Ir blaster HOME AUTOMATION wiwo orvibo & S20
@Pavel_Cherezov Thanks for your reply, I use Raspian Jessie on Raspberry PI 2. I’m using python v3.4.2.
Bye
Hello @Pavel_Cherezov! Thank you so much for developing the Python script! I am using it to control my irda device but i cannot record rf signals (I am using the same command as for grabbing ir code). I am trying to control a livolo switch that works on 433.92 mhz. do you have any suggestions? thank you!
hi danielwalters86,
i m really interested by the support of AllOne on OH2 but I m a noob :cry:
could you explain me a little bit more how i must configure the binding?
the device and item are ok but no reaction on AllOne when learn is activated…
many thanks for your interest
If I remember correctly, you need to set the file name in the learn channel and then activate the learn mode on the AllOne. The IR code should then be saved to the file you specified.
When you want to emit an IR code you specify the name to the emit channel.
If that still doesn’t work maybe at some point I’ll get back round to looking at it again.
Thanks for your answer!
if i well understand, the binding doesn’t able to change the state of the allone.
Hi Andrei!
Sorry for the late answer, but I have to disappoint you cause AllOne supports Orvibo SmartSwitch RF signal only. So, you can’t use orvibo script to control any other device.
Thanks for trying the script and have a good day!
Sorry, but I have no chance to investigate the problem.
But I remember about it :slight_smile:
Hope it is not a showstopper for you.
Thanks!
Hey…
I am also facing the same problem. I am using Openhabian and not able to execute lsof as its missing.
secondly not able to locate openhab.cfg to edit it…
Please guide…
Hey, where i can find openhab.cfg in OpenHAB3? Or should i search for another file where i can put TCP - UDP Binding?
