TheJM
(JM)
April 18, 2020, 2:06pm
1
Hey guys,
I am having issues doing unit conversions with items from my Davis Binding (version: 1.14.0.201905050308). I am trying to convert C to F but it isnt working. See my files below. I set my region settings and OpenHAB and even explicitly set the unit type preference in system config.
When i change the “[%.1f °F]” section in the items file, it changes the unit C to F in the sitemap but it doesn’t change the number. In other words 20C will change to 20F.
Item File:
Number:Temperature OutsideTemp "Outside Temp [%.1f °F]" { davis="outside_temp" }
Ive tried to put [%.1f °F], [%.1f °C], [%.1f °K], and [%.1f %unit%] and all change the unit but not the number. [%.1f %unit%] changes the unit to F but not the number.
Sitemap:
Text item=OutsideTemp
Am i doing something wrong here?
H102
(CM6.5 H102)
April 18, 2020, 2:13pm
2
Remove the UoM and see if it works e.g. remove the : and Temperature part.
Number OutsideTemp "Outside Temp [%.1f °F]" { davis="outside_temp" }
glhopital
(Gaël L'hopital)
April 18, 2020, 2:15pm
3
Are you sure Davis binding provides UoM values ?
TheJM
(JM)
April 18, 2020, 2:19pm
4
Same happened as in the OP.
TheJM
(JM)
April 18, 2020, 2:20pm
5
I wasnt aware that bindings had to specify this. If this is the case i guess the binding isn’t compatible with OpenHAB UoM?
glhopital
(Gaël L'hopital)
April 18, 2020, 2:22pm
6
Yes, all bindings have not been updated to take advantage of UoM. So you have to refer to the binding documentation to check this
H102
(CM6.5 H102)
7
You can try a more recent snapshot version.
https://openhab.jfrog.io/openhab/libs-pullrequest-local/org/openhab/binding/org.openhab.binding.davis/1.15.0-SNAPSHOT/
Remove the binding from PaperUI and add the jar file to /usr/share/openhab2/addons
then restart OH.
glhopital
(Gaël L'hopital)
April 18, 2020, 2:26pm
8
From binding documentation, UoM is not implemented
TheJM
(JM)
9
Thanks. Where can i find that documentation for next time? I appreciate your help!
H102
(CM6.5 H102)
April 18, 2020, 2:29pm
10
If no UoM on the item you should still be able to add this in your sitemap.
Sitemap file example:
Text item=OutsideTemp label="Outside [%.1f °F]"
glhopital
(Gaël L'hopital)
11
In the openhab website in the bindings section
TheJM
(JM)
April 19, 2020, 1:38am
12
Okay thanks so much for the help! I was able get it to work! I swear i tried this earlier but guess i didn’t see the Item and Sitemap files below.
Items File
Number:Temperature OutsideTemp "Outside Temp [%.1f °C]" <temperature> { davis="outside_temp" }
Sitemap FIle
Text item=OutsideTemp label="Outside Temp [%.1f °F]"
EDIT: I just discovered where I went wrong! in the items file there cant be a space between the unit letter (C or F) and the bracket. Once I fixed that, it all converted fine.
H102
(CM6.5 H102)
April 19, 2020, 2:02pm
13
Glad you got it working.
Please change the solution check box so others having this issue will also find a quick solution.
TheJM
(JM)
April 20, 2020, 11:53pm
15
I am getting these log messages with the 1.15 snapshot binding. Any idea what could be causing this? Im not too good at understanding logs. It seems to be accepting data from the station correctly.
Thanks in advance for the help!
Here is my Davis.cfg
hostName=192.168.1.196
readResponseWaitTime=1000
refresh=10000
Logs:
2020-04-20 19:48:26.891 [WARN ] [.binding.davis.internal.DavisBinding] - wakeup failed, retry
2020-04-20 19:48:27.541 [WARN ] [.binding.davis.internal.DavisBinding] - wakeup failed, retry
2020-04-20 19:48:28.741 [WARN ] [.binding.davis.internal.DavisBinding] - Wakeup failed, trying reset sequence!
2020-04-20 19:48:28.741 [WARN ] [.binding.davis.internal.DavisBinding] - error, dropping remaining data!
