I’m trying to create a composite Homekit device from a Z-Wave smoke/heat/temperature sensor.
If I try to assign TemperatureSensor
, SmokeSensor
and Battery
Homekit accessory types to either the Equipment or the Group item through the UI, then most of the times the UI does nothing. Only once I saw the different accessory settings emerge from the accessory types selected, but eventually only dummy items are created. Updating the group member assignments for the Homekit characteristics does nothing, I have to create them by adding the related metadata to every single item in the Equipment’s Items.
Is this a know issue with oH3.4?
For what it’s worth, the JavaScipt console returns 2 TypeErorr
s:
TypeError: undefined is not an object (evaluating 'Gn[n].forEach')
