HI,
I have installed 2.5.11.202012190142
and restarted OH2. But there was only one volume channel and it did not work. Hence, I have deleted the Epson thing, restarted OH2 and create new thing for Epson. But this time there is no Volume channel at all and warning
2020-12-19 12:29:58.304 [WARN ] [ore.internal.thing.ThingTypeResource] - Cannot find channel type: epsonprojector:volume
2020-12-19 12:29:58.344 [WARN ] [ore.internal.thing.ThingTypeResource] - Cannot find channel type: epsonprojector:volume
2020-12-19 12:30:08.766 [WARN ] [re.thing.internal.ThingFactoryHelper] - Could not create channel 'volume' for thing type 'epsonprojector:projector-tcp:1d58e6d8', because channel type 'epsonprojector:volume' could not be found.
2020-12-19 12:30:08.843 [hingStatusInfoChangedEvent] - 'epsonprojector:projector-tcp:1d58e6d8' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_CONFIGURATION_PENDING)
2020-12-19 12:30:16.913 [WARN ] [ore.internal.thing.ThingTypeResource] - Cannot find channel type: epsonprojector:volume
In addtion seems there is a confusion between Source
and AspectRatio
channels. I can not change Source and it displays always 30
. And I can see a constant changes as follows:
2020-12-19 12:53:16.337 [vent.ItemStateChangedEvent] - EpsonAspectRatio changed from NORMAL to 30
2020-12-19 12:53:16.639 [vent.ItemStateChangedEvent] - EpsonAspectRatio changed from 30 to NORMAL
2020-12-19 12:53:27.955 [vent.ItemStateChangedEvent] - EpsonAspectRatio changed from NORMAL to 30
2020-12-19 12:53:28.353 [vent.ItemStateChangedEvent] - EpsonAspectRatio changed from 30 to NORMAL
2020-12-19 12:53:39.974 [vent.ItemStateChangedEvent] - EpsonAspectRatio changed from NORMAL to 30
2020-12-19 12:53:40.268 [vent.ItemStateChangedEvent] - EpsonAspectRatio changed from 30 to NORMAL
Let me know if I shall restart OH2 again and provide you with DEBUG level log?
PS: I wonder, maybe you can’t have 2 different Volume channels at the same time and the binding shall be changed to choose mapping type /or projector at bridge level?
