Issues with new setup
  • Platform information:
    • Hardware:x86_64, 12GB RAM, Zooz 800 USB Stick, GoControl GC-TBZ48
    • OS: Archlinux
    • Java Runtime Environment: docker image
    • openHAB version: 4.3.5
  • Issue of the topic: general issues with z wave
I started setting up a new controller to eventually move to my parents house and I only have 1 z wave device I plan to connect to the USB stick, the GZ-TBZ48. I managed to add the z wave controller but I couldn’t get it to associate the HVAC device (GZ-TBZ48) by using the “scan” button on the z wave binding.
Eventually I tried using :
docker run -ti --rm -p 8091:8091 -p 3000:3000 --device=/dev/ttyACM0:/dev/zwave -v $(pwd)/store:/usr/src/app/store zwavejs/zwave-js-ui:latest
and I was able to associate the hvac device there without security enabled but i was forced to set a handful of unique security keys (i just type 32 1’s, then 2’s, etc. for each field, a total of 6).
when i saw this worked, i went back to OH to try to add the device and it didn’t magically appear, but when i did the scan and woke the device with a button press (didn’t go through inclusion, etc. no the HVAC device) – it found the device but it never fully synchronized. i’m not sure if its b/c it was associated to the USB stick with a different key or not (i assume no b/c i claims no security was used).
one thing that’s interesting though is i frequently see this error message from openhab:
2025-07-16 21:22:57.777 [INFO ] [ve.internal.protocol.ZWaveController] - Starting ZWave controller
2025-07-16 21:22:57.778 [INFO ] [ve.internal.protocol.ZWaveController] - ZWave timeout is set to 5000ms. Soft reset is false.
2025-07-16 21:23:00.931 [WARN ] [.core.thing.binding.BaseThingHandler] - Attempt to apply invalid configuration 'Configuration[{key=controller_softreset; type=Boolean; value=false}, {key=security_networkkey; type=String; value=D0 68 C2 56 ED B5 5D EA 1D 00 42 5F 54 F5 DB 4A}, {key=security_inclusionmode; type=BigDecimal; value=2}, {key=controller_sisnode; type=BigDecimal; value=0}, {key=controller_maxawakeperiod; type=BigDecimal; value=20}, {key=controller_sync; type=Boolean; value=false}, {key=controller_master; type=Boolean; value=true}, {key=inclusion_mode; type=BigDecimal; value=1}, {key=port; type=String; value=/dev/zwave}, {key=controller_wakeupperiod; type=BigDecimal; value=7200}, {key=controller_exclude; type=Boolean; value=false}, {key=heal_time; type=BigDecimal; value=2}, {key=controller_inclusiontimeout; type=BigDecimal; value=30}, {key=controller_hardreset; type=Boolean; value=false}]' on thing 'zwave:serial_zstick:7a3578ec85' blocked. This is most likely a bug: {controller_sisnode=The value must not be less than 1.}
2025-07-16 21:26:55.150 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 1: Device discovery could not resolve to a thingType! Manufacturer data not known.
2025-07-16 21:26:55.154 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 2: Device discovery could not resolve to a thingType! Manufacturer data not known.
2025-07-16 21:26:55.157 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'zwave:device:7a3578ec85:node2' to inbox.
2025-07-16 21:32:02.304 [INFO ] [ve.internal.protocol.ZWaveController] - Starting ZWave controller
2025-07-16 21:32:02.305 [INFO ] [ve.internal.protocol.ZWaveController] - ZWave timeout is set to 5000ms. Soft reset is false.
2025-07-16 21:32:05.361 [WARN ] [.core.thing.binding.BaseThingHandler] - Attempt to apply invalid configuration 'Configuration[{key=controller_softreset; type=Boolean; value=false}, {key=security_networkkey; type=String; value=D0 68 C2 56 ED B5 5D EA 1D 00 42 5F 54 F5 DB 4A}, {key=security_inclusionmode; type=BigDecimal; value=2}, {key=controller_sisnode; type=BigDecimal; value=0}, {key=controller_maxawakeperiod; type=BigDecimal; value=20}, {key=controller_sync; type=Boolean; value=false}, {key=controller_master; type=Boolean; value=true}, {key=inclusion_mode; type=BigDecimal; value=1}, {key=port; type=String; value=/dev/zwave}, {key=controller_wakeupperiod; type=BigDecimal; value=7200}, {key=controller_exclude; type=Boolean; value=false}, {key=heal_time; type=BigDecimal; value=2}, {key=controller_inclusiontimeout; type=BigDecimal; value=30}, {key=controller_hardreset; type=Boolean; value=false}]' on thing 'zwave:serial_zstick:7a3578ec85' blocked. This is most likely a bug: {controller_sisnode=The value must not be less than 1.}
i’ve tried setting that sisnode value from the default(?) of 1 to 2 (from the ui) but its odd that it claims it has a value less than 1.
i’ll fidle around with updating the security key that openhab had for the usb stick to the all 1’s or 2’s, … values and see if it eventually works but this has been an uphill struggle so far.
I figured out how to “reset” an old zwave dongle ( usb-Zooz_800_Z-Wave_Stick ) so I switched and this one worked flawlessly on the first try.
My guess is the issue is that openhab doesn’t quite support the much newer zooz 800 usb stick ( ZST39LR) as I started getting recurring “bridge error” messages. Luckily I’m still within the return window at Amazon.
Have you checked out zwavejs?
i found it and tried it while trying to find something else to test the dongle with and after a bit of a struggle i was able to get it to work there. i ended up returning the dongle since i was able to use zwavejs to do a factory reset on another adapter.
for anybody who does a search, the Zooz 800 Series Z-Wave Long Range S2 USB Stick ZST39 LR does not work on openahb yet so it might be best to avoid it.
There was an issue with the Zooz 800 zstick on the OH Zwave binding as explained here. I suspect that was your issue because the symptom is the sisnode message you noted.
thanks, that does seem related but i’ve since returned the device since i didn’t want to wait too close to the return window expiring.
