same problem here. I had no issues since a long time now the KNX Tiunnel connection to my Enertex KNXnet/IP Router disconnects every day with similar failures as described some posts above. I have updated to the newes 3.4.2. maybe there was an change which produce this problem.
I have tried now also different devices running OH3.
RPI2
RPI4
QNAP NAS OH runnning in docker. All devices have the same problem:
2023-03-25 14:44:48.435 [ERROR] [KNXnet/IP Tunneling 192.168.0.4:3671] - close connection - maximum send attempts
tuwien.auto.calimero.KNXAckTimeoutException: maximum send attempts, no service acknowledgment received
at tuwien.auto.calimero.knxnetip.ConnectionBase.send(ConnectionBase.java:253) ~[bundleFile:?]
at tuwien.auto.calimero.knxnetip.KNXnetIPTunnel.send(KNXnetIPTunnel.java:213) ~[bundleFile:?]
at tuwien.auto.calimero.link.KNXNetworkLinkIP.onSend(KNXNetworkLinkIP.java:423) ~[bundleFile:?]
at tuwien.auto.calimero.link.AbstractLink.send(AbstractLink.java:385) ~[bundleFile:?]
at tuwien.auto.calimero.link.KNXNetworkLinkIP.sendRequestWait(KNXNetworkLinkIP.java:402) ~[bundleFile:?]
at tuwien.auto.calimero.process.ProcessCommunicatorImpl.send(ProcessCommunicatorImpl.java:461) ~[bundleFile:?]
at tuwien.auto.calimero.process.ProcessCommunicatorImpl.write(ProcessCommunicatorImpl.java:410) ~[bundleFile:?]
at tuwien.auto.calimero.process.ProcessCommunicatorImpl.write(ProcessCommunicatorImpl.java:365) ~[bundleFile:?]
at org.openhab.binding.knx.internal.client.AbstractKNXClient.sendToKNX(AbstractKNXClient.java:553) ~[bundleFile:?]
at org.openhab.binding.knx.internal.client.AbstractKNXClient.writeToKNX(AbstractKNXClient.java:513) ~[bundleFile:?]
at org.openhab.binding.knx.internal.handler.DeviceThingHandler.lambda$7(DeviceThingHandler.java:253) ~[bundleFile:?]
at org.openhab.binding.knx.internal.handler.DeviceThingHandler.withKNXType(DeviceThingHandler.java:148) [bundleFile:?]
at org.openhab.binding.knx.internal.handler.DeviceThingHandler.withKNXType(DeviceThingHandler.java:142) [bundleFile:?]
at org.openhab.binding.knx.internal.handler.DeviceThingHandler.handleCommand(DeviceThingHandler.java:248) [bundleFile:?]
at jdk.internal.reflect.GeneratedMethodAccessor139.invoke(Unknown Source) ~[?:?]
at java.lang.reflect.Method.invoke(Method.java:566) ~[?:?]
at org.openhab.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:154) [bundleFile:?]
at org.openhab.core.internal.common.InvocationHandlerSync.invoke(InvocationHandlerSync.java:59) [bundleFile:?]
at com.sun.proxy.$Proxy2321.handleCommand(Unknown Source) [?:?]
at org.openhab.core.thing.internal.profiles.ProfileCallbackImpl.handleCommand(ProfileCallbackImpl.java:85) [bundleFile:?]
at org.openhab.core.thing.internal.profiles.SystemFollowProfile.onStateUpdateFromItem(SystemFollowProfile.java:60) [bundleFile:?]
at jdk.internal.reflect.GeneratedMethodAccessor168.invoke(Unknown Source) ~[?:?]
at org.openhab.core.internal.common.Invocation.call(Invocation.java:52) [bundleFile:?]
2023-03-25 14:44:48.549 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'ThingHandler.handleCommand()' on 'org.openhab.binding.knx.internal.handler.DeviceThingHandler@1baae65': process communicator detached
java.lang.IllegalStateException: process communicator detached
at tuwien.auto.calimero.process.ProcessCommunicatorImpl.write(ProcessCommunicatorImpl.java:408) ~[?:?]
at tuwien.auto.calimero.process.ProcessCommunicatorImpl.write(ProcessCommunicatorImpl.java:365) ~[?:?]
at org.openhab.binding.knx.internal.client.AbstractKNXClient.sendToKNX(AbstractKNXClient.java:553) ~[?:?]
at org.openhab.binding.knx.internal.client.AbstractKNXClient.writeToKNX(AbstractKNXClient.java:513) ~[?:?]
at org.openhab.binding.knx.internal.handler.DeviceThingHandler.lambda$7(DeviceThingHandler.java:253) ~[?:?]
at org.openhab.binding.knx.internal.handler.DeviceThingHandler.withKNXType(DeviceThingHandler.java:148) ~[?:?]
at org.openhab.binding.knx.internal.handler.DeviceThingHandler.withKNXType(DeviceThingHandler.java:142) ~[?:?]
at org.openhab.binding.knx.internal.handler.DeviceThingHandler.handleCommand(DeviceThingHandler.java:248) ~[?:?]
