You were right, it was the “Notify Surveillance Centre” option that had become unticked. The camera I’m working on at the moment is a Hikvision DS-2CD2085FWD-I and upgrading it to V5.6.0 build 190507 seems to have reset a few configuration parameters. I’ve upgraded the firmware on it several times before and not had this issue.
I’ve also configured my rules to use Pushover instead of Telegram and this allows me to see the animated GIFs. It does look like only a single frame of an animated GIF is supported by Telegram, either in the binding or on the mobile/desktop client.
In case this helps anyone else my camera intrusion detection rule currently looks like this:
rule "Create front door camera GIF when front door camera intrusion detected"
Item CameraFrontDoor_IntrusionAlarm changed from OFF to ON
logInfo("Dev", "Front door camera intrusion detected, triggering camera GIF creation...")
sendPushoverMessage(pushoverBuilder("Front door intrusion alarm triggered..."))
CameraFrontDoor_CreateAnAnimatedGIF.sendCommand(ON)
rule "Send front door camera GIF via Telegram"
Item CameraFrontDoor_CreateAnAnimatedGIF changed from ON to OFF
sendPushoverMessage(pushoverBuilder("Sending GIF from front door").withAttachment("/etc/openhab2/html/tmpfs/ipcamera.gif"))
New ability for all brands to now turn off updating the IMAGE channel so you can instead use the new url to fetch the ipcamera.jpg
I have been noticing a jump in CPU usage when I add extra cameras which does not make sense. This jump stems from the Openhab backend and how it handles the image, so if you turn this off you gain more CPU back as you add in extra cameras. It should also stop the event.log getting spammed if you are not filtering out the image event updating.
Brands which use event streams now have a different way to handle idle channels and it will create a warning when the stream is not staying open.
Because the binding has a new CONFIG parameter, it is necessary to delete and re-add your cameras if you are not using textual config. If you setup the cameras with a things file (well done) this happens magically when you reboot making your life easier.
Everyone should clean the cache and tmp folders as with every change to the addons folder.
@higgers
Thanks for sharing your rules I’m sure people will find them useful and it shows how much simpler it is instead of using thread:sleep to wait for files to be created. Just one tip, that is controls are set to UNDEF when Openhab reboots, so I would change your rule to be the following otherwise it may not work on the first alarm after a reboot.
CameraFrontDoor_IntrusionAlarm changed to ON
I would leave the second rule as is because I will at some stage make any errors in creating the GIF set the control to UNDEF to stop rules like that from triggering if an error occurs.
@matt1 can you give some info about the new IMAGE channel update feature? How to turn off? Also i have rebooted, using things files only, but i don’t see any changes or new CONFIG parameter..
Did you clean and cache and tmp folders and then reboot? This is a must otherwise the older version is in the cache and explains why u see nothing.
It is a new switch that can be made false by adding this to things file.
UPDATE_IMAGE=false
Drops cpu usage by more than half so it is a big change.
Yesy i cleared cache etc. the jar file is from 26-06-2019:11:27 so it is the latest one.. Don’t know why but after adding the UPDATE_IMAGE=false to each camera it stops updating the image channel, so it’s the new release already. But the updateImageNow channel doesn’t work anymore; shouldn’t this update the image channel?
I also discovered that there is wrong translation of passowrds with special characters like i.e. “!” (exclamation mark). It is being translated to “%21%21”
I also tried to get PTZ working with my FOSCAM cameras without success so far I guess the above issue may be part of the problem.
Things are configured like:
This shows that the binding could not find a network connection to use that was considered ‘site local’ or something went wrong when checking this condition. The 0.0.0.0 means it may still work if you just use the url with the IP of your openhab server as the binding has connected to all available network connections. Did you get a warning or error in the logs?
So a single ! gets converted to double %21 ? if so then that is an issue to look at as it should convert to a single %21 What platform are you running Openhab on, is it mac?
It may be related to the PTZ issue but I doubt it. PTZ is handled by an onvif library which I did not write and has not been updated in many years, there are a few newer java libraries being written but they do not support PTZ yet. You can get a lot more info as to what is wrong if you turn on debug or trace level logs when the camera is first connecting. Without the log I cant comment on what is wrong.
