I have a weird issue trying to get HomeMatic Running with Openhab.
Background: I have a NAS with Openhab (running as network: host) and a ccu3, connected to some sensors.
I installed the binding, and added the brige via things file (…203 is my static ccu3 ip, …200 is my static NAS ip):
Bridge homematic:bridge:ccu [ gatewayAddress=“192.168.178.203”, callbackHost=“192.168.178.200” ]
Then the sensors showed up in paperui and I added them there.
What I see now: Bridge is showen as Online, all sensor are showen as Offline (java.util.concurrent.TimeoutException: Total timeout 15000 ms elapsed).
Logs in openhab look fine:
2020-12-29 09:58:11.207 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'WIRED' on gateway 'ccu' not available, disabling support
2020-12-29 09:58:11.227 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'CUXD' on gateway 'ccu' not available, disabling support
2020-12-29 09:58:11.245 [INFO ] [ommunicator.AbstractHomematicGateway] - HmGatewayInfo[id=CCU,type=CCU2,firmware=3.55.5,address=QEQ0704281,rf=true,wired=false,hmip=true,cuxd=false,group=true]
These are the ccu3 logs:
Dec 29 10:58:11 de.eq3.cbcs.legacy.bidcos.rpc.LegacyServiceHandler INFO [vert.x-worker-thread-2] (un)registerCallback on LegacyServiceHandler called from url: http://openhab.validation:1000
Dec 29 10:58:11 de.eq3.ccu.virtualdevice.service.internal.rega.VirtualDeviceHandlerRega INFO [vert.x-eventloop-thread-4] (un)registerCallback on VirtualDeviceHandlerRega called from url: http://openhab.validation:1000
Dec 29 10:58:11 de.eq3.cbcs.legacy.bidcos.rpc.LegacyServiceHandler INFO [vert.x-worker-thread-3] (un)registerCallback on LegacyServiceHandler called from url: http://192.168.178.200:9125
Dec 29 10:58:11 de.eq3.cbcs.legacy.bidcos.rpc.LegacyServiceHandler INFO [vert.x-worker-thread-3] init finished
Dec 29 10:58:11 de.eq3.ccu.virtualdevice.service.internal.rega.VirtualDeviceHandlerRega INFO [vert.x-eventloop-thread-4] (un)registerCallback on VirtualDeviceHandlerRega called from url: http://192.168.178.200:9125
Dec 29 10:58:11 de.eq3.ccu.virtualdevice.service.internal.rega.VirtualDeviceHandlerRega INFO [vert.x-eventloop-thread-4] Added InterfaceId: GROUP-ccu
Dec 29 10:58:38 de.eq3.ccu.virtualdevice.service.internal.rega.VirtualDeviceHandlerRega INFO [vert.x-eventloop-thread-4] (un)registerCallback on VirtualDeviceHandlerRega called from url: http://192.168.178.200:9126
Dec 29 10:58:42 de.eq3.cbcs.legacy.bidcos.rpc.LegacyServiceHandler INFO [vert.x-worker-thread-2] (un)registerCallback on LegacyServiceHandler called from url: http://192.168.178.200:9126
Dec 29 10:59:02 de.eq3.cbcs.legacy.bidcos.rpc.LegacyServiceHandler INFO [vert.x-worker-thread-2] (un)registerCallback on LegacyServiceHandler called from url: http://192.168.178.200:9126
Dec 29 10:59:08 de.eq3.ccu.virtualdevice.service.internal.rega.VirtualDeviceHandlerRega INFO [vert.x-eventloop-thread-4] (un)registerCallback on VirtualDeviceHandlerRega called from url: http://192.168.178.200:9126
Dec 29 10:59:22 de.eq3.cbcs.legacy.bidcos.rpc.LegacyServiceHandler INFO [vert.x-worker-thread-2] (un)registerCallback on LegacyServiceHandler called from url: http://192.168.178.200:9126
Dec 29 10:59:22 de.eq3.cbcs.legacy.bidcos.rpc.LegacyServiceHandler INFO [vert.x-worker-thread-2] Removed InterfaceId: HMIP-ccu
Dec 29 10:59:22 de.eq3.cbcs.legacy.bidcos.rpc.LegacyServiceHandler INFO [vert.x-worker-thread-2] init finished
Dec 29 10:59:22 de.eq3.ccu.virtualdevice.service.internal.rega.VirtualDeviceHandlerRega INFO [vert.x-eventloop-thread-4] (un)registerCallback on VirtualDeviceHandlerRega called from url: http://192.168.178.200:9126
Dec 29 10:59:22 de.eq3.ccu.virtualdevice.service.internal.rega.VirtualDeviceHandlerRega INFO [vert.x-eventloop-thread-4] Added InterfaceId: GROUP-ccu
