I’ve this binding defined as a thing:
KNX/IP Gateway - This is a KNX IP interface or router
I want to restart this “Thing” with scripting, can i do it with rule files or any other script ?
What do you mean by „restarting“?
enable/disable
At the moment you can do that by using the REST API
In the rules you can use the sendHttpGetRequest action to call the API
thanks, exactly what I was looking for.I did it this way:
Enable:
curl -X PUT --header “Content-Type: text/plain” --header “Accept: application/json” -d “true” “http://192.168.1.100/rest/things/knx:ip:bridge/enable”
Disable:
curl -X PUT --header “Content-Type: text/plain” --header “Accept: application/json” -d “false” “http://192.168.1.100/rest/things/knx:ip:bridge/enable”