Maybe I need to change things so feel free to give feedback but currently that is how it will operate. If you turn off the image it will not update and the update image now channel will only start and stop the fetching of the snapshot from the camera every poll period.
The binding defaults to always fetching a snapshot and that channel will do nothing unless you play with the image update events option. There are now three controls which effect snapshot or image channel.
Unfortunately the name of the controls is set unless I make a breaking change to rename them which I am not keen on.
No that is not currently possible unless you also stop the snapshots from being fetched.
I wish openhab had a three way switch. NONE, snapshot only, snapshot and image being the three states. But it currently does not hence why I’m trying to find an easy to understand way that works for all people…
New Update image config stops all image updates and no way to turn them back on.
Existing updateImageNow channel will start and stop the snapshot fetching into ram from the camera, and if the update Image config is on it starts and stops the image then, however when the channel is off you also loose snapshots which halt two features from working..
preroll for gif creation
URL snapshot which I only just added.
One way I could change it is to repurpose the new config to select what the updateimagenow channel starts up on when Openhab is restarted. Then turn the updateimagenow control to start and stop the image and leave the snapshot getting fetched the entire time. If you edit the choices in the Update-snapshot/Image when config drop down list you can then turn off the snapshot fetching via this control.
If you have an idea let me know as I am happy to change it whilst the feature is new and not many people have installed the newer version of the binding.
No sorry, it’s my mistake, there should be !! that is %21%21. Why this is translated this way? Is this a result of conversion of url address string to URI compliant form?
What do you mean by “site local” ? I will review TRACE log for this.
@zacofunny
New build 2019-06-28 now uploaded to fix a bug in the ONVIF connection if you used special characters in the user or pass. Only effected Foscam users.
Correct you can not have a space or certain characters in a URL and if you enter them in a browser it will do the conversion for you before sending to the camera. If the binding gets a snapshot it will be working, if it is not working then please let me know but that so far looks normal and is not a bug unless it fails to work.
Site local is a network that can not be reached from the web without port forwarding. Ie 192.168.0.xxx range is site local which it appears your using that for your network so it is interesting that this occurred which is why I asked if you were using Mac or what platform openhab is running on?
2019-06-29 23:28:45.188 [WARN ] [ing.ipcamera.handler.IpCameraHandler] - Following NPE occured when trying to connect to the camera with ONVIF.java.lang.NullPointerException
2019-06-29 23:28:45.191 [ERROR] [ing.ipcamera.handler.IpCameraHandler] - Since an NPE occured when asking the camera about PTZ, the PTZ controls will not work. If the camera does not come online, give the camera the wrong ONVIF port number so it can bypass using ONVIF and still come online.
2019-06-29 23:28:45.207 [INFO ] [ing.ipcamera.handler.IpCameraHandler] - IP Camera at 192.168.178.34:80 is now online.
2019-06-29 23:28:45.293 [INFO ] [ing.ipcamera.handler.IpCameraHandler] - IpCamera file server for camera 192.168.178.34 has started on port 50001
What can I do to get the PTZ working? That would be the most important thing for me. Thanks in advance
You will need to make sure only 1 version is in the folder at a time and after changing the contents of the addons folder you will need to clean the cache and tmp folders and reboot.
I have only ever seen this once with my cameras and it was caused by using 1.4.0 version of that file.
Also posting the output from your logs in TRACE mode that shows a single camera connecting would also be helpful to look into it. The readme has info on log modes.
13:52:21.743 [DEBUG] [ding.ipcamera.handler.IpCameraHandler] - Fetching the number of Media Profiles this camera supports.
13:52:24.812 [DEBUG] [ding.ipcamera.handler.IpCameraHandler] - Checking the selected Media Profile is a valid number.
13:52:24.816 [DEBUG] [ding.ipcamera.handler.IpCameraHandler] - Fetching a Token for the selected Media Profile.
