I have a rule which I want to run where it updates the sitemap light switches if a member of the gLights group goes OFFLINE (or ONLINE). In other words, if I switch the light off at the wall rather than through a software method.
The syntax for getting the status of each light is pretty straight forward:
var status = ThingAction.getThingStatusInfo("uid").getStatus()
And I guess I could create 17 different rules to update each light independently, but it felt like there must be an easier way for when/if a light gets replaced/removed/added or the thing uid changes for any reason.
For now, this is what i’ve come up with, but I believe it’s using the item name rather than the item UID in the status var which returns an error:
[ERROR] [.script.engine.ScriptExecutionThread] - Rule 'Light Offline Switch Update': Could not invoke method: org.eclipse.smarthome.model.script.actions.ThingAction.getThingStatusInfo(java.lang.String) on instance: null
rule "Light Offline Switch Update"
Item gLights received update
logInfo("Light Status", "Updating Light switch states")
gLights?.members.forEach[light|
var status = ThingAction.getThingStatusInfo(light).getStatus()
logInfo("Light UID Changed:",light.name + "UID:" + uid.toString())
if(status.toString() == "OFFLINE"){
light.sendCommand(OFF)
logInfo("Light Status",light.name + "Switch state updated" + status.toString())
else {
light.sendCommand(ON)
Would one option be to run a bash/php script which extracts the gLights item uid’s from the REST api as an array/list and then does the status check before the rules engine even sees it? I’m not savvy enough with this approach to know where to begin.
Anyone got any bright ideas?
