I upgraded from OH 4.2.1 to 4.2.2 (using apt on RPi 3B+ Linux openhabian 6.6.51+rpt-rpi-v7 #1 SMP Raspbian 1:6.6.51-1+rpt2 (2024-10-01) armv7l GNU/Linux). I have IPv6 disabled by adding ipv6.disable=1 to /boot/firmware/cmdline.txt
Apart from needing to clear the OH cache to get everything working, the following lines were repeated in journalctl:
Oct 04 10:54:07 openhabian NetworkManager[550]: <warn> [1728003247.2260] ipv6ll[29b0824b1690267d,ifindex=3]: changed: no IPv6 link local address to retry after Duplic>
Oct 04 10:54:43 openhabian NetworkManager[550]: <warn> [1728003283.3768] platform-linux: do-add-ip6-address[3: fe80::ffe8:9ed1:96f8:9a18]: failure 95 (Operation not s>
Oct 04 10:54:45 openhabian NetworkManager[550]: <warn> [1728003285.3799] platform-linux: do-add-ip6-address[3: fe80::14bd:d6ba:4d2b:cc3f]: failure 95 (Operation not s>
Oct 04 10:54:47 openhabian NetworkManager[550]: <warn> [1728003287.3828] platform-linux: do-add-ip6-address[3: fe80::3538:26cd:b969:e724]: failure 95 (Operation not s>
Oct 04 10:54:49 openhabian NetworkManager[550]: <warn> [1728003289.3859] platform-linux: do-add-ip6-address[3: fe80::117e:5f74:d5bc:1573]: failure 95 (Operation not s>
Oct 04 10:54:51 openhabian NetworkManager[550]: <warn> [1728003291.3895] platform-linux: do-add-ip6-address[3: fe80::da06:cfe0:d38e:f9b]: failure 95 (Operation not su>
Oct 04 10:54:53 openhabian NetworkManager[550]: <warn> [1728003293.3926] platform-linux: do-add-ip6-address[3: fe80::3ea8:d1db:7a83:d1e7]: failure 95 (Operation not s>
Oct 04 10:54:55 openhabian NetworkManager[550]: <warn> [1728003295.3934] ipv6ll[29b0824b1690267d,ifindex=3]: changed: no IPv6 link local address to retry after Duplic>
and OH would not complete startup.
If I enabled IPv6 and rebooted, OH4.2.2 would startup OK.
Is this the expected behaviour?