13:52:24.820 [DEBUG] [ding.ipcamera.handler.IpCameraHandler] - Auto fetching the snapshot URL for the selected Media Profile.
13:52:27.963 [DEBUG] [ding.ipcamera.handler.IpCameraHandler] - About to fetch some information about the Media Profiles from the camera
13:52:27.967 [DEBUG] [ding.ipcamera.handler.IpCameraHandler] - *********** Media Profile 0 details reported by camera at IP:192.168.178.34 ***********
13:52:27.970 [DEBUG] [ding.ipcamera.handler.IpCameraHandler] - Camera will use this Media Profile unless you change it in the bindings settings.
13:52:27.973 [INFO ] [ding.ipcamera.handler.IpCameraHandler] - This can be used to stream HLS with low CPU overhead
13:52:27.976 [DEBUG] [ding.ipcamera.handler.IpCameraHandler] - Media Profile 0 is named:VideoEncoder_1
13:52:27.980 [DEBUG] [ding.ipcamera.handler.IpCameraHandler] - Media Profile 0 uses video encoder :H_264
13:52:27.983 [DEBUG] [ding.ipcamera.handler.IpCameraHandler] - Media Profile 0 uses video quality :10.0
13:52:27.987 [DEBUG] [ding.ipcamera.handler.IpCameraHandler] - Media Profile 0 uses video resoltion :1920 x 1080
13:52:27.990 [DEBUG] [ding.ipcamera.handler.IpCameraHandler] - Media Profile 0 uses video bitrate :0
13:52:27.993 [DEBUG] [ding.ipcamera.handler.IpCameraHandler] - *********** Media Profile 1 details reported by camera at IP:192.168.178.34 ***********
13:52:27.997 [INFO ] [ding.ipcamera.handler.IpCameraHandler] - This can be used to stream HLS with low CPU overhead
13:52:28.000 [DEBUG] [ding.ipcamera.handler.IpCameraHandler] - Media Profile 1 is named:VideoEncoder_2
13:52:28.003 [DEBUG] [ding.ipcamera.handler.IpCameraHandler] - Media Profile 1 uses video encoder :H_264
13:52:28.006 [DEBUG] [ding.ipcamera.handler.IpCameraHandler] - Media Profile 1 uses video quality :10.0
13:52:28.009 [DEBUG] [ding.ipcamera.handler.IpCameraHandler] - Media Profile 1 uses video resoltion :640 x 360
13:52:28.012 [DEBUG] [ding.ipcamera.handler.IpCameraHandler] - Media Profile 1 uses video bitrate :0
13:52:28.015 [DEBUG] [ding.ipcamera.handler.IpCameraHandler] - About to interrogate the camera to see if it supports PTZ.
13:52:33.715 [DEBUG] [ding.ipcamera.handler.IpCameraHandler] - Camera is reporting that it supports PTZ control with Absolute movement via ONVIF
13:52:33.719 [DEBUG] [ding.ipcamera.handler.IpCameraHandler] - Checking Pan now.
13:52:39.172 [WARN ] [ding.ipcamera.handler.IpCameraHandler] - Following NPE occured when trying to connect to the camera with ONVIF.java.lang.NullPointerException
13:52:39.176 [ERROR] [ding.ipcamera.handler.IpCameraHandler] - Since an NPE occured when asking the camera about PTZ, the PTZ controls will not work. If the camera does not come online, give the camera the wrong ONVIF port number so it can bypass using ONVIF and still come online.
13:52:39.180 [DEBUG] [ding.ipcamera.handler.IpCameraHandler] - Sending camera GET: http://192.168.178.34:80/onvif/snapshot
13:52:39.197 [TRACE] [.ipcamera.internal.MyNettyAuthHandler] - MyNettyAuthHandler is now setup for GET:/onvif/snapshot
13:52:39.200 [DEBUG] [ding.ipcamera.handler.IpCameraHandler] - Have opened a brand NEW channel:0 GET:/onvif/snapshot
13:52:39.206 [INFO ] [ding.ipcamera.handler.IpCameraHandler] - IP Camera at 192.168.178.34:80 is now online.
