Islamic Prayers - Time calculations and rules with audio and video
What is the difference between Time cron “0 2 0 ? * * *” and “0 2 0 * * ?”
None
You can check with:
Well, I was again tinkering with the rule and found, that all of the performance issues came from the auto(un)boxing of objects vs. primitive types. I got rid of almost all of the .doubleValue stuff and am back to a 10sec precompile time.
That is very interesting. So the problem was the use of primitives. I usually recommend against using primitives where possible but never imagined that it would have that big of a performance impact. Really good to know. Thanks for coming back to post this.
I have downloaded the script and testing it out. Been away for a while due to ramadhan and syawal. Great to know Vincent have shared the code to all. May I know the codes in GitHub - vzorglub/Openhab2-Prayer-Times: Islamic prayer times calculation and items and rules for OpenHAB2 has been updated with the enhancement as per comments above? It looks like the code was last updated 2 months ago. I will try it out anyway
For my case in Malaysia have to use a custom method 18 degrees for Isyak, dan 20 degrees for subuh. I have check the actual timing on Prayertimes.org and there are a 1 or two minutes difference but good enough for me as I am using this for switching of fans and ptz cameras for recording of daily speech. Will let you know how t works out.
The original code at the top of the thread still works. I have changed mine according to @rlkoshak at it works fine except when the system starts at 6pm say and 4 timers go off and it tries to play 4 prayers at the same time…
I have not tried the calculation OH code yet.
The original code worked fine for 6 months or so before I published.
You can tweak the times in the sccript config
That is odd and unexpected and clearly wrong. There is a fundamental bug here but I’m too far away from the code now to easily find why that would be the case. Let me know if you want some help finding where I went wrong.
Yes please,
It happens every time system started occurs
So everytime I change item files of rules of it goes…
When System started does it immediately plays all four prayers, or is there a delay and then it plays all four? Does it play the four in sequence or in parallel? Does it work correctly all other times?
I know I had some typos in the code I posted above. Can you post the latest version you are working with just to ensure that we are looking at the same thing?
It plays all in parallel depending on the time of day, if 2 of 3 prayers in the day have triggered already it will play 2 or three.
It works perfectly, it’s just on system started.
It does it after a small delay. I think it’s the first rule that gets the values from the python script and then populates the timers. The timers then trigger because the time has already elapsed…
The code:
import java.util.Map
import java.util.HashMap
import org.eclipse.xtext.xbase.lib.Functions
val Map<String, Timer> timers = new HashMap<String, Timer> //createHashMap
// Converts HH:MM to a DateTimeType for today
val Functions$Function1<String, DateTimeType> toDateTimeType = [ hhmm |
    val hours = Integer::parseInt(hhmm.split(":").get(0))
    val mins = Integer::parseInt(hhmm.split(":").get(1))
    // Jumps to tomorrow midnight and substract to avoid problems at daylight saving changes
    val timerTime = now.withTimeAtStartOfDay.plusDays(1).minusHours(24-hours).plusMinutes(mins)
    new DateTimeType(timerTime.toString)
// Create a Timer that sendCommand to trigger with cmd at the passed in time
val Procedures$Procedure5<Map<String, Timer>, String, DateTimeType, String, String> createPrayerTimer = [ timers, key, time, trigger, cmd |
    val timerTime = new DateTime(time.getZonedDateTime.toInstant.toEpochMilli)
    timers.get(key)?.cancel
    timers.put(key, createTimer(timerTime, [ |
        sendCommand(trigger, cmd)
        timers.put(key, null)
val Procedures$Procedure2<Map<String, Timer>, String> prayerTrigger = [ timers, prayer |
     if (House_HomeAway.state.toString == "home") {
        var prayerDuration = if(prayer == "Fajr") 178 else 98
        var String soundFile = if(prayer == "Fajr") "adhanfajr.mp3" else "adhan.mp3"
        var String topic = if(prayer == "Fajr") "Misc/PrayerTriggerFajr" else "Misc/PrayerTrigger"
