I build an ESP8266 IR Blaster based on Tasmota to find that there is not a lot of information about the codes that have to be used for my equipment. As numerous people before me I decided to read the codes coming from my RC. Hopefully they come in hand for someone.
I will extend the list over time as I gather more info.
Octava HD41-ARC 4 xl HDMIARC+Toslink
| HDMI input 1 | {"Protocol":"NEC","Bits":32,"Data":"0x00DF48B7","DataLSB":"0x00FB12ED","Repeat":0} | |
| HDMI input 2 | {"Protocol":"NEC","Bits":32,"Data":"0x00DF7887","DataLSB":"0x00FB1EE1","Repeat":0}} | |
| HDMI input 3 | {"Protocol":"NEC","Bits":32,"Data":"0x00DF807F","DataLSB":"0x00FB01FE","Repeat":0} | |
| HDMI input 4 | {"Protocol":"NEC","Bits":32,"Data":"0x00DFC03F","DataLSB":"0x00FB03FC","Repeat":0} | |
| HDMI input up | {"Protocol":"NEC","Bits":32,"Data":"0x00DF58A7","DataLSB":"0x00FB1AE5","Repeat":0} | |
| HDMI input down | {"Protocol":"NEC","Bits":32,"Data":"0x00DF40BF","DataLSB":"0x00FB02FD","Repeat":0} | |
| Audiosource HDMI | {"Protocol":"NEC","Bits":32,"Data":"0x00DF20DF","DataLSB":"0x00FB04FB","Repeat":0} | |
| Audiosource Optical | {"Protocol":"NEC","Bits":32,"Data":"0x00DFA05F","DataLSB":"0x00FB05FA","Repeat":0} | |
| Audiosource ARC | {"Protocol":"NEC","Bits":32,"Data":"0x00DF609F","DataLSB":"0x00FB06F9","Repeat":0} | |
| Optical select 1 | {"Protocol":"NEC","Bits":32,"Data":"0x00DFE01F","DataLSB":"0x00FB07F8","Repeat":0} | |
| Optical select 2 | {"Protocol":"NEC","Bits":32,"Data":"0x00DF906F","DataLSB":"0x00FB09F6","Repeat":0} | |
| Optical select 3 | {"Protocol":"NEC","Bits":32,"Data":"0x00DF50AF","DataLSB":"0x00FB0AF5","Repeat":0} | |
| Optical select 4 | {"Protocol":"NEC","Bits":32,"Data":"0x00DFF807","DataLSB":"0x00FB1FE0","Repeat":0} | |
| Optical select up | {"Protocol":"NEC","Bits":32,"Data":"0x00DF10EF","DataLSB":"0x00FB08F7","Repeat":0} | |
| Optical select down | {"Protocol":"NEC","Bits":32,"Data":"0x00DFD827","DataLSB":"0x00FB1BE4","Repeat":0} | |
| ON/OFF | {"Protocol":"NEC","Bits":32,"Data":"0x00DF30CF","DataLSB":"0x00FB0CF3","Repeat":0} | |
| AUX | {"Protocol":"NEC","Bits":32,"Data":"0x00DFB04F","DataLSB":"0x00FB0DF2","Repeat":0} | |
| LED | {"Protocol":"NEC","Bits":32,"Data":"0x00DF708F","DataLSB":"0x00FB0EF1","Repeat":0} |