13:52:39.212 [DEBUG] [ding.ipcamera.handler.IpCameraHandler] - commonCameraHandler closed channel:0 URL:/onvif/snapshot
13:52:39.221 [INFO ] [ding.ipcamera.handler.IpCameraHandler] - IpCamera file server for camera 192.168.178.34 has started on port 50001
14:27:02.099 [hingStatusInfoChangedEvent] - 'ipcamera:ONVIF:001' changed from INITIALIZING to OFFLINE (CONFIGURATION_ERROR): Camera failed to report a valid Snaphot URL, try over-riding the Snapshot URL auto detection by entering a known URL.
Hi! I’v updated binding to the new one and verified with one of my Foscam cameras. I still get 0.0.0.0 streamURL address and can’t find where is problem. I tried to use streamURL item in Image Widget (Openhab String Item) in habpanel but it doesn’t work. To make it work I need to directly put the address to the camera stream as string e.g. http://192.168.1.171:54322/ipcamera.mjpeg.
I’ve also checked if TILT and PAN works and… it works, however… after setting slider in habpanel i need to wait ~30 seconds for a reaction. I’ve enabled TRACE log and it can’t find there anything wrong.ZOOM doesn’t work at all. My Foscam cameras are all FI9826P models. Here is some loge from TILT and PAN and ZOOM.
I am just adding a note here in relation to this binding and Sricam IP Cam (SP012). I’ve spent way to much time trying to get OH2 to talk to the camera and I don’t believe it works at all. I have OH2 on a Raspberry Pi 3.
Using the Onvif settings I can get it to detect the camera and it can see it online but I can get a snapshot to display at all, I’ve tried multiple variations but nothing. I know its a cheap camera but I’ve started out with it and has served a purpose.
I initially had issues with the camera being detected, getting the error “OFFLINE - COMMUNICATION_ERROR”. Once I added an overwrite URL for the snapshot or streaming this changed to online. I tried to repeat this but it doesn’t come back so I am not sure what caused it to change the 1st time.
I tried to to find URLs online where OH2 could take a snap shot from and grab a stream but everything I found didn’t work.
None of the URL suggestions work. I also added the camera to MotionEye which works fine cause its using RTSP. Once the camera was added it gave me the below URLs for snapshots and a stream. Again none of these work when I put them into a browser, I assumed the video might not but since a browser can render images that they should appear. No responses to all these.
The only way I can get a stream from the camera is with rtsp://192.168.0.110:554/onvif1 via VLC or as mentioned through MotionEye. Anyhing that supports RTSP.
I had a a look online and I can see OH2 doesn’t support RTSP yet so I think its not going to happen.
Hopefully this info is helpful to someone and they don’t waste as much time as I did.
Think I’ll buy a new camera since I prefer OH2 over Home Assistant.
re: 0.0.0.0 I would need to add some more logging to narrow down why it happens, but as you mention if you use the Openhab servers IP instead of the 0.0.0.0 it should still work.
Re delay on PTZ, yes I get around 8 seconds here on mine so some delay is to be expected but if it is really 30 seconds I would suggest you look at what the poll time is setup for the camera as it will wait until the next poll time before it starts to process the new location. If you have a 20 second poll time selected it will move faster if you drop that value down. I just looked at the logs and it appears the 3 location values are not set all at the same time? Are you just moving them manually? When set all at the same time in a rule they should all move at the same time after around 8-10 seconds if you camera behaves the same as mine. The readme has an example rule and how I setup buttons to make a camera jump to a set location.
@spudatron
Yes the binding needs a snapshot to determine if the camera is online or not so without one the camera will stay offline, otherwise you could use it for casting the cameras with HLS as these come from a rtsp source. I would personally get a better camera as the other features in the firmwares are very useful depending on your use case. You could work around it using a script or using the command action to call ffmpeg to generate snapshots or a non stop stream for openhab to use. This would use the rtsp feed as the source…
This will chew your CPU which wont be much for a snapshot. The other option would be to use a Pi and the motion software to keep the rtsp stream alive and generate what you need and would give you decent movement detection and more..