2020-04-20 19:48:29.192 [WARN ] [.binding.davis.internal.DavisBinding] - wakeup failed, retry
2020-04-20 19:48:30.842 [WARN ] [.binding.davis.internal.DavisBinding] - wakeup failed, retry
2020-04-20 19:48:31.393 [WARN ] [.binding.davis.internal.DavisBinding] - I/O Exception reset after Error: {}
java.io.IOException: unexpected response too short: , expected: \n\rOK\n\r
at org.openhab.binding.davis.internal.DavisBinding.expectString(DavisBinding.java:447) ~[bundleFile:?]
at org.openhab.binding.davis.internal.DavisBinding.resetAfterError(DavisBinding.java:309) [bundleFile:?]
at org.openhab.binding.davis.internal.DavisBinding.sendCommand(DavisBinding.java:434) [bundleFile:?]
at org.openhab.binding.davis.internal.DavisBinding.execute(DavisBinding.java:140) [bundleFile:?]
at org.openhab.core.binding.AbstractActiveBinding$BindingActiveService.execute(AbstractActiveBinding.java:146) [bundleFile:?]
at org.openhab.core.service.AbstractActiveService$RefreshThread.run(AbstractActiveService.java:169) [bundleFile:?]
2020-04-20 19:48:34.495 [WARN ] [.binding.davis.internal.DavisBinding] - unexpected response too short: , expected: \n\rOK\n\r
2020-04-20 19:48:34.495 [WARN ] [.binding.davis.internal.DavisBinding] - error, dropping remaining data!
2020-04-20 19:48:35.883 [vent.ItemStateChangedEvent] - MasterBRFanSmartplugRssi changed from -61 dBm to -62 dBm
2020-04-20 19:48:35.884 [vent.ItemStateChangedEvent] - MasterBRFanSmartplugPower changed from 0.573461 W to 0.614874 W
2020-04-20 19:48:35.884 [vent.ItemStateChangedEvent] - MasterBRFanSmartplugCurrent changed from 0.07361 A to 0.074154 A
2020-04-20 19:48:35.884 [vent.ItemStateChangedEvent] - MasterBRFanSmartplugVoltage changed from 126.540277 V to 126.657605 V
2020-04-20 19:48:36.244 [WARN ] [.binding.davis.internal.DavisBinding] - wakeup failed, retry
2020-04-20 19:48:37.596 [WARN ] [.binding.davis.internal.DavisBinding] - wakeup failed, retry
2020-04-20 19:48:40.098 [vent.ItemStateChangedEvent] - ZWaveSerialControllerSerialSof changed from 28950 to 28951
2020-04-20 19:48:40.185 [vent.ItemStateChangedEvent] - ZWaveSerialControllerSerialSof changed from 28951 to 28952
2020-04-20 19:48:40.897 [WARN ] [.binding.davis.internal.DavisBinding] - I/O Exception reset after Error: {}
2020-04-20 19:48:41.633 [vent.ItemStateChangedEvent] - ZWaveSerialControllerSerialSof changed from 28952 to 28953
2020-04-20 19:48:42.000 [WARN ] [.binding.davis.internal.DavisBinding] - wakeup failed, retry
2020-04-20 19:48:42.545 [WARN ] [.binding.davis.internal.DavisBinding] - expected length of response: 99, but got: 107
2020-04-20 19:48:42.546 [WARN ] [.binding.davis.internal.DavisBinding] - error, dropping remaining data!
2020-04-20 19:48:44.300 [WARN ] [.binding.davis.internal.DavisBinding] - wakeup failed, retry
2020-04-20 19:48:45.646 [WARN ] [.binding.davis.internal.DavisBinding] - wakeup failed, retry
2020-04-20 19:48:47.947 [WARN ] [.binding.davis.internal.DavisBinding] - wakeup failed, retry
2020-04-20 19:48:49.602 [WARN ] [.binding.davis.internal.DavisBinding] - unexpected response too short: , expected: <ACK>
2020-04-20 19:48:49.602 [WARN ] [.binding.davis.internal.DavisBinding] - error, dropping remaining data!
