I’m trying to integrate our old ABB IP-Router IPR/S2.1 of which is set as ROUTER.
Everything works fine on most of our KNX device except that I can’t send GA values to KNX secure devices.
So far the keyring and password has been set but stil no success on sending the GA Values.
Now I’m figuring out whether you should need a KNX SECURE compatible router or a normal router is also possible to work(if the latter is possible, great, but can you share the setting I might need to set)
