Issue with rule coming from openhab 1 -> 2
I’ve been using openhab1 for a couple years now and really love it. Recently I decided it was finally time to upgrade to openhab2 and I’m running into an issue with changing toDateMidnight() to toDateTimeAtStartOfDay()
I had the following rule in OH1 to give me some daily min/max temps:
rule "Update Nest Temperature Min- and Max values"
        Item  living_room_ambient_temperature_f received update
        var Number Min
        var Number Max
        var String tmp
        var SimpleDateFormat df = new SimpleDateFormat( "hh:mm a" )
        if (living_room_ambient_temperature_f.state instanceof DecimalType) {
            Min = (living_room_ambient_temperature_f.minimumSince(now.toDateMidnight, "rrd4j").state as DecimalType)
            tmp = (Math::round(Min.floatValue*10.0)/10.0) + " °F (" + df.format(living_room_ambient_temperature_f.minimumSince(now.toDateMidnight, "rrd4j").timestamp) + ")"
            postUpdate(living_room_ambient_temperature_f_Min, tmp)
            Max = living_room_ambient_temperature_f.maximumSince(now.toDateMidnight, "rrd4j").state as DecimalType
            tmp = (Math::round(Max.floatValue*10.0)/10.0) + " °F (" + df.format(living_room_ambient_temperature_f.maximumSince(now.toDateMidnight, "rrd4j").timestamp) + ")"
            postUpdate(living_room_ambient_temperature_f_Max, tmp)
When I moved it to OH2 I received a warning about “toDateMidnight()” being depreciated in my log. Google lead me to the following page where they say to replace it with “toDateTimeAtStartOfDay()”:
http://joda-time.sourceforge.net/apidocs/org/joda/time/LocalDate.html#toDateTimeAtStartOfDay(org.joda.time.DateTimeZone)
I did so, and now the rule read like this (included line numbers so you can match to the line provided by the error to come):
 821 rule "Update Nest Temperature Min- and Max values"
 822     when
 823         Item  living_room_ambient_temperature_f received update
 824     then
 825         var Number Min
 826         var Number Max
 827         var String tmp
 828         var SimpleDateFormat df = new SimpleDateFormat( "hh:mm a" )
 829
 830
 831
 832         if (living_room_ambient_temperature_f.state instanceof DecimalType) {
 833             Min = (living_room_ambient_temperature_f.minimumSince(now.toDateTimeAtStartOfDay, "rrd4j").state as DecimalType)
 834             tmp = (Math::round(Min.floatValue*10.0)/10.0) + " °F (" + df.format(living_room_ambient_temperature_f.minimumSince(now.to
 835             postUpdate(living_room_ambient_temperature_f_Min, tmp)
 836             Max = living_room_ambient_temperature_f.maximumSince(now.toDateTimeAtStartOfDay, "rrd4j").state as DecimalType
 837             df = new SimpleDateFormat( "hh:mm a" )
 838             tmp = (Math::round(Max.floatValue*10.0)/10.0) + " °F (" + df.format(living_room_ambient_temperature_f.maximumSince(now.to
 839             postUpdate(living_room_ambient_temperature_f_Max, tmp)
 840         }
 841     end
However I now get the following error in my openhab.log:
2018-01-04 18:38:54.307 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Update Nest Temperature Min- and Max values': 'toDateTimeAtStartOfDay' is not a member of 'org.joda.time.DateTime'; line 833, column 67, length 26
Does anyone have any idea how to fix this?
The method toDateTimeAtStartOfDay isn’t in the org.joda.time.DateTime class, but instead is in the org.joda.time.LocalDate class.
The method you want is withTimetStartOfDay. Or something like that. On my phone so it isn’t easy to look up.
Thanks for the quick reply!
I tried adding:
import org.joda.time.LocalDate
to my rules file and I still get the error. Is there something I should be importing or otherwise doing to fix this error?
Found it:
Thanks!
Hey tommycw10,
Can you instruct me on where I can find openhab 1 by chance?
I am afraid you won’t. We are just about to release openHAB 4.2.
Support for openHAB 1.x has stopped some years ago.
At least I could send you some zip files with the latest stable versions (runtime, addons…) still on my file server, somewhere…
Would that make sense?
Starting with openHAB 1 nowadays?
Yes, that will be fine. I just wanted an older version to run some test on it. In regards to vulnerabilities and other aspect.
You will not be able to compare vulnerabilities between openHAB 1 and 4.
Many things have changed, even Java version to run openHAB (8 → 17).
I’d second @hmerk’s comment. OH has changed so much since 1.8 that any comparisons between it and OH 4 would be meaningless. You might get some useful comparisons between OH 2.5 and 4.
I understand the changes and that is a given. This is more so for research purposes.
