Hi Martin,
yes I checked the suggestions. I use “login with password and username” with a user only for openhab.
Before the upgrade there where no log entries like this.
Interesting is that everything works well. I can switch DECT!200 and get some information (temperatur) without delay.
Thank you,
Greetings
Marc
very interesting. Can you tell me a little bit more about your setup? Which FRITZ! devices do you use? Can you please activate the DEBUG logging level for the binding and post an abstract of the complete request and response, if available?
Thanks.
Hi Guy,
I guess it was my fault.
I have two Fritzbox (7490) in my environment. To control the DECT stuff, I only use one of them, the second one works as a W-LAN Access Point. The second one was discovered and in my things list, but offline. With openhab 2.0, there was no log entry, but now openhab try to login also to the second one, and this is the reason for the warnings in the log file.
I remove the thing for the second Fritzbox and the log entry disappear.
Sorry for confusion,
many greetings
Marc
