The cam works with RTSPS.
From Unifi Protect i just get a URL like this:
rtsps://192.168.1.1:7441/abcdefghijklmnop?enableSrtp
How do i have to enter it to the IpCam Binding?
When i fill in the url in the field MJPEG URL i just get errors.
But when i test the connection in the cli of the docker container openhab is running in, it seems like the url an the connection is ok:
root@d01:/openhab# ffmpeg -i rtsps://192.168.1.1:7441/abcdefghijklmnop?enableSrtp -t 5 -f null -
ffmpeg version 5.1.6-0+deb12u1 Copyright (c) 2000-2024 the FFmpeg developers
built with gcc 12 (Debian 12.2.0-14)
configuration: --prefix=/usr --extra-version=0+deb12u1 --toolchain=hardened --libdir=/usr/lib/x86_64-linux-gnu --incdir=/usr/include/x86_64-linux-gnu --arch=amd64 --enable-gpl --disable-stripping --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libdav1d --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libglslang --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librabbitmq --enable-librist --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libsrt --enable-libssh --enable-libsvtav1 --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzimg --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opencl --enable-opengl --enable-sdl2 --disable-sndio --enable-libjxl --enable-pocketsphinx --enable-librsvg --enable-libmfx --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --enable-libplacebo --enable-librav1e --enable-shared
libavutil 57. 28.100 / 57. 28.100
libavcodec 59. 37.100 / 59. 37.100
libavformat 59. 27.100 / 59. 27.100
libavdevice 59. 7.100 / 59. 7.100
libavfilter 8. 44.100 / 8. 44.100
libswscale 6. 7.100 / 6. 7.100
libswresample 4. 7.100 / 4. 7.100
libpostproc 56. 6.100 / 56. 6.100
Input #0, rtsp, from 'rtsps://192.168.1.1:7441/abcdefghijklmnop?enableSrtp':
Metadata:
title Fxxxxxxxxx_0
Duration: N/A, start: 0.000000, bitrate: N/A
Stream #0:0: Audio: aac (LC), 16000 Hz, mono, fltp
Stream #0:1: Audio: opus, 48000 Hz, stereo, fltp
Stream #0:2: Video: h264 (Main), yuvj420p(pc, bt709, progressive), 2688x1512, 30 fps, 30 tbr, 90k tbn
Stream mapping:
Stream #0:2 -> #0:0 (h264 (native) -> wrapped_avframe (native))
Stream #0:1 -> #0:1 (opus (native) -> pcm_s16le (native))
Press [q] to stop, [?] for help
Output #0, null, to 'pipe:':
Metadata:
title : Fxxxxxxxxx_0
encoder : Lavf59.27.100
Stream #0:0: Video: wrapped_avframe, yuvj420p(pc, bt709, progressive), 2688x1512, q=2-31, 200 kb/s, 30 fps, 30 tbn
Metadata:
encoder : Lavc59.37.100 wrapped_avframe
Stream #0:1: Audio: pcm_s16le, 48000 Hz, stereo, s16, 1536 kb/s
Metadata:
encoder : Lavc59.37.100 pcm_s16le
frame= 149 fps= 36 q=-0.0 Lsize=N/A time=00:00:05.00 bitrate=N/A speed=1.21x
video:69kB audio:938kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: unknown
And this is one configuration i tried as example:
Thing ipcamera:generic:MeineUnifiKamera "Meine UniFi Kamera" [
ipAddress="192.168.1.1",
port=7441,
ffmpegInput="rtsps://192.168.1.1:7441/abcdefghijklmnop?enableSrtp",
snapshotUrl="ffmpeg",
ffmpegInputOptions="-rtsp_transport tcp"
