Is there any way to get the old OH4.3 Matter Binding Working again?
Hello everyone! I’m running an rPi 3b+ and was delighted to get openhab 4.3’s matter bridge setup with my old yamaha stereo so i could turn it on via google assistant. After an update, the matter plugin (which worked perfectly) was marked as deprecated and ceased working. After a lot of investigating it seems that the 3b+ has really no chance of being able to run openhab 5. I have so far, exactly one need, which was already working until the plugin self-destructed. Is there any chance I can just get the last working version of the matter plugin .jar file? I understand the “non-marketplace” method of install might allow me to get it working. However, I spent a long time searching, and can’t find anywhere to download it. Thank you in advance!
Of course, not long after I post this, i find something! Was able to download this jar and manually place it in the addon’s folder, and it appears to work!
https://community.openhab.org/t/matter-binding-marketplace-deprecated/161138/507?u=frankjp
All previous versions are also available from JFrog
It can be a pain to navigate to find what your after if your not used to it. Also if you download a KAR or a JAR, these are just ZIP files, you can rename them and open in any zip program. You’re able to open up the KAR that has all addons in it and pull out just a single addons JAR file. I dont know where the link to the offline all bindings KAR is but you should be able to find it. So there are a number of ways to go back to just about any point in openHAB history if you wish.