        if (LivingRoom_TVON.state == ON) {
            if ((LivingRoom_TVSource.state.toString == "HDMI1") || (LivingRoom_TVSource.state.toString == "HDMI-CEC")) {
                if (timers.get("prayerDuration") === null) {
                    // save the current states of hte TV and Lights Items
                    val tvStates = storeStates(LivingRoom_TVSource, LivingRoom_TVVolume)
                    publish("mybroker", topic, "ON")
                    Thread::sleep(2600)
                    SkyBox.sendCommand("pause")
                    LivingRoom_TVRemoteKey.sendCommand("KEY_PAUSE")
                    LivingRoom_TVSource.sendCommand("AV")
                    LivingRoom_TVVolume.sendCommand(65)
                    //LivingRoom_TVLightLeft_Colour.sendCommand(new HSBType(new DecimalType(25), new PercentType(100), new PercentType(80)))
                    //LivingRoom_TVLightLeft_Level.sendCommand(100)
                    timers.put("prayerDuration", createTimer(now.plusSeconds(prayerDuration), [ |
                        restoreStates(tvStates)
                        SkyBox.sendCommand("play")
                        LivingRoom_TVRemoteKey.sendCommand("KEY_PLAY")
                        timers.put("prayerDuration", null)
        } else {
            playSound(soundFile)
// Update the prayer start times based on the result of the Python script
rule "prayer times"
    Time cron "0 2 0 * * ?" or
    System  started
    var String PT = executeCommandLine("python /etc/openhab2/scripts/prayertimes.py", 5000)
    PrayerTime_Fajr.postUpdate(toDateTimeType.apply(transform("JSONPATH", "$.fajr", PT)))
    PrayerTime_Zuhr.postUpdate(toDateTimeType.apply(transform("JSONPATH", "$.dhuhr", PT)))
    PrayerTime_Asr.postUpdate(toDateTimeType.apply(transform("JSONPATH", "$.asr", PT)))
    PrayerTime_Maghrib.postUpdate(toDateTimeType.apply(transform("JSONPATH", "$.maghrib", PT)))
    PrayerTime_Isha.postUpdate(toDateTimeType.apply(transform("JSONPATH", "$.isha", PT)))
// Reset the timers when a prayer time is updated
rule "Prayer time updated"
    Member of PrayerTimes received update
    val prayer = triggeringItem.name.split("_").get(1)
    createPrayerTimer.apply(timers, prayer, triggeringItem.state, "PrayerTime_PrayerTrigger", prayer)
    val prayerTime = new DateTime((triggeringItem.state as DateTimeType).getZonedDateTime.toInstant.toEpochMilli)
    val beforePrayerMins = BeforePrayerMinutes.members.findFirst[ min | min.name == "PrayerTime_MinutesBefore" + prayer]
    val afterPrayerMins = AfterPrayerMinutes.members.findFirst[ min | min.name == "PrayerTime_MinutesAfter" + prayer]
    if (beforePrayerMins !== null) {
        val time = new DateTimeType(prayerTime.minusMinutes((beforePrayerMins.state as Number).intValue).toString)
        createPrayerTimer.apply(timers, "before" + prayer, time, "PrayerTime_BeforePrayerTrigger", prayer)
    if (afterPrayerMins !== null) {
        val time = new DateTimeType(prayerTime.plusMinutes((afterPrayerMins.state as Number).intValue).toString)
        createPrayerTimer.apply(timers, "after" + prayer, time, "PrayerTime_AfterPrayerTrigger", prayer)
// Fajr is handled differently
rule "Fajr"
    Item PrayerTime_PrayerTrigger received command "Fajr"
    if (PrayerTime_PlayEarlyAdhan.state == ON) {
        if (now.getHourOfDay() >= (PrayerTime_EarlyAdhanTime.state as Number)) {
            prayerTrigger.apply(timers, receivedCommand.toString)
rule "Prayer Trigger other times"
    Item PrayerTime_PrayerTrigger received command "Zuhr" or
    Item PrayerTime_PrayerTrigger received command "Asr" or
    Item PrayerTime_PrayerTrigger received command "Maghrib" or
    Item PrayerTime_PrayerTrigger received command "Isha"
rule "Before Maghrib"
    Item PrayerTime_BeforePrayerTrigger received command "Maghrib"
    PrayerTime_MaghribPeriod.postUpdate(ON)
    PrayerTime_MaghribLightsTrigger.sendCommand(ON)
rule "After Maghrib"
    Item PrayerTime_AfterPrayerTrigger received command "Maghrib"
    PrayerTime_MaghribPeriod.postUpdate(OFF)
    PrayerTime_MaghribLightsTrigger.sendCommand(OFF)
rule "Maghrib Lights"
    Item PrayerTime_MaghribLightsTrigger received command
        MaghribLights.sendCommand(receivedCommand)
Oh, so on system started is plays all the prayers that have occurred so far for that day in parallel. That narrows things down significantly.
