Hi all,
As the title says, is there a way to switch off prediction Ed state? Either globally or per item?
Thank you,
Ramon
Hi all,
Thank you,
Ramon
set autoupdate
to false
Switch YourItemName "YourItemLabel" { channel="a:b:c:d", autoupdate="false" }
Thank you, this is exactly what I was looking for, unfortunately it does not appear to work?!?
Its an ikea zigbee rollershutter. I have this definition now:
Rollershutter Blind1WindowCover (gBlind1, gWindowCover) {channel="zigbee:device:01381834:84fd27fffe6f763c:84FD27FFFE6F763C_1_windowcoveringlift", autoupdate="false" }
Any idea?
What do you see in your events log?
This:
2025-03-04 21:24:11.617 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Blind1WindowCover' received command 75
2025-03-04 21:24:12.312 [INFO ] [openhab.event.ItemStateEvent ] - Item 'Blind1WindowCover' shall update to 75
2025-03-04 21:24:12.313 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item 'Blind1WindowCover' updated to 75
2025-03-04 21:24:12.313 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Blind1WindowCover' changed from 70 to 75
2025-03-04 21:24:13.329 [INFO ] [openhab.event.ItemStateEvent ] - Item 'Blind1WindowCover' shall update to 72
2025-03-04 21:24:13.329 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item 'Blind1WindowCover' updated to 72
2025-03-04 21:24:13.330 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Blind1WindowCover' changed from 75 to 72
2025-03-04 21:24:14.342 [INFO ] [openhab.event.ItemStateEvent ] - Item 'Blind1WindowCover' shall update to 74
2025-03-04 21:24:14.343 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item 'Blind1WindowCover' updated to 74
2025-03-04 21:24:14.343 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Blind1WindowCover' changed from 72 to 74
2025-03-04 21:24:15.346 [INFO ] [openhab.event.ItemStateEvent ] - Item 'Blind1WindowCover' shall update to 75
2025-03-04 21:24:15.347 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item 'Blind1WindowCover' updated to 75
2025-03-04 21:24:15.347 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Blind1WindowCover' changed from 74 to 75
I pressed the +5% button, so it commanded to 75 (from 70). You see it jumps to 75 then gets a status update to 72, then 74 finally it reaches 75.
It is likely the device (rollershutter) is sending periodic updates every second while moving. Are there any device parameters that can be adjusted? That doesn’t look like autoupdate. Typically autoupdate logs say “Predicted…”
indeed, it giving updates while moving, which is fine, actually great, but i dont want to get the initial “shall update to 75” and “updated to 75”. I just want to get actual values, not commanded values.
This is probably bad advice coming from someone who has disabled the event log entirely, but you could disable those items in the log4j2.xml file. Just keep the ItemStateChangedEvent
That just disables the logging, but then still on my UI it jumps around. That is actually what I want to fix. My guess is that maybe in the binding it is handled wrongly.
Is there not maybe a option that tells the binding that the channel does not update instantaneously?
Beyond my knowledge, Sorry
This is the Zigbee binding, correct? If so, you’d have to ask @chris. Maybe it depends on the Zigbee device as well?
This is the reporting from the zigbee device. You should be able to adjust the reporting time on most channels - it’s a configuration on the channel, but it’s not on all channels at the moment.
If this doesn’t exist on the channel, let me know and I’ll take a look when I get a chance (might be a few weeks as I’m travelling at the moment).
yes zigbee
I am not sure what cluster and attribute to add to the zigbee reportcfg command. So not sure how to check.
You don’t need to know this - as I said above this should be configurable on the channel itself.
Do you mean these:
channels:
- id: 84FD27FFFE6F763C_1_batterylevel
channelTypeUID: system:battery-level
label: Battery Level
configuration:
zigbee_reporting_polling: 7200
- id: 84FD27FFFE6F763C_1_windowcoveringlift
channelTypeUID: zigbee:windowcovering_lift
label: Window Covering Lift
configuration:
zigbee_reporting_polling: 900
- id: 84FD27FFFE6F763C_1_batteryalarm
channelTypeUID: zigbee:battery_alarm
label: Battery Alarm
configuration:
- id: 84FD27FFFE6F763C_1_batteryvoltage
channelTypeUID: zigbee:battery_voltage
label: Battery Voltage
configuration:
there does not appear to be anything useful there?
@chris i still have the issue. Any idea?
