Is there a problem with the build system on openhabian?
I’m getting this on building a binding:
mvn clean install -X -pl :org.openhab.binding.denonmarantz
[INFO] ------------------------------------------------------------------------
[INFO] BUILD FAILURE
[INFO] Total time:  49.965 s
[INFO] Finished at: 2024-03-18T22:27:21+01:00
[ERROR] Failed to execute goal biz.aQute.bnd:bnd-maven-plugin:7.0.0:bnd-process (default) on project org.openhab.binding.denonmarantz: The plugin biz.aQute.bnd:bnd-maven-plugin:7.0.0 requires Maven version 3.8.1 -> [Help 1]
org.apache.maven.lifecycle.LifecycleExecutionException: Failed to execute goal biz.aQute.bnd:bnd-maven-plugin:7.0.0:bnd-process (default) on project org.openhab.binding.denonmarantz: The plugin biz.aQute.bnd:bnd-maven-plugin:7.0.0 requires Maven version 3.8.1
    at org.apache.maven.lifecycle.internal.MojoExecutor.execute (MojoExecutor.java:172)
    at org.apache.maven.lifecycle.internal.MojoExecutor.execute (MojoExecutor.java:156)
    at org.apache.maven.lifecycle.internal.MojoExecutor.execute (MojoExecutor.java:148)
    at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject (LifecycleModuleBuilder.java:117)
    at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject (LifecycleModuleBuilder.java:81)
    at org.apache.maven.lifecycle.internal.builder.singlethreaded.SingleThreadedBuilder.build (SingleThreadedBuilder.java:56)
    at org.apache.maven.lifecycle.internal.LifecycleStarter.execute (LifecycleStarter.java:128)
    at org.apache.maven.DefaultMaven.doExecute (DefaultMaven.java:305)
    at org.apache.maven.DefaultMaven.doExecute (DefaultMaven.java:192)
    at org.apache.maven.DefaultMaven.execute (DefaultMaven.java:105)
    at org.apache.maven.cli.MavenCli.execute (MavenCli.java:957)
    at org.apache.maven.cli.MavenCli.doMain (MavenCli.java:289)
    at org.apache.maven.cli.MavenCli.main (MavenCli.java:193)
    at jdk.internal.reflect.NativeMethodAccessorImpl.invoke0 (Native Method)
    at jdk.internal.reflect.NativeMethodAccessorImpl.invoke (NativeMethodAccessorImpl.java:77)
    at jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke (DelegatingMethodAccessorImpl.java:43)
    at java.lang.reflect.Method.invoke (Method.java:568)
    at org.codehaus.plexus.classworlds.launcher.Launcher.launchEnhanced (Launcher.java:282)
    at org.codehaus.plexus.classworlds.launcher.Launcher.launch (Launcher.java:225)
    at org.codehaus.plexus.classworlds.launcher.Launcher.mainWithExitCode (Launcher.java:406)
    at org.codehaus.plexus.classworlds.launcher.Launcher.main (Launcher.java:347)
Caused by: org.apache.maven.plugin.PluginIncompatibleException: The plugin biz.aQute.bnd:bnd-maven-plugin:7.0.0 requires Maven version 3.8.1
    at org.apache.maven.plugin.internal.DefaultMavenPluginManager.checkRequiredMavenVersion (DefaultMavenPluginManager.java:309)
    at org.apache.maven.lifecycle.internal.MojoExecutor.execute (MojoExecutor.java:168)
[ERROR]
[ERROR]
[ERROR] For more information about the errors and possible solutions, please read the following articles:
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/PluginIncompatibleException
openhabian@openhabian:~/openhab-addons $ git status
On branch main
Your branch is up to date with 'origin/main'.
Untracked files:
  (use "git add <file>..." to include in what will be committed)
	bundles/org.openhab.binding.mhiaircon/ <-that's the stuff I'm developing
nothing added to commit but untracked files present (use "git add" to track)
openhabian@openhabian:~/openhab-addons $ runtime
Version:     4.1.1 (Build)
running    1-03:31:50
openhabian fully updated and upgraded.
Edit: my knowledge of maven is near zero, but that used to work a while ago.
Looks like you need to install a more recent Maven version.
openHABian is the OS to run openHAB but not meant to be a development platform.
Thank you! I think the last time I was actually compiling on a fedora machine and then copying the binding file over to the openhabian.
