I’m very new to openHAB, more at the looking at it and testing proof of concept.
I’m having issues that I thought was me not knowing enough getting data (temps etc) to show up in openHAB. I was happily making sense of everything until I started wondering.
I have a win 10 SFF PC (don’t hate me ) on 192.168.1.162 (static IP) with Mosquitto and Openhab working on it. A tasmota device is talking to the MQTT server, and I can see that data using MQTT-SPY on my PC and on the ‘server’. Tasmota’s console is showing data going to the MQTT server.
I assumed it was down to a mis-configuration and I’ve been working my way thru it, with a view to understanding it better… I thought I’d look at the (openHAB) logs to see if there was anything obvious.
I got ; "
> 22:14:26.337 [INFO ] [o.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to '192.168.1.162' with clientid fffbe576-441a-4ef7-93d2-04e58993d0c6
> 22:15:26.354 [INFO ] [t.reconnect.PeriodicReconnectStrategy] - Try to restore connection to '192.168.1.162'. Next attempt in 60000ms
> 22:15:26.354 [INFO ] [o.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to '192.168.1.162' with clientid fffbe576-441a-4ef7-93d2-04e58993d0c6
Does this denote an openHAB to MQTT connection issue? Resulting in my not getting any data to openHAB?
I ask this before I start posting the broker connection and things to this chat.
Yep, this sounds like an issue communicating with Mosquitto. In general, it’s better to just post any config/settings that you suspect to be a problem in your first post. If you’re on the right track, you’ll get a faster response (and others don’t have to ask for them).
You should have gotten this template when you started your message. You answered most of it, but following the layout really does help us to help you (even if you just answer “I don’t know” to some things). In particular, I don’t know which version of OH you’re on, and don’t want to assume it’s OH3.
Platform information:
Hardware: CPUArchitecture/RAM/storage
OS: what OS is used and which version
Java Runtime Environment: which java platform is used and what version
openHAB version:
Issue of the topic: please be detailed explaining your issue
Please post configurations (if applicable):
Items configuration related to the issue
Sitemap configuration related to the issue
Rules code related to the issue
Services configuration related to the issue
If logs where generated please post these here using code fences:
Java Runtime Environment: which java platform is used and what version [Azul Zulu] as per openHAB pre-requsites.
openHAB version: Version 3. As downloaded 1 week ago.
Please post configurations (if applicable): Please correct me if I’ve missed anything, but since it’s initally a openHAB to MQTT issue, I’m just post that broker if that’s ok? Seem’s better the flooding you with pages and pages.
I don’t know if anything else is relavent. I understand the need for comprehensive information to assist me, but I don’t fully know what is needed, and I’m doing this all from the UID. Hope it’s good?
openhab> log:clear
openhab> log:display
00:07:27.579 [INFO ] [t.reconnect.PeriodicReconnectStrategy] - Try to restore co nnection to '192.168.1.162'. Next attempt in 60000ms
00:07:27.579 [INFO ] [o.transport.mqtt.MqttBrokerConnection] - Starting MQTT bro ker connection to '192.168.1.162' with clientid fffbe576-441a-4ef7-93d2-04e58993 d0c6
00:08:27.584 [INFO ] [t.reconnect.PeriodicReconnectStrategy] - Try to restore co nnection to '192.168.1.162'. Next attempt in 60000ms
00:08:27.584 [INFO ] [o.transport.mqtt.MqttBrokerConnection] - Starting MQTT bro ker connection to '192.168.1.162' with clientid fffbe576-441a-4ef7-93d2-04e58993 d0c6
openhab>
It’s worth noting, possibly, I set this up so far using the tutorial’s on openHAB. everything was default apart from names and IP’s. There is no security at the moment.
I think the thing that’s caused confusion is that the web page says the broker is on-line. I guess that means the connection is turned on, not communicating.
For sure. As you say, the tricky part is that you don’t know what’s needed. But when you provide something/anything, it shows us that you’re willing and able to meet us halfway. And as I said before, sometimes the solution is almost immediate (though that doesn’t seem like it’ll be the case here).
Which tutorials? I was just going to ask if you set up username/password in your Mosquitto broker.
For reference, here’s what my broker connection looks like (with user/pass omitted):
Update after an hour of changes (remember to remove the # from mosquitto.conf!!)
I’ve setup a username and password as suggested. and set the line allow_anonymous false (was true) to disallow anonymous entrys
I’m now getting
2021-01-26T17:39:51: New client connected from 192.168.1.162:55600 as openHAB (p2, c1, k60, u'mosquitto_admin')..
from $SYS$/# topic.
This looks good. After some struggle I seem to have the Tasmota client talking to Mosquitto and the openHAB talking to mosquitto as well. An openHAB is now showing Data! Yea!