2020-04-20 19:48:50.931 [vent.ItemStateChangedEvent] - MasterBRFanSmartplugPower changed from 0.614874 W to 0.609929 W
2020-04-20 19:48:50.931 [vent.ItemStateChangedEvent] - MasterBRFanSmartplugCurrent changed from 0.074154 A to 0.073703 A
2020-04-20 19:48:50.931 [vent.ItemStateChangedEvent] - MasterBRFanSmartplugVoltage changed from 126.657605 V to 126.603915 V
2020-04-20 19:48:51.703 [WARN ] [.binding.davis.internal.DavisBinding] - wakeup failed, retry
2020-04-20 19:48:52.248 [WARN ] [.binding.davis.internal.DavisBinding] - wakeup failed, retry
2020-04-20 19:48:54.449 [WARN ] [.binding.davis.internal.DavisBinding] - I/O Exception reset after Error: {}
java.io.IOException: unexpected response too short: \n\r, expected: \n\rOK\n\r
2020-04-20 19:48:55.551 [WARN ] [.binding.davis.internal.DavisBinding] - wakeup failed, retry
2020-04-20 19:48:57.005 [WARN ] [.binding.davis.internal.DavisBinding] - I/O Exception reset after Error: {}
2020-04-20 19:48:58.107 [WARN ] [.binding.davis.internal.DavisBinding] - wakeup failed, retry
2020-04-20 19:49:00.853 [WARN ] [.binding.davis.internal.DavisBinding] - unexpected response too short: \n\r, expected: \n\rOK\n\r
2020-04-20 19:49:00.853 [WARN ] [.binding.davis.internal.DavisBinding] - error, dropping remaining data!
2020-04-20 19:49:02.954 [WARN ] [.binding.davis.internal.DavisBinding] - wakeup failed, retry
2020-04-20 19:49:03.408 [vent.ItemStateChangedEvent] - rx_total changed from 27603 to 27623
2020-04-20 19:49:03.409 [vent.ItemStateChangedEvent] - rx_crc changed from 0
to 0
2020-04-20 19:49:04.508 [WARN ] [.binding.davis.internal.DavisBinding] - wakeup failed, retry
2020-04-20 19:49:05.984 [vent.ItemStateChangedEvent] - MasterBRFanSmartplugRssi changed from -62 dBm to -61 dBm
2020-04-20 19:49:05.984 [vent.ItemStateChangedEvent] - MasterBRFanSmartplugPower changed from 0.609929 W to 0.601883 W
2020-04-20 19:49:05.984 [vent.ItemStateChangedEvent] - MasterBRFanSmartplugCurrent changed from 0.073703 A to 0.074206 A
2020-04-20 19:49:05.984 [vent.ItemStateChangedEvent] - MasterBRFanSmartplugVoltage changed from 126.603915 V to 126.5144 V
2020-04-20 19:49:06.809 [WARN ] [.binding.davis.internal.DavisBinding] - wakeup failed, retry
2020-04-20 19:49:08.255 [WARN ] [.binding.davis.internal.DavisBinding] - I/O Exception reset after Error: {}
2020-04-20 19:49:09.110 [WARN ] [.binding.davis.internal.DavisBinding] - wakeup failed, retry
2020-04-20 19:49:10.311 [WARN ] [.binding.davis.internal.DavisBinding] - Wakeup failed, trying reset sequence!
2020-04-20 19:49:10.311 [WARN ] [.binding.davis.internal.DavisBinding] - error, dropping remaining data!
2020-04-20 19:49:10.311 [WARN ] [.binding.davis.internal.DavisBinding] - I/O Exception reset after Error: {}
java.io.IOException: Stream closed.
at java.net.AbstractPlainSocketImpl.available(AbstractPlainSocketImpl.java:470) ~[?:1.8.0_232]
at java.net.SocketInputStream.available(SocketInputStream.java:259) ~[?:1.8.0_232]
at org.openhab.binding.davis.internal.DavisBinding.readResponse(DavisBinding.java:326) ~[bundleFile:?]
at org.openhab.binding.davis.internal.DavisBinding.resetAfterError(DavisBinding.java:305) [bundleFile:?]
at org.openhab.binding.davis.internal.DavisBinding.execute(DavisBinding.java:143) [bundleFile:?]
