In OH 2 I had a camera stream displayed on the surface in HABPanel and switched it to full screen when motion was detected. Is this also possible in the OH 3 UI at the moment?
HABpanel works in V3 so you can move across and still use your panels as per normal, however I would move towards building anything new in the main UI and not using habpanel anymore. Basically anything you can do in habpanel the new UI will be able to do plus more, however there are less ready made widgets for the new UI and it is very new and not many people playing with widget creation yet.