I bet this is exactly the case. And the fix is really simple.
    // Only create a Timer if the time is in the future
    if(timerTime.isAfter(now)) {
Yep, that worked, thanks
I am having a problem .The value that I set did not work. Using Egypt method with Angle fajr 20 degrees and isha 18 degrees
prayTimes = PrayTimes(‘Egypt’)
prayTimes.adjust( {‘highLats’:‘AngleBased’, ‘fajr’: 20, ‘isha’: 18 } );
times = prayTimes.getTimes(date.today(), (3.054543,101.765242,0), timeZoneOffset);
print times;
{‘isha’: ‘13:41’, ‘asr’: ‘09:44’, ‘sunset’: ‘12:27’, ‘dhuhr’: ‘06:19’, ‘maghrib’: ‘12:27’, ‘imsak’: ‘22:38’, ‘midnight’: ‘18:19’, ‘sunrise’: ‘00:11’, ‘fajr’: ‘22:48’
the time that I should get is
|Fajr|5:49 am|
|Sunrise|7:11 am|
|Dhuhr|1:20 pm|
|Asr|4:44 pm|
|Maghrib|7:28 pm|
|Isha|8:42 pm|
There is a bug with the ime zone that I didn’t have a problem with because I am in time zone 0.
It looks like you are 5 hours off so change this:
times = prayTimes.getTimes(date.today(), (3.054543,101.765242,0), 5);
Change the last digit until you get the correct times for your time zone
ok. Thanks, it worked… I am learning up python now and will probably add some additional code to support Malaysia calculation method. For now I am adding a new method but still testing it.
methods = {
‘MWL’: {
‘name’: ‘Muslim World League’,
‘params’: { ‘fajr’: 18, ‘isha’: 17 } },
‘ISNA’: {
‘name’: ‘Islamic Society of North America (ISNA)’,
‘params’: { ‘fajr’: 15, ‘isha’: 15 } },
‘Egypt’: {
‘name’: ‘Egyptian General Authority of Survey’,
‘params’: { ‘fajr’: 19.5, ‘isha’: 17.5 } },
‘Makkah’: {
‘name’: ‘Umm Al-Qura University, Makkah’,
‘params’: { ‘fajr’: 18.5, ‘isha’: ‘90 min’ } }, # fajr was 19 degrees before 1430 hijri
‘Karachi’: {
‘name’: ‘University of Islamic Sciences, Karachi’,
‘params’: { ‘fajr’: 18, ‘isha’: 18 } },
‘Tehran’: {
‘name’: ‘Institute of Geophysics, University of Tehran’,
‘params’: { ‘fajr’: 17.7, ‘isha’: 14, ‘maghrib’: 4.5, ‘midnight’: ‘Jafari’ } }, # isha is not explicitly specified in this method
‘Jafari’: {
‘name’: ‘Shia Ithna-Ashari, Leva Institute, Qum’,
‘params’: { ‘fajr’: 16, ‘isha’: 14, ‘maghrib’: 4, ‘midnight’: ‘Jafari’ } },
‘Malaysia’: {
‘name’: ‘Jakim Malaysia, Malaysia’,
‘params’: { ‘fajr’: 20, ‘isha’: 18 } }
I am a bit confused, I new new to OH, creating rules and items. I tried to follow the tutorial and going thru all the comments and improvement suggestions and I am lost. Correct me if i am wrong please check whether all the files are correct , I am using raspberry pi.
Additional question How do I display the solat time in the UI?
File created as per the tutorial
For Directory
/etc/openhab2/items/
prayertimes.items
For Directory /etc/openhab2/rules
magriblight-timeChange.rules
prayertimes-check.rules
prayertimes.rules
pray.rules
for Directory /etc/openhab2/scripts
adhan.py
prayertimes.py
for Directory /etc/openhab2/transform
maghriblight.js
Am I good to go?
You really did a good job with this algortithm; https://prayertimes.dawateislami.net/pk/karachi/872996
It’s not mine.
The python algorithm credits are in the code, but thanks
If you like Multiroom Audio System than you should check Squeezebox with Logitech Media Server in OH2 and get some Airplay speakers. Playing Adhan in all rooms makes another feeling like in a Mosque :slight_smile:
Great work to the developer.
How can i visualize the prayer times on the habpanel can someone give me an advise?
