http://docs.oasis-open.org/wsrf/r-2" xmlns:tds="http://www.onvif.org/ver10/device/wsdl" xmlns:tev="http://www.onvif.org/ver10/events/wsdl" xmlns:trt="http://www.onvif.org/ver10/media/wsdl" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:timg="http://www.onvif.org/ver20/imaging/wsdl" xmlns:tmd="http://www.onvif.org/ver10/deviceIO/wsdl" xmlns:tptz="http://www.onvif.org/ver20/ptz/wsdl" xmlns:tns1="http://www.onvif.org/ver10/topics" xmlns:ter="http://www.onvif.org/ver10/error"><SOAP-ENV:Header></SOAP-ENV:Header>
<SOAP-ENV:Body><trt:GetSnapshotUriResponse><trt:MediaUri><tt:Uri>http://www.gwelltimes.com/manage/Upload/Pic/20147914514701.jpg</tt:Uri>
<tt:InvalidAfterConnect>false</tt:InvalidAfterConnect>
<tt:InvalidAfterReboot>false</tt:InvalidAfterReboot>
<tt:Timeout>PT0S</tt:Timeout>
</trt:MediaUri>
</trt:GetSnapshotUriResponse>
</SOAP-ENV:Body>
</SOAP-ENV:Envelope>
… here’s the interessting part of the trace. Hope this helps. I will try the latest shnapshot and give you the feedback
My last working release was 4.1.3 (latest stable) and I switched to the milestone release because of another binding bug (Tapo)
I used to connect through onvif (port 8000) and that stopped working with the latest snapshot. I believe that it tries to authenticate in a way that is not supported. Did you activate “Use API Token”?
Hi there, not sure if that is really related to the ipcamera binding, but since I manually installed the jar from the snapshot I run into heapspace issues after a few hours:
2024-06-17 16:37:57.773 [WARN ] [era.internal.handler.IpCameraHandler] - !!! Camera possibly closed the channel on the binding, cause reported is: Java heap space
I increased it, let’s see if that helps or if it just cures the symprtpoms for a bit longer.
Is it possible that there is a memory leak somewhere?
