I’m stuck in setting up the IrTrans binding.
I would like to control my Epson projector using IrTrans.
I believe IRTrans is set up correctly. I can power on/off, play/pause/… using these links:
http://192.168.3.14/send.htm?remote=Epson&command=Power
http://192.168.3.14/send.htm?remote=Epson&command=Pause
http://192.168.3.14/send.htm?remote=Epson&command=Play
http://192.168.3.14/send.htm?remote=Epson&command=Stop
I’ve installed the IrTrans-binding (OpenHAB 2.1).
I have created the following items:
Switch IRtrans_EV_Ontspanningsruimte_Projector "Epson Projector Aan/Uit" <projector_benq> (gEV_Ontspanningsruimte, gIRtrans) { irtrans="[ON:192.168.3.14:3000:*:Epson:Power]" }
Switch IRtrans_EV_Ontspanningsruimte_Projector_PlayPause "Epson Projector Play/Pause" <projector_benq> (gEV_Ontspanningsruimte, gIRtrans) { irtrans="[ON:192.168.3.14:3000:*:Epson:Pause]" }
As soon as I save the .items file, my openhab.log starts generating the following entries:
2017-05-11 15:42:31.176 [INFO ] [ing.tcp.AbstractSocketChannelBinding] - Attempting to reconnect the channel for /192.168.3.14:3000
2017-05-11 15:42:31.207 [WARN ] [ing.tcp.AbstractSocketChannelBinding] - The channel java.nio.channels.SocketChannel[closed] has encountered an unknown IO Exception: Connection refused
2017-05-11 15:42:35.207 [INFO ] [ing.tcp.AbstractSocketChannelBinding] - Attempting to reconnect the channel for /192.168.3.14:3000
I’m not sure where to go from here or how to troubleshoot it…
Any help would be great!
