- Platform information:
- Hardware: Intel x64
- OS: FreeNAS 12 with a FreeBSD Jail 12.2
- Java Runtime Environment: openjdk-11
- openHAB version: 3.0
- Issue of the topic: I have problems settings up my ZigBee USB Dongle CC2531.
I have some Xiaomi temperature sensors which I would like to connect to my fresh brand new openHAB 3 installation. I have just downloaded opneHAB3, created a FreeNAS Jail, applied devfs rules, connected my USB CC2531 ZigBee stick with my NAS and followed the openHAB tutorial. Currently I am stuck here: Adding Things - Intermediate | openHAB
For preparation I have flashed my CC2531 device following this tutorial: ZigBee - Bindings | openHAB
The CC2531 device is also visible in my jail as /dev/cuaU0.
How do I want to install the CC2531 thing in OpenHAB3?
- Click on THINGS
- Click ok +
- Chose
CC2531EMK Coordinator - Setup correct Port and save.
Afterwards I get the following error message:
Status:
UNINITIALIZED
HANDLER_INITIALIZING_ERROR
Task java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask@5ffb0d6c[Not completed, task = java.util.concurrent.Executors$RunnableAdapter@5503661c[Wrapped task = org.openhab.binding.zigbee.handler.ZigBeeCoordinatorHandler$$Lambda$1428/0x000000107e578040@5bc492cc]] rejected from org.openhab.core.internal.common.WrappedScheduledExecutorService@348be867[Terminated, pool size = 0, active threads = 0, queued tasks = 0, completed tasks = 1]
openhab.log
2021-01-23 12:47:45.188 [ERROR] [core.thing.internal.ThingManagerImpl] - Exception occurred while initializing handler of thing 'zigbee:coordinator_cc2531:55d86e72ba': Task java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask@5ffb0d6c[Not completed, task = java.util.concurrent.Executors$RunnableAdapter@5503661c[Wrapped task = org.openhab.binding.zigbee.handler.ZigBeeCoordinatorHandler$$Lambda$1428/0x000000107e578040@5bc492cc]] rejected from org.openhab.core.internal.common.WrappedScheduledExecutorService@348be867[Terminated, pool size = 0, active threads = 0, queued tasks = 0, completed tasks = 1]
java.util.concurrent.RejectedExecutionException: Task java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask@5ffb0d6c[Not completed, task = java.util.concurrent.Executors$RunnableAdapter@5503661c[Wrapped task = org.openhab.binding.zigbee.handler.ZigBeeCoordinatorHandler$$Lambda$1428/0x000000107e578040@5bc492cc]] rejected from org.openhab.core.internal.common.WrappedScheduledExecutorService@348be867[Terminated, pool size = 0, active threads = 0, queued tasks = 0, completed tasks = 1]
at java.util.concurrent.ThreadPoolExecutor$AbortPolicy.rejectedExecution(ThreadPoolExecutor.java:2055) ~[?:?]
at java.util.concurrent.ThreadPoolExecutor.reject(ThreadPoolExecutor.java:825) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor.delayedExecute(ScheduledThreadPoolExecutor.java:340) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor.schedule(ScheduledThreadPoolExecutor.java:562) ~[?:?]
at org.openhab.binding.zigbee.handler.ZigBeeCoordinatorHandler.startZigBeeNetwork(ZigBeeCoordinatorHandler.java:562) ~[?:?]
at org.openhab.binding.zigbee.handler.ZigBeeCoordinatorHandler.startZigBee(ZigBeeCoordinatorHandler.java:410) ~[?:?]
at org.openhab.binding.zigbee.cc2531.handler.CC2531Handler.initializeDongle(CC2531Handler.java:63) ~[?:?]
at org.openhab.binding.zigbee.handler.ZigBeeCoordinatorHandler.initialize(ZigBeeCoordinatorHandler.java:321) ~[?:?]
at jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at java.lang.reflect.Method.invoke(Method.java:566) ~[?:?]
at org.openhab.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:154) [bundleFile:?]
at org.openhab.core.internal.common.Invocation.call(Invocation.java:52) [bundleFile:?]
What am I doing wrong? Who can help?
