Hello everyone,
I’ve created a widget using the following YAML code (see below). However, I’ve run into a styling issue. My goal is to have the label (currently set to display “wwww” as default) align directly after the icon in the header. However, it’s rendering on the far left instead of immediately following the icon.
Here’s the YAML configuration:
uid: widget_newlayout
tags: []
props:
parameters:
- description: A text prop
label: Prop 1
required: false
type: TEXT
- context: item
description: An item to control
label: Item
required: false
type: TEXT
parameterGroups: []
timestamp: Nov 13, 2024, 8:54:06 AM
component: oh-context
constants:
widgetID: =Number.parseInt(Math.random()*8912).toString(16).padStart(4, '0')
slots:
default:
- component: f7-card
style:
background-color: "=props.bgcolor ? props.bgcolor : ''"
box-shadow: 5px 5px 10px 1px rgba(0,0,0,0.1)
height: 150px
margin-left: 5px
margin-right: 5px
noShadow: false
padding: 0px
slots:
header:
- component: f7-icon
f7: alarm
style:
margin-right: 0px
visible: true
- component: Label
style:
font-size: 12px
margin-left: -20px
text: "=props.title ? props.title : 'wwww'"
content:
- component: Label
text: "=props.header ? props.header : 'Set Props'"
style:
font-size: 16px
color: "#555555"
font-weight: 600
- component: oh-slider
item: BrightnessItem
min: 0
max: 100
step: 1
unit: "%"
style:
--f7-range-bar-border-radius: 8px
--f7-range-bar-size: 8px
--f7-range-knob-box-shadow: 0 2px 4px rgba(0, 0, 0, 0.3)
--f7-range-knob-size: 20px
width: calc(100% - 40px)
footer:
- component: f7-row
style:
width: 100%
slots:
default:
- component: oh-button
text: Szene 1
action: command
actionCommand: =props.Scene1Value
actionItem: =props.SceneGroupItem
visible: true
style:
width: 30%
text: Szene 2
action: command
actionCommand: =props.Scene2Value
visible: true
style:
width: 30%
popupOpen: =`.popup-${const.widgetID}`
iconF7: gear_alt
style:
width: 30%
Question
I’d like to understand why the label “wwww” doesn’t align directly after the f7-icon
component in the header, even though I’ve set the margin-left of the label to -20px
. I suspect there might be something off with either the label’s styling or layout configuration.
Any insights or suggestions on how to get the label positioned immediately after the icon would be greatly appreciated!
Thank you!