Dec 29 10:59:30 de.eq3.cbcs.legacy.bidcos.rpc.internal.InterfaceInitializer ERROR [vert.x-worker-thread-0] IO Exception: Could not add interface: HMIP-3014F711A0001F9A49942719
de.eq3.cbcs.legacy.communication.rpc.RpcIOException: java.net.ConnectException: Connection timed out (Connection timed out)
at de.eq3.cbcs.legacy.communication.rpc.internal.transport.http.HttpTransport.sendRequest(HttpTransport.java:110)
at de.eq3.cbcs.legacy.communication.rpc.internal.rpc.RpcClient.sendRequest(RpcClient.java:94)
at de.eq3.cbcs.legacy.communication.rpc.internal.rpc.RpcClient.invoke(RpcClient.java:82)
at com.sun.proxy.$Proxy20.listDevices(Unknown Source)
at de.eq3.cbcs.legacy.bidcos.rpc.internal.LegacyBackendClient.listDevices(LegacyBackendClient.java:139)
at de.eq3.cbcs.legacy.bidcos.rpc.internal.DeviceUtil.synchronizedBackendDevices(DeviceUtil.java:148)
at de.eq3.cbcs.legacy.bidcos.rpc.internal.InterfaceInitializer.handle(InterfaceInitializer.java:109)
at de.eq3.cbcs.legacy.bidcos.rpc.internal.InterfaceInitializer.handle(InterfaceInitializer.java:26)
at io.vertx.core.eventbus.impl.HandlerRegistration.deliver(HandlerRegistration.java:212)
at io.vertx.core.eventbus.impl.HandlerRegistration.handle(HandlerRegistration.java:191)
at io.vertx.core.eventbus.impl.EventBusImpl.lambda$deliverToHandler$3(EventBusImpl.java:505)
at io.vertx.core.impl.ContextImpl.lambda$wrapTask$2(ContextImpl.java:337)
at io.vertx.core.impl.TaskQueue.lambda$new$0(TaskQueue.java:60)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at java.lang.Thread.run(Thread.java:748)
Caused by: java.net.ConnectException: Connection timed out (Connection timed out)
at java.net.PlainSocketImpl.socketConnect(Native Method)
at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:350)
at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:206)
at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:188)
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392)
at java.net.Socket.connect(Socket.java:589)
at org.apache.http.conn.scheme.PlainSocketFactory.connectSocket(PlainSocketFactory.java:120)
at org.apache.http.impl.conn.DefaultClientConnectionOperator.openConnection(DefaultClientConnectionOperator.java:179)
at org.apache.http.impl.conn.AbstractPoolEntry.open(AbstractPoolEntry.java:144)
at org.apache.http.impl.conn.AbstractPooledConnAdapter.open(AbstractPooledConnAdapter.java:134)
at org.apache.http.impl.client.DefaultRequestDirector.tryConnect(DefaultRequestDirector.java:612)
at org.apache.http.impl.client.DefaultRequestDirector.execute(DefaultRequestDirector.java:447)
at org.apache.http.impl.client.AbstractHttpClient.doExecute(AbstractHttpClient.java:884)
at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:82)
at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:107)
at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:55)
at de.eq3.cbcs.legacy.communication.rpc.internal.transport.http.HttpTransport.sendRequest(HttpTransport.java:106)
... 15 more
Dec 29 10:59:30 de.eq3.ccu.virtualdevice.service.internal.rega.BackendWorker INFO [vert.x-worker-thread-2] Execute BackendCommand: de.eq3.ccu.virtualdevice.service.internal.rega.BackendUpdateDevicesCommand
Dec 29 10:59:30 de.eq3.cbcs.legacy.bidcos.rpc.internal.InterfaceInitializer INFO [vert.x-worker-thread-0] Added InterfaceId: HMIP-3014F711A0001F9A49942719
I do not really understand what could be the issue, I did verify both ports are open on my NAS:
david@nas:/$ sudo netstat -tulpn | grep LISTEN | grep 912
tcp6 0 0 192.168.178.200:9125 :::* LISTEN 12864/java
tcp6 0 0 192.168.178.200:9126 :::* LISTEN 12864/java
Anyone has an idea what I could do?
Thx a lot in advance!
David
